Car installed radios for those who live in the cold northern states...
I'm so afraid to drill into my Forester to get a mobile 50W installed. The pic @tcp2525 shared is right about where I'd mount mine, but I'm having issues finding any firewall/trunk/hood grommets to get the cable inside. I also don't want to replace my car's existing radio/OnStar/Sirius/etc. stuff. I have a moon roof and could get by just using it on dry days but meh. Would a dashboard/trunk antenna with good window access suffice? What do y'all recommend?
Posted (edited)
I mean, if you know someone or a shop that installs aftermarket sound systems, that's who I'd lean on for install help. I've got a friend who does it, so for me, it's no big deal. (Also, my cars are out of warranty). To me, it's not much different than a car sound system. The major differences are (a) power: it seems like a lot of these radios need to go direct to a battery power post and negative to a good ground point (b) antenna cabling: the antenna needs to penetrate the car which might lead to water/weather issues.
That's my take. YMMV.
Edited by Imply4907
I'm so afraid to drill into my Forester to get a mobile 50W installed. The pic [mention=6186]tcp2525[/mention] shared is right about where I'd mount mine, but I'm having issues finding any firewall/trunk/hood grommets to get the cable inside. I also don't want to replace my car's existing radio/OnStar/Sirius/etc. stuff. I have a moon roof and could get by just using it on dry days but meh. Would a dashboard/trunk antenna with good window access suffice? What do y'all recommend?
Some things to consider with your Subaru:
Antenna -
Consider using a ditch light hood bracket, or lip mount, to install an antenna on the hood. While not necessarily the ideal location, it can work just fine. A benefit is easy cable run into the cabin.
Radio -
A typical 50w mobile might a challenge to mount in the front area. You have some options:
- A remote faceplate radio where you can mount the main radio under a seat or in the cargo area, using an extension to bring display to dash area.
- An all in one unit, like the Midland MTX575, where the radio is remote and all you need is the mic to control everything. There are other brands too.
- A 20-30w radio that has a smaller footprint.
For display panel mounting, consider something like a Pro-Clip vehicle specific mount or even a RAM mount. You can easily mount a radio face/control head using easily available pieces.
Thank you @Imply4907 and @Hoppyjr! I live close-by to an offroad-specific autoshop, will give them a ring to see if they've done similar for radio enthusiasts in general. Not trying to mess with any of the pillars/rails since I want to keep them fully functional. I don't need a big 50W, any recommendations for something that can get plugged into the cigarette lighter (or an inverter I have for normal three-prong 120v which plugs into the lighter port)? The Forester also has a lighter port in the back. Also, for antennas, I know GMRS you typically want them upright hence the recommendations, but are there any decent options which could run horizontally along my rails? Looking for functional/compatible with concurrent kayak/gear use rather than objective best case for radio alone. Thanks!
Some of the sketchiest electrical connections I've ever seen have come out of those shops.
Them, and trailer builders, I swear 😂
