WRYZ926 Posted March 31 Report Posted March 31 Well every one that uses our GMRS repeater does use their actual GMRS call sign. They will use designators such as WRYZXXX Base, or WRYZXXX Unit 2, etc. And that has worked just fine for us. I would not want to try and remember a bunch of numbers either. And you still have to use your call signs when using open repeaters anyway. Now if the repeater is closed and ONLY used by immediate family then that's a different story. Correction. Call signs are still required even on private/closed repeaters. Though the repeater itself does not. WRUU653 and SteveShannon 2 Quote
SteveShannon Posted March 31 Report Posted March 31 30 minutes ago, WRYZ926 said: Now if the repeater is closed and ONLY used by immediate family then that's a different story. Not very much; every user is still required to use the proper call sign (even though all of them are using the same call sign), but in this situation the repeater is not required to ID separately. WRUU653 and WRYZ926 2 Quote
WRYZ926 Posted March 31 Report Posted March 31 1 hour ago, SteveShannon said: Not very much; every user is still required to use the proper call sign (even though all of them are using the same call sign), but in this situation the repeater is not required to ID separately. Thanks for the correction. Dealing with too much blood in the caffeine system today. SteveShannon 1 Quote
SteveShannon Posted March 31 Report Posted March 31 28 minutes ago, WRYZ926 said: Thanks for the correction. Dealing with too much blood in the caffeine system today. Ha! No problem. Sorry to be so OCD. WRYZ926 1 Quote
WRYZ926 Posted March 31 Report Posted March 31 12 minutes ago, SteveShannon said: Ha! No problem. Sorry to be so OCD. It's all good my friend SteveShannon 1 Quote
