WQWI871 Posted June 8, 2017 Report Posted June 8, 2017 I like a more sensitive receive, so, I generally set the squelch in Chirp to 10 on the Squelch 1 of my handhelds. Never thinking to go lower, I just figured that should be good and it always was. Recently I got a new Baofeng UV-82 and set everything the same as usual. I noticed I was getting clear receives on my UV5R's and BF-F9 while not receiving on my UV-82. I thought that was a little odd with the squelch set the same and just figured the squelch on the UV-82 wasn't as sensitive, so, I lowered it more. This time to 5. Of course I receive some transmissions, just a lot I don't. On 5, I noticed that still not getting some unless I open squelch. So, I set it to 1. I was missing a lot of transmissions this time even when I did open squelch all the way. Even connected to my base antenna. Any ideas what's up? It's almost as if each time I lowered squelch, It's closing it. Quote
WQYC236 Posted June 12, 2017 Report Posted June 12, 2017 I like a more sensitive receive, so, I generally set the squelch in Chirp to 10 on the Squelch 1 of my handhelds. Never thinking to go lower, I just figured that should be good and it always was. Recently I got a new Baofeng UV-82 and set everything the same as usual. I noticed I was getting clear receives on my UV5R's and BF-F9 while not receiving on my UV-82. I thought that was a little odd with the squelch set the same and just figured the squelch on the UV-82 wasn't as sensitive, so, I lowered it more. This time to 5. Of course I receive some transmissions, just a lot I don't. On 5, I noticed that still not getting some unless I open squelch. So, I set it to 1. I was missing a lot of transmissions this time even when I did open squelch all the way. Even connected to my base antenna. Any ideas what's up? It's almost as if each time I lowered squelch, It's closing it. Just an FYI here. I usually find my Baofeng's set to a squelch of 4 out of the box. I always reset mine to 1 and never look back. That brings in the weakest signals in my area with rarely any noise. My motorola's are also set to 1 and are extremely sensitive to weak signals without picking up the stray noise. Quote
WQWI871 Posted June 12, 2017 Author Report Posted June 12, 2017 My baofengs were all set to a squelch of 4 from stock. It's hard to explain, but, Chirp allows to fine tune squelch levels. For example, a squelch level of 1 is fine tuned to about a 25 sensitivity. So, although 1 is the lowest level (excluding 0), it won't actually have the most sensitivity without fine tuning the sensitivity in Chirp. I generally change the squelch level 1 to a 1 - 10 sensitivity. If that makes sense. Quote
jwilkers Posted June 16, 2017 Report Posted June 16, 2017 The Miklor site has a good explanation of the chirp squelch adjustments. The factory thresholds generally need tweaking. Suggested values are presented. Sent from my LG-D631 using Tapatalk Quote
