WRUU653 reacted to a post in a topic: Marine VHF
WRUU653 reacted to a post in a topic: Antenna question.
Maybe YOU should read what you wrote. I never implied that 30Mhz and below would NOT reflect. I did say that about anything over 100 would NOT reflect off the ionosphere however. Which is basically what this post says. And is correct. You said that VHF maritime radio would reflect, you never mentioned HF marine radio. If you ever operated Sporadic-E you know that it opens for a few minutes at the longest and then fades. It's not a consistent method of communications. Yes, this is an exception to the normal rule that frequencies above 100 Mhz pass through the ionosphere. Just like there were 10 meter (29Mhz) downlinks on some ham satellites. Of course they worked better when the sun spot cycle was in a null and the MUF for DX never got above the 15 meter band.
You pronounce it your way, I'll pronounce it mine.
It's pronounced: reet-hard ..
WRZP254 joined the community
WSFM630 joined the community
I looked. Apparently I scanned over it. I looked on page 39 and didn't find what I needed. Stop being an arrogant azz.
AMAZING!!!! What a very small amount of literacy does. Manuals come with radios for a reason. They are also available on the internet webby thingy.
WSHZ660 joined the community
The only reason I don't run the 2x4 on my truck is that it doesn't like the very limited ground plane I get on the back of the bed. It works like a dream on the roof of my car, though. It's probably the most versatile multi-band antenna available. Mine even shows excellent SWRs in the 220 MHz band. A good SWR doesn't necessarily mean it will transmit well on that band -- the ability to transmit is dependent upon the electrical and physical characteristics of the radiating element -- but it does mean that if I try it, it's very unlikely to damage my radio. I likely will try it sometime just out of curiosity.
SteveShannon reacted to a post in a topic: Antenna question.
WRXB215 reacted to a post in a topic: Marine VHF
Moto387 joined the community
SteveShannon reacted to a post in a topic: KG-1000G plus VFO tuning
WSIG432 joined the community
Thanks guys! Great help.
Confirmed, it works. Thanks.
WRCH341 joined the community
GrouserPad reacted to an answer to a question: TD-H3 transmitting but not showing up on SWR meter
WSAG821 joined the community
WRQE754 joined the community
WSHI752 reacted to a post in a topic: Antenna question.
Yes the Comet 2x4SR will be an improvement if you want multi band use. You are correct that you would not have to change the mag mount to go from the MXT-26 to the 2x4SR. All you have to do is swap them out on your mag mount. I would run the 2x4SR on my Ford Escape all of the time if I didn't have height restrictions to deal with.
WRYZ926 reacted to a post in a topic: GMRS security risk.
While I like the ut72 and think it would work well for most people the mxt26 is a big step up. However the 2x4 is a much bigger step up. It doubled our tx and made our rx much more clear. Other then one old truck still running the 72 all our other trucks now run 2x4s. Even with 20w radios if we can see it we can hit it out over 100miles simplex in the clear and we get all the available weather stations and murs comes in RX perfect as well.
Alright, so I have a Retevis RA25 mounted in my Xterra. Right now I'm using an NMO mag mount MXT-A26 antenna. It works great for GMRS. I used to have the Nagoya UT-72G mag mount hooked up to a TD-H3. I seemed to be able to get a lot more reception on that set up, using both GMRS and HAM. With the UT-72G, I was able to get NOAA channel 5 in super clear, plus I think channels 4,3, and 1 a little bit. With the MXT-A26, I can only get NOAA channel 5, from the same spot. I know the MXT-A26 is tuned specifically for GMRS. My question is, should I get the Comet 2x4SRNMO antenna? I would like to be able to just screw it into the NMO mount and not switch out the whole thing. I'm not HAM licensed yet, but I like to listen. And also I would like to have it in case of emergency. Plus I probably will eventually get my HAM license.
WSHM374 joined the community
Davichko5650 reacted to a post in a topic: Programming Retevis RA87 with software
This is why it's good to have Socal around. Eventually he get's a NOOB that deserves it.
LeoG replied to hxpx's question in Technical Discussion
Gotta be the battery BMS because you use standard USB wall wart chargers. The battery itself shouldn't allow the charger to cause it harm. -
hxpx replied to hxpx's question in Technical Discussion
Same issue here - I programmed one radio, did a wireless copy to the rest, and at least two batteries were charged in the charging stand while attached to a radio. So all four have the same setup, two were charged while attached and turned on, and no idea which one the dead one was because they all look the same and I wasn't smart enough to number them beforehand. They do seem to be aware of the battery charging issue - at the bottom of the "we're shipping you a new radio" email, they added this at the bottom: -
GrouserPad replied to hxpx's question in Technical Discussion
I’m not sure. It’s not my problem. I did nothing to them that should have made them fail. The very first tdh3 I bought still works today and it was programmed abd used identically as the other 4. And none of these were DOA. All worked out of the box. Then approx 2 to 3 weeks later I noticed issues hitting repeaters and at that point realize no output. So not sure when these failed after charging or after programming. -
TBH, I'm not sure. It has that dull sheen like aluminum, but that could just be the finish. I don't have a magnet handy, but a lot of stainless steel isn't very magnetic anyway. I think the whole "dissimilar metals" things is a bit overblown anyway. Cars and motorcycles bolt aluminum to steel all the time. If it were a part that carries a current, it might be different, but I've seen lots of aluminum wire secured to an outlet with steel screws for decades without any issue, so maybe not even then.
I'll recheck it when I have the antenna stood up. I hung it a few feet off the ground for the initial test. I wanted to be sure there wasn't anything to address before I got it 40' in the air.
Anyone know where to find a Kenwood TK-890H?
Lscott replied to WSHF732's question in Technical Discussion
Have you considered the TK-8180H model? You’re limited to 50 watts anyway on GMRS. https://www.kenwood.com/usa/Support/pdf/TK-7180_8180.pdf -
SteveShannon replied to hxpx's question in Technical Discussion
How many were DOA and how many died after being programmed? I’m not saying you made a mistake; I’m simply mildly curious about the sequence of events. -
I think you found the motherlode of the bad batch. This is what happens with mass produced stuff. If you get a problem it's not one or two, it's hundreds or thousands if they don't catch it. Apparently I've been luckier than you with 2 out of 14 being non transmit. -
I have been scratching my head over this for a long time now. I understand being cautious about the security of your home, but do you all (those that have this issue with the address on the FCC database) live in an extremely high crime neighborhood? Are you all filthy rich, prominent, and in the newspapers front and center? I have had a Ham license starting off in 1996 with several different addresses over the years and now have GMRS and Ham with my address on there. I know hundreds of Hams out there that have their address on their license and don't know of anyone who has been harmed or robbed. Could it happen? Absolutely. But ask the many radio operators out there. How many have had their house broken into and been robbed or half beaten to death? I think the key thing is to NOT display your equipment online in either a list or pictures. Even then, who is coming to steal it? Probably only another radio operator. I remember when I got one of my licenses recently, someone sent me a message warning me that my address was online. Yep, it was, just like it had always been. And if people did further searching, you would find that a hundred other sites had my address and probably every address I ever lived at, including every phone number I have ever had. The FCC website is the least of your worries. Try fast people search, been verified, and hundreds of other data mining sites that collect every bit of information on you, place it in a blender, and whip up a mess of info on you that can sometimes make you look really sketchy. Unless you paid a lot of money to the right people to have all of your information scrubbed from the internet, something about you or related to your address is going to pop up. To want to give up on having a radio because you think that someone is going to break into your house just because the FCC has your address up for all to see, is crazy. Best bet is to get a P.O. Box so that your address wont pop up. The issue is that other websites will still have your address. If you own your own home and I find your name on the FCC website, I can then take that name and then enter into the tax assessors database for your town and find your address that way. Too much is public knowledge these days. It is almost impossible to hide. My thought is that criminals looking to steal to make a quick buck are going to break into your house just because. I highly doubt they will get sophisticated enough to monitor radio traffic to see when you are not around. The best thing is to maybe get cameras installed on your house. Put up signs stating that the property is monitored by camera surveillance.
A couple!?! Bruh I’m 4 out of 5 failure on these pos. -
OK, I'll give that a shot. Glad you didn't have to walk all that way Randy And there it is. Hard to believe after pressing those buttons randomly that it never showed itself. So there is a trick.
No, it's not a trick. According to page 40 of the user manual, after switching to VFO mode by pressing the 6/Mode button, then press the 2/Mhz button to direct-enter your frequency. ...and, i just confirmed this works with the KG-1000G+ in my office right next to me... I was going to try it on my Bathroom KG-1000G+, but that's all the way down the hall.
^ Good to know. Thanks.
