iyakonboats Posted February 21 Report Posted February 21 Hopefully the listing caught your attention. I used to know how to setup my BF-F8HP and I live in Stuart, Florida and we have a repeater on 462.625 and it shows input and output tones of 136.5, which I setup in the radio via R-CTCSS and T-CTCSS as 136.5 and my offset is 5MHZ+. I know there may not be others on the repeater; however, my other Baofeng I setup the same way and cannot hear when I transit. Am I missing something that is painfully obvious? Quote
GrouserPad Posted February 21 Report Posted February 21 Are you getting a tone or cw id or squelch tail back from the repeater with one radio and not the other? Quote
TrikeRadio Posted February 21 Report Posted February 21 if your two radios are too close together when you test hitting the repeater, they could be desensing each other. Move them apart... like across the room if necessary... or get someone else to monitor the other radio further from your transmitting one. WRUU653, AdmiralCochrane, WSGC763 and 1 other 4 Quote
iyakonboats Posted February 21 Author Report Posted February 21 I went outside with one and left the other in my office with my phone recording, heard nothing. I know it must be something I'm doing wrong Quote
iyakonboats Posted February 21 Author Report Posted February 21 14 minutes ago, GrouserPad said: Are you getting a tone or cw id or squelch tail back from the repeater with one radio and not the other? I am getting that "feedback" after I'm done transmitting, yes Quote
TrikeRadio Posted February 21 Report Posted February 21 Does your radio have a setting to turn ON repeaters? (Some do, some are set on automatically without a setting) also... there are usually pre-set SIMPLEX GMRS channels that only do simplex... an then above channel 22 there are repeater channels for those same frequencies... what channel slot are you useing? if it is below 23 you may not be able to hit a repeater. Quote
TrikeRadio Posted February 21 Report Posted February 21 2 minutes ago, iyakonboats said: I am getting that "feedback" after I'm done transmitting, yes can you reverse the process? use the other radio to transmit and see if you get a repeater squelch tail noise back on that one too? Quote
iyakonboats Posted February 21 Author Report Posted February 21 On the BF-F8HP it doesn't have this setting, it lets me manually set the frequency directly, I'm not using the preset channels. I am getting the squelch tail noise on the first one. I just tried in reverse, same. I'm looking to see if I am missing something in the F8HP Quote
iyakonboats Posted February 21 Author Report Posted February 21 I'm using this radio and these instructions: Quote
TrikeRadio Posted February 21 Report Posted February 21 6 minutes ago, iyakonboats said: I'm using this radio and these instructions: hmm.. if you followed the instructions on that video for both radios, and are getting squelch tail response from the repeater on both... then I am not sure why you are not hearing your transmit from one to the repeater and back to the other. Have you just tried calling for a radio check with your id to see if someone else out there can hear you and respond? Quote
TrikeRadio Posted February 21 Report Posted February 21 8 minutes ago, Socalgmrs said: If you have set ups repeater your radios will never communicate with each other. They will need to transmit to the repeater and the repeater will transmit back out. Radios on. Handles set up to talk to repeaters do not talk to eachother. So are you close enough to the repeater to use it? he did say he was getting a squelch tail back from the repeaters with each radio when transmitting... so that seems to be working Quote
TrikeRadio Posted February 21 Report Posted February 21 Another thing you can do, remove the RX tones on both radios... jsut keep the TX tones for the repeater and see if that lets you hear your transmit to the repeater coming back in the other radio. Quote
iyakonboats Posted February 21 Author Report Posted February 21 20 minutes ago, Socalgmrs said: If you have set ups repeater your radios will never communicate with each other. They will need to transmit to the repeater and the repeater will transmit back out. Radios on. Handles set up to talk to repeaters do not talk to eachother. So are you close enough to the repeater to use it? From where the repeater is on the map, less than 3 miles and it shows about 10 miles range SteveShannon 1 Quote
TrikeRadio Posted February 22 Report Posted February 22 Any success yet @iyakonboats ? any other ideas? Quote
iyakonboats Posted February 23 Author Report Posted February 23 Hey, just tried removing the RX tones on both, same result. I'll try in another location to see, just maybe, there is a distance issue. TrikeRadio and WRUU653 2 Quote
WSEN940 Posted February 24 Report Posted February 24 Something else to try….this is the idiots guide to making sure you’re getting out at least. A troubleshooters guide of you will. set up one radio (the secondary) to receive simplex from the TX channel (from your primary radio) with no CTSS tone to ensure you are transmitting on the +5 channel and receiving it on the simplex channel. if that works, add the CTSS tone to the receiving radio to ensure that you are, in fact, transmitting the right tone as well. if the TX side is working…try the following. set up your other radio (secondary) with the repeaters output frequency…Transmit to the primary radio and make sure it’s receiving on that channel. Hopefully that makes sense…I’m two beers into the evening at a restaurant in Guatemala and trying to type on a small cellphone screen! Quote
