  1. Today
  2. I saw a lot of discussion on challenges loading airband channels and I thought I'd mention that there's some pre-programmed related frequencies in CHIRP. Go to File > Open Stock Config > US Aviation Frequencies.csv. Not sure if that helps anyone but thought I'd mention. They also have GMRS/FRS, Marine, etc. under there.
  3. I have a few small gripes with this radio but, for the money, I think the AR-5RM is simply awesome. Dislike the red font on menu settings - hard to see. No memory banks for 999 channels? Oh well. I have my ham and gmrs license and have friends using both. Being able to use either in the same radio is super key to me; I used to seek out older Baofengs for this reason. That capability alone (and being tri-band) has earned it a place in my emergency bag (GHB,BOB), as well as my "shack", for sure. Thrilled with it over all.
  4. Just a suggestion, instead of wasting money and time buying substandard coax and finding out it's not making you happy, just buy some 1/2" Heliax and save money and time. UHF isn't forgiving when it comes to feedline.
  5. Just a suggestion, instead of wasting money and time buying substandard coax and finding out it's not making you happy, just buy some 1/2" Heliax and save money and time. UHF isn't forgiving when it comes to feedline.
  6. Yesterday
  7. Two very important tips to always remember.
  8. I'm glad to hear that you redid the connections and that improved things for you. While ABR makes excellent coax cables, their ABR240-UF is pretty much the same as RG-213. Line Loss per 100 Feet RG-213 - 5.28dB, 70% loss LMR240 (same as ABR240) - 5.40dB, 72% loss LMR400 - 2.87dB, 48% loss RG-58 - 9.16dB, 88% loss Again, The calculations were made using 50 watts in and an SWR of 1.5. I used the https://kv5r.com/ham-radio/coax-loss-calculator/ to get those numbers. Your numbers will be different depending on the actual gain of your antenna. Higher loss cable will actually show a lower SWR due to loss. Go with the best that you can afford along with the acceptable losses for your needs. I would go with the DX Engineering 400MAX or R&L Electronics Jetstream 400Flex before going with RG-213/ABR240/LMR240. ABR coax is good stuff and I use their cables for all of my portable/POTA setups. Check out the coax loss calculator I linked. It is very helpful.
  9. Tell this to the other person: Press the button... THEN talk.... This fixes the problem 99.998% of the time.. The other 0.002% the problem is because the person did not listen to what you told them to do.
  10. 40YEARS!!!! Orrrr…. you could just turn off that function. I guarantee you it’s horrible annoying for every one else. It’s like a backwards roger beep. Plus a call sign at every transmission. I’d just turn off the radio if I had to hear that. 40 YEARS!!!!!
  11. I just got my RepeaterID for the RT97L and they even emailed me the file I wanted for it for free. https://www.repeaterid.com/store/p16/RepeaterID_RT97L.html# I got it in 3 days and very easy to use. It works great!
  12. My TYT DMR radio has a function that you have to key it and wait till it chirps a bit before you talk and I often mess up talking too soon! Darn new technology! I’ve been using radios for over 40 years so trying to learn a new way kinda sucks. My cure is to use my call sign first calling the other person. Better I mess up my call sign than missing who I’m calling…
  13. UPDATE ! I decided to redo the connections I pre iously made,this time making sure to crimp the collars as best as I could,and taking care to fill the pin with as much solder as possible. While a continuity check yielded the same .002 my SWR has now dropped to 1.43. Not perfect but for this RG 58 I don't think it will get any better. I am looking as some custom cables fromABR industries. Their ABR 240-UF. I do appreciate everyone's input and help.
  14. I'll give you TWO tips! always back-up your channel set before doing a factory reset dont run with scissors
  15. Had to do a factory reset now the channel set under settings is gone. Any tips?
  16. Nahh get that antenna outside above the roofline and you’ll still gain ALOT of performance no matter what your topography is !!
  17. Here's my experience with the subject. I'm a fan of DCS for all the reasons listed above. However, I have found that some radios take a slightly longer time to open with DCS than CTCSS. Not a problem for us "radio people", but I have a group of radios that I use with a local theater. Sometimes the users push and talk at the same time and the first syllable would be missed using DCS. I reprogrammed the radios for CTCSS and that solved the problem. Again, this might be a brand/model specific issue but something to take into consideration.
  18. Man I feel like the tdh3 IS a nice radio that would hang with radios 4x its price if the transmitter section wouldn’t crap the bed. Everything about the tdh3 is freaking awesome. But what’s the point of having a fully featured radio if this POS doesn’t transmit.
  19. As mentioned, nothing will protect against a direct lightning strike. That being said, it is till a good idea to have lightning protection for the near strikes. Plus lightning arrestors will also help prevent damage from static electricity buildup on antennas when everything is properly grounded per NEC codes.
  20. And the typical lightning strike is 30,000 amps. And the recommended wire gauge is #8. That should last a few milliseconds.
  21. Also, if you go to Makers World you find a 3D cradle file for practically every radio free for downloading. True that not everyone owns a 3D printer but as cheap as they are now days, they should.
  22. back in early 80's a Microwave site i maintained at Bird Springs took a direct hit on the overhead power power transformer. This site was well fortified with grounding.. Six charcoal/salt canisters and a ground web tied to each one.. The hit took pretty much everything in the block building and did some pretty good damage to the power panel. I remember walking into the building, it smelled like an electronic frying pan. The grounding system served zero purpose and won't on direct hits.
  23. i think you wold be amazed at the number of repeaters someone sets up whom actually do not operate repeaters but do it because 'they can' This site is not a formal process. Anyone can set up a repeater here, even a Cave Man can do it.... Once someone set's up a repeater here, it's the responcibgly of that individual to maintain its status, not the site owner. If that person whom set it up died, moved on, or got bored and not having fun playing around,, oh well. it is what it is.
  24. Hi everyone! Recently I created a 3D printed Tabletop Cradle Mount for the OpenSPOT 3, 4, 4 Pro. Not everyone has access to a 3D printer, but I'm trying to make it as accessible as I can. I've placed the Cradle Mount on Etsy with a significant price discount, and free shipping! Price: $12.96 USD Shipping: Free Warranty: 1 year warranty with free shipping of replacement if the mount does not fit as desired, or breaks due to natural use. The openSPOT fits snugly into the mount by way of a friction device at the bottom, keeping it from moving loosely while standing upright. This cradle mount is ideal for ham radio enthusiasts who want a stable place to secure their device, while having the option to charge the device while in its mount. It stands upright, allowing for ease of use, while being able to monitor the LED display at the bottom of the device. It is customizeable with your CALL SIGN, up to eight characters! WHITE primary color, with BLUE call sign color, which makes the mount look FANTASTIC! We have customizable colors, so please inquire if you have a specific request. This design was created by That Medic Andrew, as seen on TikTok and MakerWorld, using 3D printers by Bambulab and FlashForge. Please let me know if you have any questions or suggestions. I'm always looking for new ideas and quality input to improve my designs for those of us in the hobby. https://www.etsy.com/listing/4298063353/ 73 all, Andrew, N2AL / WRTD229
  25. I am with the original poster. As a repeater owner, part of it is either listing the repeater as open and shutting off the requests, or checking the requests. The system does email repeater owners at their registered email address when a request comes in. So it's not like they aren't seeing it. If they have the function enabled for requests, then it would seem they want the requests. So they need to answer them in a timely manner. If they want the repeater listed but be private, to help eliminate interference, then it needs to be listed as such. But putting a repeater up, listing it on the site and then not bothering to answer requests is crap. If you don't have the time to do it, turn off the function or remove the listing. It's not rocket science. I understand that it cuts into your time. I had mine listed with requests for a while and after answering 200 something requests, I set the request function to off. It clearly states that requests are NOT needed and the PL for the repeater is accessible for any member of this board. It is open to all licensed GMRS users.
  26. If I can catch the storm I disconnect the coax from the radio and put a shot glass over the connector. Plus it's lightning. It jumped from the cloud to the ground. It's going to do what it wants. A good grounded system will definitely help guide it to the ground but there is never a guarantee. It might find another path it likes better no matter how short the ground is through the wire. It's just as unpredictable as most of nature is.
