I’m sorry, I don’t know where Clay Co. is in Alabama, but there are 82 repeaters listed in Alabama including some that might no longer be operating. If you click on Repeaters on the menu above, you can find the ones closest to you or you can click on Map and see what’s on the map closest to you. I’ll put the links below: Repeaters: https://mygmrs.com/repeaters Map: https://mygmrs.com/map/
WSIM668 joined the community
Funline created a club: H.O.T GMRS
Funline joined the community
WRUU653 reacted to a post in a topic: GMRS license covers my family? And etiquette for family chat?
WSHR411 joined the community
SteveShannon reacted to a post in a topic: GMRS license covers my family? And etiquette for family chat?
SteveShannon reacted to an answer to a question: Connecting radio to headset for listen only
WRUU653 replied to HamsterDancer's question in Technical Discussion
There are some Bluetooth dongles that will plug into the Kenwood style Jack as well out there. I don’t have any firsthand experience with any of them myself to make a recommendation though. -
WRUU653 reacted to an answer to a question: Connecting radio to headset for listen only
Back to you Bill aka @HamsterDancer, you may also give the family FRS radios if you like and you can use these along with your GMRS radio. No need for call signs using FRS radios. Quite frankly unless you’re using a repeater no one would know either way, however your effort to do things correctly is admirable.. Cheers
WSFC691 joined the community
amaff started following GMRS license covers my family? And etiquette for family chat?
amaff replied to HamsterDancer's topic in FCC Rules Discussion
You wouldn't happen to be in SoCal, would you? Oh wait, sorry, let me write it in a way you'd understand: You Wouldn't Happen To Be In SoCal, Would You? -
amaff reacted to a post in a topic: GMRS license covers my family? And etiquette for family chat?
WRTT645 joined the community
amaff reacted to an answer to a question: Connecting radio to headset for listen only
KerrySnider joined the community
I am considering getting a GMRS radio system to connect with friends and family is the Clay County,AL area. It is quite mountainous and wooded so I would like to know if there is a repeater in this area that I could join.
Dizzycowboy joined the community
Remind me again: what DMR radio are you wanting to learn to program?
TNWEB replied to HamsterDancer's question in Technical Discussion
2.5mm or 3.5mm audio cables or adapters are readily available at many online retailers. -
WSBA407 joined the community
WSHL963 joined the community
WSJQ333 joined the community
I have a couple of Motorola DMR radios with several DMR repeated and simplex channels programmed and not one of the have any HAM channels programmed in them. One main reason why I don't is because I am not a licensed HAM and I don't care to be a HAM.
You can start by looking through the attached file. Amateur Radio Guide to DMR.pdf
What's the best way to learn DMR? This question from some holding a GMRS license only. Randy, you have a channel?
Sorry I missed this, but UncleYoda gave you the right answer. Every person should ID every 15 minutes and at the end of the conversation. Because you are all using the same ID a unit number or name is frequently also used. But to be honest most people just use their names and most people don’t care too much.
CONGRATS on getting your Tech license.
You can give them GMRS approved (certified) radios. (Not HAM radios.) yes (any of the pre-programmed channels) They will need to identify with your call sign (at the end of each conversation, and every 15 mins if longer than that). You can give each one an optional unit number or nickname to tell them apart but the official ID is still required.
Need help contacting a repeater with a Midland 115 mobile radio
WRUQ683 replied to WRUQ683's question in Technical Discussion
I know about the normal and inverted codes. But there is no option for that on the Midland radio. I opened a help ticket with Midland but of course it will be nexr week before anyone will get back to me. -
I took a drive around the block. No luck. I can easily Tx from the HT to the mobile on the repeater channel but not the other way round. I haven't touched the squelch but I'll look at that next. -
I took a drive around the block. No luck. I can easily Tx from the HT to the mobile on the repeater channel but not the other way round. -
hxpx replied to HamsterDancer's topic in FCC Rules Discussion
If God the FCC gave us 50 watt channels, I'm gonna use all 50 watts. Edit: Theoretically. All I have are a bunch of 5W handhelds. But I would if I could!
