I'm new to GMRS. I bought 2 Cobra Trailblazer 450 hand held radios, repeater capable. They were a little over 2 watts. I could hear people coming off the repeater but I was unable to get anyone to hear me. I am assuming the Cobra hand helds were not strong enough to get a signal to the repeater.
I am considering getting a BTech GMRS 50 watts. Do you have any advice on this? 50 watts should be able to reach the repeater wouldn't you think?
Thanks very much for any advice anyone has.
WSHJ646
Stanley
5 answers to this question
It kind of depends on your needs. I would say that a 10-watt radio will be sufficient for most situations, but if you're looking to cover greater distances, a 50-watt radio would be the best option. You don't necessarily need to spend a lot on a 50-watt radio; you can get a Baofeng GMRS version for around $20. It works well indoors or in a car, but using an outside antenna will improve its performance significantly.
  • 2
WSHJ646
Stanley
Hi Stanley,
Before you buy another radio, make sure you exhaust the possible solutions. There are at least three different technical possibilities for why people using the repeater didn’t acknowledge you:
1. You might have been on the wrong channel. Channels 15-22 are for talking directly to other radio users. On the Trailblazer 450 the repeater channels are named 15RP - 22RP.  You can hear repeaters on either group of channels but you can only transmit to a repeater on the repeater channels.
2. Nearly every repeater uses tones or digital signals to prevent accidental interruptions. The tones are called PL, or CTCSS, or something similar. Digital signals (codes) are called DCS or DPL. If you have no receive tones set you hear everything. If you have the wrong transmit tone or no transmit tone set, the repeater will automatically ignore you. Nobody will hear you in that case.
3. Finally, you mentioned power output. It’s possible your radio isn’t reaching the repeater. Try getting closer.
Welcome to the forum!
Thanks very much for the information guys. I may try to program them again and see if I get a better result. Glad you guys are out there and willing to share your knowledge!
WSHJ846
Stanley
WSHJ646
Stanley
I would say that two watts is probably sufficient if you are using a good repeater that is mounted on a tower. However, if the repeater is on a roof or in a location that isn’t on a tower, two watts may not be ideal unless you are within 0.5 miles of that repeater.
Before you think of buying a more powerful radio, consider all the advice you've been given here. Check all the things @SteveShannon suggested. If you're wanting to use it in a fixed location, @Socalgmrs is spot on about a good antenna and elevation. If you want to be mobile with it, the best you can do is a magnetic-mount antenna on the roof of your vehicle, but that will still be much better than the stock HT antenna. Even handheld, a better antenna can help. The stock antennas are usually mediocre at best.
Radio waves do funny things, but generally speaking, they travel in a straight line, meaning that if you can hear the repeater, it should be able to hear you...but there are some caveats. An RF signal may be completely blocked by intervening terrain, in which case you won't pick it up. However, it can sometimes be somewhat attenuated but not blocked. In that case, more power may be helpful, but it's possible to overdo it and spend too much money. For any practical purpose, each watt increase costs more than the watt before it, and that adds up pretty quickly. Power is a distant third behind topography and antenna in terms of improving your signal. It's been my experience that if I can't hit it with 15-20 watts, I can't hit it with 50 watts either. By this, you may infer that I spent the money for a 50 watt radio. I don't regret it because it was extra features I wanted it for, but for two identical radios, I wouldn't pay extra for anything above 20 watts. This is only my personal experience and others may disagree, but my advice is worth at least what you paid for it.
