Wouxun KG-XS20-Plus & KG-935 Plus undocumented password features.
For both the Wounxun KG-XS20G Plus and KG-935G Plus factory programming software provides the ability to password the MODE key and password the RESET "ALL" function.
I didn't find any reference to this password functionality in my hardcopy manual or the latest PDF version so I played around with it see how it works.
Here's what I found:
Both passwords must be 6 digits.
Password digits can be any number between 0-9 with a password of all zeros a special case.
Entering 3 to 5 digits will cause the factory software to left justify the entered digits and pad the remainder with zeros.
A password of all zeros disables the feature. All zeros is the factory default.
Changing modes on the radio with  "Mode Switch Password" enabled:
1) Press the MODE button
2) Enter the 6 digit password
3) Press the MENU button
Do a RESET / ALL with "Reset Password" enabled:
1) Press the Menu button and using the up / down buttons select RESET function:
2) Press the Menu button again and using the up / down buttons select the reset type "ALL"
3) Press the Menu button again and enter the 6 digit password.
4) Press the MENU button.
Quirks:
Attempting to write a password of less than 3 digits to the radio will result in an programming software error.
Saving to file a config with only 1-2 character passwords entered and then reading that file back results in the 6 digits passwords being left justified and padded with zeros.
1 answer to this question
