WSGL345 Posted February 27 Report Posted February 27 My DB20-g menu has switched to Chinese; unfortunately I read only English? Quote
4 SteveShannon Posted February 27 Report Posted February 27 13 minutes ago, WSGL345 said: My DB20-g menu has switched to Chinese; unfortunately I read only English? Switch it back to English. Plug in the programming cable. Open the software (it should still be in English). Read from the radio. Open up the Edit menu. Choose Function Setup. Menu Language is the third selection on the right column of the Function Setup dialog. Change it to English (the middle selection). Write to the radio. amaff, Seapup, OffRoaderX and 3 others 4 2 Quote
2 SteveShannon Posted February 27 Report Posted February 27 1 minute ago, Socalgmrs said: I’m always amazed at the stuff people bring to this group. My radio randomly did something strange. (It may have with these junkers). Now you all need to tell me how to fix it. When did people stop thinking or reading for them selves? Use he software I’m sure your not using to re set that setting. It’s super easy IF your already programming in a computer like most don’t do. No, people don’t really come looking for advice. They really just want to see how useless you can be. It’s entertainment. WRUU653, tcp2525, wrci350 and 2 others 1 4 Quote
2 WRUU653 Posted February 27 Report Posted February 27 22 minutes ago, SteveShannon said: Switch it back to English I would go with @SteveShannon’s method. It’s probably the best and easiest solution… still @dosw’s post of $5 online Cantonese tutors could be effective after some effort and time and shouldn’t be discounted. SteveShannon 1 Quote
1 amaff Posted February 27 Report Posted February 27 15 minutes ago, WSGL345 said: My DB20-g menu has switched to Chinese; unfortunately I read only English? There's no menu option on the radio to change the language, I believe it can only be done through the programming software. My guess is you mis-clicked an option. Should be easy enough to switch it back. SteveShannon, WSGL345 and WRUU653 3 Quote
0 dosw Posted February 27 Report Posted February 27 Some instructions online say that holding down the V/M button while turning on the radio will initiate a factory reset, though that doesn't seem to be documented in the manual. The manual says this: If you follow the method in the manual you'll need to be able to read Chinese. You don't, but Google Translate does: I pointed my phone with Translate running, and captured an image with and without the translation happening: It's not perfect, but certainly good enough to comprehend a Chinese menu system in the radio. I love how "My DB20-g menu has switched to Chinese" as if it did it all by its lonesome sitting in the car while you slept. Hey, we've all done it. No shame! Of course we haven't established that a factory reset actually will reset the language. If it doesn't, your best option may be the programming software made for that radio, as Amaff described. Quote
0 WSGL345 Posted February 27 Author Report Posted February 27 Thanks to everyone for their help; I should have realized the answer was in the programming software. SteveShannon, GrouserPad, amaff and 1 other 4 Quote
0 SteveShannon Posted February 27 Report Posted February 27 Just now, WSGL345 said: Thanks to everyone for their help; I should have realized the answer was in the programming software. I’m just curious. What did you do right before the language changed to Chinese? dosw 1 Quote
0 amaff Posted February 27 Report Posted February 27 23 minutes ago, SteveShannon said: I’m just curious. What did you do right before the language changed to Chinese? That question gave me work PTSD The customers I've worked with have never once in recorded history made a change to their equipment before it started working improperly. Sometimes, they never made a change even after we hold their hand and show them the evidence of the change they made wrci350, dosw, SteveShannon and 1 other 4 Quote
-2 WRYS709 Posted February 27 Report Posted February 27 2 hours ago, Socalgmrs said: When did people stop thinking or reading for them selves? Is that your preference for sex as well? Quote
WSGL345
9 answers to this question
