Kenwood TK-880 displays "TEST" when powered on
Trying to program 2 Kenwood TK-880s. Both radios read TEST on the display when i power them on. None of the buttons do anything other than beep. What exactly does this mean and how do i get out of test mode?
7 answers to this question
If my memory serves me right, you can change the message in the CPS.
Assuming you're using windows 10 or 11 you'll need KPG60D for your software, unless you're using an older OS. I have my 880-1 prog to directly to scan on power up.
I think not getting the programming cable to communicate is my problem. If i could connect i think all would be fine.
Are you using a Kenwood Kpg cable ? I use a spare Anytone programming cable, and it works fine.
Thanks for the tip on the Anytone cable. I am actually using a KPG cable.
The KPG-60D is for the 32-Bit computers and the KPG-49D is for the 64-Bit computers. The KPG-46P cable is for the Prolific driver and the KPG-46 cable has the FTDI chip in the cable for that driver.
When I get a used radio and program it, I will often put in a common frequency and label it as "TEST" instead of "Channel 1"  That way, when I have the radio on my tuning bench, I know the frequencies (and codes) that are in the radio, and I know it hasn't been programmed to a customer frequency.
I don't believe you are actually seeing a Test mode - ie: Something the radio is locked into. I believe you are seeing someone else's old programmed name for the first channel in the radios. Especially if the two radios talk to each other already.
A Kenwood radio should drop into a  "Program" message when you have the proper cable & software, and try to read or write the radio. Some of the older Kenwood software required you to run a regular Comm port (not USB) and the software only allowed a choice of Comm1  through Comm4 for serial ports.  Trying to use a newer computer with old software can lead to some issues.
