WRXP246 joined the community
Premium members can run reports and download files that can be used offline.
SteveShannon reacted to a post in a topic: Baofeng and Baofeng Tech
I couldn’t quite find this topic in the forums so I started a new. My question here is I’m setting up a basic comms box (with a typical micro pc). My idea was to use the utilize this to view downloaded (if possible) repeater, location and information while away from cell service areas. I know it’s possible to save certain website data to view off-line but I’m curious if this is possible through mygmrs.com.
WRXH799 joined the community
Baofeng is indeed a place name (in fact, several) in China. Here's one: https://en.wikipedia.org/wiki/Baofeng_County (although that is 12 hours from the factory). Right around the factory (Changfu Industrial Zone, XIamei Town of Nan'an City, Quanzhou, Fujian province, China) there's also Baofeng Building Materials Hang, Baofeng Printing Shop, Baofeng Household Appliances and so forth. There's also a Dalian Baofeng Machinery Manufacturing Company elsewhere that makes large metal rollers. Here is the scoop on the Pofung business. I don't know what your BFF9 was. There is only one BF-F8HP Pro, it is only available from BTECH, and it went on sale in October, 2024: https://baofengtech.com/product/bf-f8hp-pro/
I tried hitting the repeater with both HTs again during the Sky-Watch net. It seems the Wouxun was able to reach the repeater, as I successfully checked in. The Baofeng, however, appears to be receiving some noise but doesn't seem able to transmit to the repeater. I tried switching the antennas, but that didn’t help. Both radios can communicate with each other on simplex just fine.
Baofeng? Or BTECH? Baofeng will private label anything for anybody, as long as they meet the minimum quantity. Baofeng also re-uses model numbers for similar or utterly different products, and many of their products have quite short production lifetimes. BTECH tries to have one product in each market segment, customized for them and available for a long time - you can still buy a UV-82HP from them if you really want one.
TerriKennedy reacted to a post in a topic: Baofeng and Baofeng Tech
They're compatible with the newer full-color screen UV5-family models. BTECH has a cigarette lighter battery eliminator available for purchase now, and I believe an official BTECH extended-capacity battery is coming. But anything from the full-color-screen UV5-family models should work, even if not from BTECH. [Again, not an official position of BTECH.]
Does anyone know if repeaters in the Roscommon/ Grayling area are linked to for instance Saginaw or Metro Detroit? A guy on Mackinac Island was able to come through on Mount Clemens or Detroit repeater recently and I'm curious what he was connected to. My brother is trying to figure out what repeater he might be able to use while in Roscommon.
Alex284 joined the community
WSEC330 reacted to an answer to a question: Duty Cycle Explained
Bummer, I believe I only have a mic jack in the back unlike a handhelds. Of course the manuals do nothing for me. Wondering if I just plug a mic cord between them or mic cord from 628/629....Hmm.
mb523 reacted to a post in a topic: GMRS HT with NOAA Weather Alert
SteveShannon reacted to a post in a topic: Just passed my General class test on Saturday!!!!
Radioddity DB40-G as repeater radios
SteveShannon replied to WSEC330's question in Technical Discussion
Yes, they need to be connected together. Surecom makes a couple of controllers (628 and 629) which might work. However, desense frequently occurs when trying to cobble together a repeater from two transceivers and you might want to run the transmitter at low power if you anticipate much use. -
Dyom joined the community
Repeaters are required to transmit the call sign at the end of a conversation and every 15 minutes while in use. Most don’t transmit their call every 15 minutes when not in use because that would be annoying to anyone who monitors the repeater. So, after a repeater has been on standby for awhile and someone tries it or kerchunks it, many repeaters will issue their call sign. As far as what inverse and normal means, DCS is a digital code rather than a tone like CTCSS. So it’s really a series of 1s and 0s. For instance 5 is normally 00000101. If you invert it, it’s 11111010. Often, DCS codes are expressed with either an N or an I as part of the code to denote whether it’s Normal or Inverted. If neither is included most of us assume N for Normal.
Hello gang. I've been playing with these a little while, enough to work them but new enough to venture neck deep. I am fooling around with building a repeater with two of these radios. I realize my connector and cable collect will expand. I have a 100W duplexer, two DB40-G radios in service (which will test my toy before purchasing more). I have an antennae which will work for this game. 1) Do they need to be connected together (mic wire, controller, etc...)? 2)Depending on the previous answer, what would be recommended? This is a fun project which is relatively low budget. Sorry that I have not added a clever sign off below but its coming.
AdmiralCochrane reacted to an answer to a question: Just one more antenna question
AdmiralCochrane reacted to an answer to a question: Antenna question?
AdmiralCochrane replied to WRPL700's topic in Amateur Radio (Ham)
The number of hams that I know that are also musicians is surprising to outsiders. There must be some kind of brain function that links the two. -
The Queen is never wrong. Once we thought (s)he was, but she was mistaken!
WSEC330 joined the community
Your loyalty will be remembered and rewarded when the day comes...
I was not trying to correct. I know nothing (can't even connect to a repeater without help). You are, "The Queen of GMRS". Love your content.
New Member Check-In
WSDV406 replied to SteveGibbs's topic in South Central Tennessee GMRS's Club Forum Page
Welcome, 874! Looking forward to catching ya on the air. Plenty of folks here to help you grow your knowledge. Don't hesitate to ask a question. Welcome to the GMRS family! -
Thanks for your help gents! I was able to hit the repeater last night on the Wouxun KGS-88G. I joined the repeaters weekly net to verify. The repeater's owner told me that the Baofeng radios have two separate lists of DCS codes, one is "inverted" (don't know what that means, yet) and the repeater uses the non-inverted code. I will test it out tonight on the local Skywatch net that uses the same repeater.
WSIW874 started following New Member Check-In
New Member Check-In
WSIW874 replied to SteveGibbs's topic in South Central Tennessee GMRS's Club Forum Page
Hello everyone, I'm WSIW874 Troy, I live in Lewisburg. I'm extremely new to GMRS. I've only had my license for a week or two. I have 3 baofeng uv-5r radios that I have only monitored some of the ham repeaters in my area. That's the extent of my radio knowledge. I'm very willing to learn more. -
I stand corrected and you are correct - I just realized the same thing with my KG-905G PLUS radio.. It seems there is some leeway in interpreting the FCCs rules on radios that do not have a full keypad.
I actually can transmit in FREQ mode on the Wouxun, not on the Baofeng.
No. It seems like these tones are just transmitted every 15 minutes. I just happened to coincide with my test.
WSHG887 joined the community
Coax size between repeater and duplexer
WRUE951 replied to Defender92's question in Technical Discussion
Those will work just fine. -
Um, yea, i was looking to see if those were still some of the better options out there or if there was anything better.
WSDM850 joined the community
I just wish there weren’t 40 varieties of radios from them. It gets hard to figure out what’s different about all of them and which ones are newer. They have a dizzying amount of models.
