I was setting up my UV-5G Plus radios with a matching set of frequencies for my GXT1000 radio's "extended" channel list, just gives us more options of pre-programmed 'coded' channels to match up with the Midland crowd.
I coded in all of the Midland channels 23-50 and tested them...only to discover that channel 50 is off channel. I tested all the channels between the UV-5G and the GXT and it did not work....so I set the UV to listen mode and lo and behold, the GXT is transmitting on 462.58625! That's not right it's 0.0125 below the GMRS Channel 2....ooops.
Anyone else with these radio's, and the ability to check, want to confirm that theirs does it too?
I won't bother with hassling Midland about it....I mean, I've never used channel 50, and am not likely too...but wanted to see if this was common. Kind of an odd one to let slip through!
WSEN940
13 answers to this question
