WSHG225 Posted March 13 Report Posted March 13 Hi, I’ve heard it’s possible to have two (or more) repeaters on one channel, on the H8 can anyone offer some advice on how this is done? Quote
0 WSAM454 Posted March 13 Report Posted March 13 There can be more than one repeater on the same frequency. If they are near each other, with overlapping coverage areas, then they will usually each use different CTCSS tones to access them. If this is the case, then you would program your radio with the same frequencies on 2 different channels, but have your transmit set to use the correct tone frequency for each. If they do not use a tone on the output of the repeater, then, as mentioned in the above post, you will hear all traffic on either one. If they do use a tone on their output, then you would program than into your receive tone setting for each channel. That way you will only hear the traffic through the repeater on the channel you select. SteveShannon, WSDM599 and TrikeRadio 3 Quote
0 WSHG225 Posted March 13 Author Report Posted March 13 Ahah! Only if the repeaters already share the same frequency not two separate on different frequencies. Do I have it right? WRTC928 1 Quote
0 WSAM454 Posted March 13 Report Posted March 13 If by 'channel' you mean using the same frequency, then I think you have it. Quote
0 WSHG225 Posted March 14 Author Report Posted March 14 Got it now! Thanks! you saved me months of google searches TrikeRadio 1 Quote
WSHG225
4 answers to this question
