WRYF792 Posted February 23 Report Posted February 23 I've got a RA86, and I'm trying to program some local repeaters for a local club. The club is very strict about keeping their repeater info private, so I will not be providing crutial information regarding this. However, the issue I am having is I cannot figure out what the RX, RX PL, TX AND TX PL tones would be displayed as on the radio. I've hit a road block trying to figure this out, so any suggestions, links or info would be wonderfully appreicated! Quote
SteveShannon Posted February 23 Report Posted February 23 1 minute ago, WRYF792 said: I've got a RA86, and I'm trying to program some local repeaters for a local club. The club is very strict about keeping their repeater info private, so I will not be providing crutial information regarding this. However, the issue I am having is I cannot figure out what the RX, RX PL, TX AND TX PL tones would be displayed as on the radio. I've hit a road block trying to figure this out, so any suggestions, links or info would be wonderfully appreicated! PL is the same as CTCSS. Quote
WRYF792 Posted February 23 Author Report Posted February 23 All of the options when I push the menu button are as listed below: POWER LEVEL TX CODE RX CODE SQUELCH MIC GAIN REPEATER CALL TONE KEYTONE ROGER BEEP VOX TOT BACK LIGHT BRIGHTNESS SLEEP TIMER SPEAKER SELECTION With that all in mind, how will I know which one of those is the RX PL, the TX and the TX PL when those are what the club lists? Quote
WRYF792 Posted February 23 Author Report Posted February 23 28 minutes ago, SteveShannon said: PL is the same as CTCSS. This radio shows nowhere in the menu for a PL or a CTCSS. Quote
OffRoaderX Posted February 23 Report Posted February 23 6 minutes ago, Socalgmrs said: It’s really not this difficult to do Neither is leaving helpful, socially-acceptable answers - but, alas, "some people" are totally incapable of figuring it out and make themselves look like social-retards every time they leave a response.. @WRYF792 the settings you are looking for are the TX code and the RX code. I have given away my RA86, so I can't look at the radio or the user manual for you, but if i recall, in the TX and RX code lists you will be able to choose from either a PL/CTC tone or a DTC/DPL tone. all you need to do is find the NUMBER (dont worry if it starts with a P, C, or D), just find the NUMBER and select it from the list. WRYF792 and SteveShannon 1 1 Quote
WRYF792 Posted February 23 Author Report Posted February 23 11 minutes ago, Socalgmrs said: Are you programming on a computer it’s 1000xs easier. It’s only 2 in to the repeater and out from the repeater. This is honestly the same question asked 10xs. Week. It’s really not this difficult to do. We do t need to know the exact tones just put them in tx and rx. Some lazy people will chime in and say you do t even need the rx. If you can program tx you can program rx. It’s exactly the same. I would however recommend you reach out the the repeater club. After all that’s what a club should be for. I have reached out to the club, I do know that they have a lot of helpful members who are glad to help people like me, so fingers crossed! Worse case, somebody in the club has a cable I can borrow, because I agree, a computer makes programming completley painless! Sadly, I do not have a programming cable for the radio. I work at a dealership and it was in a truck we bought from auction, and they did not have the cable in the truck when they sold it. Pretty decent free find though nontheless! Quote
WRYF792 Posted February 23 Author Report Posted February 23 2 minutes ago, OffRoaderX said: Neither is leaving helpful, socially-acceptable answers - but, alas, "some people" are totally incapable of figuring it out and make themselves look like social-retards every time they leave a response.. @WRYF792 the settings you are looking for are the TX code and the RX code. I have given away my RA86, so I can't look at the radio or the user manual for you, but if i recall, in the TX and RX code lists you will be able to choose from either a PL/CTC tone or a DTC/DPL tone. all you need to do is find the NUMBER (dont worry if it starts with a P, C, or D), just find the NUMBER and select it from the list. The radio has TX and RX, what's throwing me off is the club lists the tones as RX TL and TX PL, but they also show info for just TX and RX. Thank you for the info about the number though. That is incredibly good to know! Quote
OffRoaderX Posted February 23 Report Posted February 23 16 minutes ago, WRYF792 said: The radio has TX and RX, what's throwing me off is the club lists the tones as RX TL and TX PL, but they also show info for just TX and RX. Thank you for the info about the number though. That is incredibly good to know! Disregard the letters "PL".. and for now, disregard the RX tone as it is optional and will just confuse you more - in the TX menu, find the number and select it.. This whole thing should take no more than 15 seconds.. For more information/explanation, this video was recently posted on Youtube explaining and simplifying this exact topic: WRUU653 and SteveShannon 1 1 Quote
Wsie552 Posted May 25 Report Posted May 25 This might be a bit late but hopefully will help someone. On the mike scroll through the channels. When you get to the repeater channels you will find double channel entries. On is simplex and the other is the repeater channel. Once there match up the channel and ct code in the manual. Then using the menu system on the correct freq you will be able to set the rec and tx. Best to find that info and write it down before setting the numbers. Quote
