Sonicgott Posted March 9 Report Posted March 9 Seems a lot of people make this mistake as a newbie GMRS user. I'm seeing several topics on it. People not hearing you? Here's my explanation. CTCSS - Continuous Tone Coded Squelch System DCS - Digital Coded Squelch Both of these serve the same purpose: To isolate conversation. Be warned, however, some radios advertise these as "privacy tones." They have nothing to do with privacy. They do not "hide" your conversation in any way. For example: If you connect to a repeater using 462.725MHz (Channel 22. Repeater channel 22 is 467.725MHz), and the requested CTCSS is 141.3Hz, then anyone listening with that tone code will be able to hear you. Without it, they won't hear you at all. However, if you're listening, and you're not using a tone code, you will hear EVERYTHING (hence why tones have nothing to do with privacy). The CTCSS code ensures that only traffic using that transmit tone code will be heard on your radio. Anything else not using that code or using a different code your radio will ignore. While it's not necessary to have a receive code since you will hear everything, it's because that you'll hear everything that you may not know who's actually talking from that repeater, or who just happens to be using that frequency. That may end up causing confusion with conversations. TL;DR: If people aren't responding to you, it's probably because they can't hear you because of a missing CTCSS code for your radio. Double check with the repeater owner to see if a transmit CTCSS or DCS code is required. Do note that not all GMRS radios support repeaters or CTCSS/DCS codes. WSCL244/KF0QNM WRUU653, Paul357 and SteveShannon 2 1 Quote
SteveShannon Posted March 9 Report Posted March 9 27 minutes ago, Socalgmrs said: Yes this comes up a few times a week at least. Like clock work. Having this post here will be great for those that read and it’s full of good info but unfortunately most people don’t read. They just run to the net and start asking other people to solve a problem for them. If people did read they wouldn’t need a post like this. I do have to say I’ve never seen a gmrs radio that didn’t support tones and repeaters. FRS radios don’t support repeaters and still have tones. I’m seriously curious. Obviously you’re not here to ask for help, you inject negativity into the threads started by people who actually do help, and you make zero effort to get along with people socially. So, why are you here, Devin? Do you actually like the negative attention you receive? Is it somehow better than no attention at all? wrci350, gortex2, WRUU653 and 2 others 5 Quote
WRYZ926 Posted March 9 Report Posted March 9 3 minutes ago, SteveShannon said: I’m seriously curious. Obviously you’re not here to ask for help, you inject negativity into the threads started by people who actually do help, and you make zero effort to get along with people socially. So, why are you here, Devin? Do you actually like the negative attention you receive? Is it somehow better than no attention at all? He is like the toddler that acts badly to get attention from the parents that otherwise ignore the child. He has definitely earned the Negative Nancy nickname. WRUU653 and SteveShannon 2 Quote
WRTC928 Posted March 9 Report Posted March 9 27 minutes ago, WRYZ926 said: He is like the toddler that acts badly to get attention from the parents that otherwise ignore the child. He has definitely earned the Negative Nancy nickname. Yes, but people who behave politely get plenty of attention here, too. All you have to do is impart some useful information and you'll get kudos. Unlike the toddler, there are other ways to get that attention in this group. SteveShannon, WRUU653 and WRYZ926 3 Quote
WRUU653 Posted March 9 Report Posted March 9 32 minutes ago, SteveShannon said: I’m seriously curious. Obviously you’re not here to ask for help, you inject negativity into the threads started by people who actually do help, and you make zero effort to get along with people socially. So, why are you here, Devin? Do you actually like the negative attention you receive? Is it somehow better than no attention at all? He’s a one trick pony and he doesn’t seem to answer direct questions like this. 27 minutes ago, WRYZ926 said: He is like the toddler that acts badly to get attention from the parents that otherwise ignore the child. He has definitely earned the Negative Nancy nickname. I have started looking at his comments as if they were from a bot that only has one type of response… it’s just incapable of doing anything else. WRYZ926 and SteveShannon 2 Quote
WRYZ926 Posted March 9 Report Posted March 9 12 minutes ago, WRTC928 said: Yes, but people who behave politely get plenty of attention here, too. All you have to do is impart some useful information and you'll get kudos. Unlike the toddler, there are other ways to get that attention in this group. This is very true. But "some people" just can't behave or be polite. WRUU653, WRTC928 and SteveShannon 3 Quote
TDM827 Posted March 9 Report Posted March 9 I agree that most GMRS radios are repeater capable and support codes. But, while pretty rare, some GMRS handhelds are not repeater capable. So those new the GMRS world should at least confirm your possible purchases are repeater capable. As an example, my Midland GXT1000s handhelds are technically GMRS radios, but they are not repeater capable. I never viewed this as a negative as my use case includes FRS as well as GMRS. And I was in the market for some more FRS radios. In other words I knew what I was getting into and understood their limitations when I purchased them. But if I was new to GMRS and was leaning exclusively toward GMRS, I would have been disappointed if I was expecting to hit repeaters with those units. SteveShannon 1 Quote
Sonicgott Posted March 9 Author Report Posted March 9 Thanks to those of you who are leaving positive feedback. SteveShannon 1 Quote
WSHH887 Posted March 9 Report Posted March 9 Like I've said before I'm new, and I recently (re)discovered I had a pair of GXT100's I had bought for emergencies and never even turned on. I was wondering, is the reason things like the GXT1000 aren't repeater capable is because of their low wattage doesn't support duplex? If I'm correct you need duplex capability to use repeaters. Educae me if I'm on the wrong path. Quote
SteveShannon Posted March 9 Report Posted March 9 4 minutes ago, WSHH887 said: Like I've said before I'm new, and I recently (re)discovered I had a pair of GXT100's I had bought for emergencies and never even turned on. I was wondering, is the reason things like the GXT1000 aren't repeater capable is because of their low wattage doesn't support duplex? If I'm correct you need duplex capability to use repeaters. Educae me if I'm on the wrong path. Power has nothing to do with the ability to transmit and receive on different frequencies. That’s strictly programming. I don’t know why the GXT100s are incapable of transmitting and receiving on different frequencies. Quote
WSHH887 Posted March 9 Report Posted March 9 Ahh, the mystery deepens, even as the veil of ignorance is lifted. I've been involved in most of my hobbies for decades. I had forgotten that the path to knowledge takes a lot of effort and brain cells. Quote
TDM827 Posted March 9 Report Posted March 9 Midland heavily marketed the GPX1000 as GMRS / FRS radios. They have non-removable antennas and are not repeater capable. I suspect they want to attract customers who primarily are interested in using simplex GMRS, like on a family farm, with the ease, familiarity and ability to do FRS. They often sell these handhelds in combo packs with their micro-mobile units, which are fully repeater capable. Like I said, it must come down to marketing because they have been selling these combo packs for a long time and they seem to have attracted a large customer base. But hey what do I know, I am not a marketing pro. Quote
SteveShannon Posted March 10 Report Posted March 10 1 hour ago, TDM827 said: Midland heavily marketed the GPX1000 as GMRS / FRS radios. They have non-removable antennas and are not repeater capable. I suspect they want to attract customers who primarily are interested in using simplex GMRS, like on a family farm, with the ease, familiarity and ability to do FRS. They often sell these handhelds in combo packs with their micro-mobile units, which are fully repeater capable. Like I said, it must come down to marketing because they have been selling these combo packs for a long time and they seem to have attracted a large customer base. But hey what do I know, I am not a marketing pro. One of the changes to the regulations in 2017 was to prohibit the future certification of those combination GMRS/FRS radios. 95.1761 d) Effective December 27, 2017, the Commission will no longer issue a grant of equipment authorization for hand-held portable unit transmitter types under both this subpart (GMRS) and subpart B of this part (FRS). Quote
wrci350 Posted March 10 Report Posted March 10 I had a pair of GXT1000 radios back before the 2017 rule changes. They *were* GMRS/FRS 'combo' radios, and in the owner's manual it told you that you were only allowed to use it on channels 8-14 unless you had a GMRS license. As can be expected, 99.9% of owners either never read the manual or ignored that rule, and used them as high-power FRS radios. As part of the 2017 changes, all of those combo radios were reclassified as either FRS or GMRS, based on the power output. A lot of them are now FRS, but the GXT1000 is considered a GMRS radio BUT it is not repeater-capable, just as it wasn't back in 2015. Quote
TDM827 Posted March 10 Report Posted March 10 1 hour ago, SteveShannon said: One of the changes to the regulations in 2017 was to prohibit the future certification of those combination GMRS/FRS radios. 95.1761 d) Effective December 27, 2017, the Commission will no longer issue a grant of equipment authorization for hand-held portable unit transmitter types under both this subpart (GMRS) and subpart B of this part (FRS). Interesting. Kind of left scratching my head. Even the most up to date radio manual from Midland says you can use the GXP radio on channels 8-14. But goes on to say the radio will self regulate its power output on those channels to comply with FCC regulations, with no power adjustment possible. Which I believe would be 0.5W On the other hand the micro mobile does not even have these channels programmed in. So you truly cant utilize those channels. Quote
wrci350 Posted March 10 Report Posted March 10 2 minutes ago, TDM827 said: On the other hand the micro mobile does not even have these channels programmed in. So you truly cant utilize those channels. 8-14 are for HT (hand-held) use only. 467 MHz interstitial channels. Only hand-held portable units may transmit on these 7 channels. The channel center frequencies are: 467.5625, 467.5875, 467.6125, 467.6375, 467.6625, 467.6875, and 467.7125 MHz. Quote
TDM827 Posted March 10 Report Posted March 10 11 minutes ago, wrci350 said: I had a pair of GXT1000 radios back before the 2017 rule changes. They *were* GMRS/FRS 'combo' radios, and in the owner's manual it told you that you were only allowed to use it on channels 8-14 unless you had a GMRS license. As can be expected, 99.9% of owners either never read the manual or ignored that rule, and used them as high-power FRS radios. As part of the 2017 changes, all of those combo radios were reclassified as either FRS or GMRS, based on the power output. A lot of them are now FRS, but the GXT1000 is considered a GMRS radio BUT it is not repeater-capable, just as it wasn't back in 2015. Ok that brings a bit of clarity as my GXTs are pretty long in the tooth. Looking closer at the Midland website they definitely promote them as a GMRS radio these days. Quote
SteveShannon Posted March 10 Report Posted March 10 And 8-14 are limited to 0.5 watts erp for both GMRS and FRS. Quote
