I recently purchased a pair of RT87s in addition to the UV-5R, AR-5RM, and Arcshell AR-5 radios I already have. I programmed them in CHIRP and they communicate with one another just fine, but they absolutely will not receive from nor transmit to any of the other radios. The other radios all communicate amongst themselves just fine, but the RT87s will only communicate with one another. I looked in CHIRP and on the menu for anything I may have set wrong, but nothing seems amiss. Is there some secret to these things that I have to do, or are they just designed to be incompatible with other radios? As a general rule, if you program two radios of different brands to the same frequency, they will communicate, but these little bastards just flatly refuse. Suggestions?
WRTC928
12 answers to this question
