I've sent them back and I'm going to try the UV-17r Pro GPS. CHIRP does support it. -
Password for Baofeng UV-5RM Pro GPS Software.
A guy on YouTube did a different radio with similar software and it wasn't anything he input, it was some preset codes. All that aside, the radio wouldn't work with the software for programming so I've returned them and I'm going to give the UV-17r Pro GPS radio a try. It's CHIRP compatible. -
This is the kind of detailed real world data that's useful.
Lscott reacted to a post in a topic: SGQ-450D Duplexer - Tune-up and Review
OffRoaderX reacted to a post in a topic: Antenna Height Secret
That’s only true if the only people who use it are operating under the owners license. If any other license holders use it then it must identify. Obviously that’s not the case here because MrSig has asked if others can check and see if they can access his repeater. But I don’t understand why anyone would go to the expense to add a Repeater ID to their repeater but not have it actually ID their repeater.
I Would Have To Disagree. Think His Story Has A Crack In It..........
BrynoDawgFoo joined the community
SteveShannon reacted to a post in a topic: Simplex Linking vs. Repeater Linking
Okay folks... Leo sent me a new SGQ-450D duplexer. We gave this one a tune-up and it's looking good. I am very impressed. First, I swept it while it was factory tuned. It looked really good and if it was mine, I probably would have left it alone. On the transmit side, we had a good notch removing the receive frequency at almost -80dB. On the receive side, the notch looked even better at -85dB. Leo asked me to see what I could squeeze out of it, and I have to say, I am impressed with how well it tuned. On the receive side, we got the transmit frequency notch out -95.5dB. On the transmit side, I was able to notch out the receive frequency -95.5dB. Very well balanced. I recorded a quick video of the sweep showing notching as deep as -100.2dB, which is fantastic. The video demos the benefit of a hi-res VNA (mine goes to 1024 points), the sweep results, and the SWR at power. On the receive side, I was at 35 watts, but when I switched frequency to demo the transmit side, I forget to turn the power down. That SWR reading was at 50 watts, even though I said 35 watts. I really hope this helps someone on the fence about buying a B-Tech repeater or the SGQ-450D duplexer. @LeoG, can you share your opinion on the real-world results?
kirk5056 reacted to an answer to a question: Repeater connection problem!!!
kirk5056 reacted to a post in a topic: Antenna Height Secret
plug in the coordinates on Google Earth and check in Street View. (no all are available)
LeoG started following RepeaterID Universal Test
If it's a private repeater you don't need it.
WSGH438 joined the community
Raybestos reacted to a post in a topic: Simplex Linking vs. Repeater Linking
Gotcha. Thanks for clarifying.
Yup,, much different breaking a law, vs. a 'rule'
WSJCRaleigh joined the community
The butt-prints smell fresh so your story checks out.
It's okay, man. I already know where you live. I sat on you front porch naked for two hours this morning before sunrise. If you don't believe me, check out the crusty butt prints near the top step.
WSGC788 joined the community
And for follow up. I created two .csv files for anyone who wants to do the radio check I laid out. I have both the UV 5G plus and a TD-H3 so I built a test code plug that you can load into chirp to use. Obviously as they are the CSV files, you can use them for any radio as I note you have the TDH8. Set the UV5G to have channel 1 on the top line and channel 2 on the bottom line. Transmit on the TD and you should see the top line receive work. A/B the UV5G to the bottom line and transmit. The TD should then light up. If this works...the radio is fine. As noted elsewhere. You do not need the tone squelch on receive for a repeater, you just need it's input or TONE frequency. I did this test with the Tone Squelch enabled. repeater check td.csv repeater check uv.csv
SteveShannon replied to marino389's topic in FCC Rules Discussion
Actually, no, the rule is that GMRS communications may not be placed onto a network. That extrapolated into not linking repeaters. -
As @Jaay already mentioned above... a topo map can give you the elevation if you know the location or general location. If you know something about the locaiton and the repeater is on a mountain top or something (as apposed to a building or tower) you can use this line of sight tool to see where you would get good line on a repeater. https://www.scadacore.com/tools/rf-path/rf-line-of-sight/ But yeah, like some have already said, if they don't tell you the elevation or don't want to... there is no reason they have to.
I know that FCC clarified that you can't link repeaters. But what about a simplex node with AllStar? Is that ambiguous?
I posted on another thread about how to test your radio for this exact scenario. link below. As you have two radio's you can do a very simple test to make sure that you are able to transmit/receive correctly. This is a good way to get to know the radios and the software and have a controlled test bed to work from. In effect, you are independently checking the two halves of the repeater equation. Now, if this test passes, then you can bet your bottom dollar that the tone for the repeater is wrong, or, you are just not reaching it. Although the latter, in your case is not the issue if your sitting so close you can feel the radio waves (joking of course) Radio Check for Repeaters
PRadio replied to WSAA635's question in Technical Discussion
Maybe try to set a password via the radio setup menu, then hook it up to the programming software. Then use the password you created on the radio. 7.3.7 Power-on Password Allows the radio to set a power-on password to protect device security and settings. Press >> Radio Settings >> Password. Prompts “Input password”. Enter 1-8 digits (0-9), ******** will be displayed. Press the # key to display your entry. Press the key to save and return to the previous menu. To cancel the power-on password Press the key >> Radio Settings >> Password. Prompts “Input password ********”. Press the key to delete until all are deleted. Press to save and return to the previous menu. When the power-on password feature is enabled, the radio will prompt “Input Password” when turning on the radio, and only after entering the correct password will the radio turn on properly. The power-on password can be read and modified by CPS software. -
WSFM218 changed their profile photo
I dont publish the actual/*exact* elevation of my repeater antenna because its connected to my house and knowing its exact elevation would make it easier for all the mentally-ill people that send me threats to locate it.
Interfering with police/emergency communications violates criminal law and is a police matter, very unlike violating FCC Rules.
WRTC928 replied to WSAA635's question in Technical Discussion
Last week I bought a Baofeng AR-152 Pro GPS. I wasn't surprised that it isn't supported by CHIRP, but I was surprised that there's no factory CPS either. Maybe that's because it's allegedly programmable via Bluetooth, but I haven't experimented with that yet. i have input a few channels manually, and overall, I like the features, so I won't be sending it back, but it's probably going on a shelf until there's a more efficient way to program it available. I'd be interested to know if other people are having your problem because I was considering the 5RH Pro GPS. I downloaded the 5RHPG program and tried it with the 152PG because the features are similar, but it wouldn't read my radio. Now I wonder if it's an issue of quirky software instead of radio incompatibility. -
Except that they dont.
I'm pretty sure most states have laws pertaining to interference with emergency services operations. The local police can slap that stuff down pretty quickly. A hefty fine and a realistic threat of jail time can serve to modify one's behavior.
