Ah, thanks! So that means my first Tx hit the repeater and it responded with its call-sign in Morse-code. The Baofeng also received the call-sign, but it is not receiving the Tx from the Wouxun KGS-88G. Nor does the Wouxun receive transmission from the Baofeng. All is well in simplex land.
tcp2525 replied to WRTC928's question in Technical Discussion
Yawn, looks like you got me, Einstein! I would never directly ground a radio with 500 MCM as it's best to feed your primary bonding plate with 500 MCM and then, yes then, reduce to a home run of 250 MCM to each fixed equipment rack. https://www.gordonelectricsupply.com/p/Harger-223T-Tin-Flange-Bonding-Plate/6096051 But, we ground each of our Baofeng handhelds with 4/0 THHN for maximum flexibility. - Today
WRKC935 replied to WRTC928's question in Technical Discussion
Again, where are you placing the surge suppressor's? They typically are inside the structure, either directly mounted to or wired to a ground bar located right at the entry point. Surge suppressors are a serviceable item, so they need to be exposed to be replaced after they fire and short. Not wrapped in putty and tape outside. Where do you come up with this crap? -
Even though this is about as far from the truth as I can imagine, I am gonna give you to benefit of the doubt to explain this, WITH links to real documentation proving what you are saying is true. Even if I know it's BS and in truth NOT EVEN possible. I mean seriously, just give me a part number for the Burndy lug that's a single .25 (1/4 inch) hole that I can connect to an MTR repeater ground screw. Let along the one for a 10-32 screw hole that would be on a radio. Never mind getting the 500 bent into shape to connect to the radio. I have to see this. Do you have pictures? Are you using the 500 cable as the method to mount the radios on a desk? -
BoxCar reacted to a post in a topic: Happy Independence Day
BoxCar reacted to a post in a topic: Baofeng and Baofeng Tech
SteveShannon reacted to an answer to a question: CHIRP Programming Issue – Tone Squelch & Duplex Changing After Save (KG-935G Plus)
SteveShannon reacted to an answer to a question: Help with KG-935G Plus Programming & Repeater Setup – Debug Assertion Failed Error
blbass409 joined the community
WRTB851 joined the community
WSEZ969 reacted to a post in a topic: What's missing from myGMRS.com?
Its easiest to start with the pre-programmed channels so you can see what they look like in CHIRP.. Once you figure that out you can then create your own new, custom channels. Re Tone or TSql, i believe @SteveShannon already answered that question in your other post, and because he is an officially-recognized HERD, you should listen to what he says.
WRHS218 reacted to an answer to a question: Help with KG-935G Plus Programming & Repeater Setup – Debug Assertion Failed Error
And you are doing exactly what is expected when considering buying a disposable radio. No shame in buying a Midland if it makes you feel good and it gets the job done.
No assumption, people buy cheap tools from Harbor Freight with the intention of using it once to get a certain job done and throw it in the storage bin when done with the intention of possibly using it in the future. They generally forget about it and it gets tossed in the trash accidentally or intentionally. The same concept applies to these disposable or throwaway radios we buy. Case in point, I bought a Baofeng UV82 10+ years back for under $50 with the intention that it is a sacrificial radio, or disposable as we like to call them. The damn thing far exceeded my expectations of performance and survivability of abuse and is still in use today and doesn't YET warrant going into the scrap bucket. As for Midland, these radios are generally mistakenly purchased solely by name recognition or not taking the time to fully researching prior to purchasing. People see the flashy ads on the seller's site and go for it. Sadly, the majority of Midland purchasers learn the hard way that they made a costly mistake and finally wise up and never buy another Midland product again. In Midland's defense, their marketing is strong enough to bring in enough one-time customers to survive. A moth going back to the flame a second time is delusional.
How many fars on the Maljamar, NM repeater?
SteveShannon replied to WSFE293's question in Technical Discussion
The output power isn’t meaningless, but it has much less of an effect than the antenna height and gain. A 20 watt radio can easily transmit 100 miles if there are no obstructions, but obstructions are common. A fifty watt radio cannot overcome obstructions, but it can power its way through vegetation which might attenuate the signal of a less powerful radio until it cannot be detected. There are lots of threads which discuss which antennas work well and how and where to mount them. And attenuation affects signals in both directions. So, more important than the output power is the cable, the antenna gain, the antenna mounting position, and the antenna height. Personally I use a db20g radio with a Midland MXTA26 antenna on the center of my steel roof using a magnetic mount from Midland. -
OffRoaderX replied to WSFE293's question in Technical Discussion
You spelt farz wrong. -
I know, another newbie question about fars...but I'm looking for some input from others with a some experience. I was playing around on the repeater map and found the Maljamar, NM repeater says estimated range of 100 miles. What equipment would be needed on a mobile car setup to get to the repeater from 100 miles away? Would a 25W radio be enough power or would a 50W radio be needed? What about an antenna with gain? I realize that this probably depends on many things but hoping to hear about if this is realistically possible. I looked at the RF Line of Sight website and assumed the repeater is 100m high (no idea if this is accurate) and it says there is clear line of sight to Carlsbad and Roswell. Has anyone here used this repeater before? The reason I'm asking is because I'm looking into getting a mobile setup but just haven't pulled the trigger yet. The posting from a few weeks about about mobile setup is really useful. Thanks, hope you all have a good Fourth of July.
I already have been thinking about that problem for my (likely) purchase of the T75 units…and my plan is blaze orange duck tape, or a tag, or something, to help with that exact problem in my very dense woods. In the same vein, I love the idea of camo Rite in the Rain pads…but during hunting season I switched to the blaze orange of those too after I almost lost one of those this fall lol. Funny thing (and I whole-heartedly agree with @SteveShannon here!), I actually have a pair of cheap lightly water-resistant baofengs I intend to use while sailing on a local lake to talk back to shore…because they’re cheap enough I almost consider them disposable! If I drown it, oh well, $10 lost and move on. The reason is, the GOOD waterproof units are out of price range for me, so a waterproof box I already had and cheap HT meet my use case there, and good high quality middle-priced Midlands should the rest of the time when I need better features that aren’t necessary on the water. Back to the point if this thread though, again, for wx alert features, if that’s your main goal, and you want something to rely your safety on, personally I recommend spending more $$$ there (Midland or otherwise) if you know you’ll get a more reliable product. Knowing if its reliable is up to the many interpretations that I’m sure will be weighing in below (), but in general that’s my $0.02 worth
If you set the mode to “Tone”, the Tone Squelch frequency setting becomes meaningless. Tone mode means your radio doesn’t (or isn’t supposed to) filter on receive. Tone mode is the same as having no receiver tone. If you want the Tone Squelch setting to be effective you must set mode to TSQL. As far as the random offset frequency, when you transmit are you on 467.725 MHz? If so, the offset doesn’t matter. The best way to ensure your radio works with the repeater is to get on the air and test it. The issues above may be things that the chirp developers would explain better than I can.
Hello everyone, I’m running into a consistent programming issue with my Wouxun KG-935G Plus using CHIRP. Here’s what’s happening: I program my repeater channels with: Correct RX frequency (e.g. 462.xxx MHz) Tone Mode: Tone Tone and Tone Squelch matching (e.g. both 131.8 Hz) Duplex set to “+” for standard GMRS repeater +5 MHz offset Problem: After saving and reopening the file: Tone Squelch reverts to 88.5 Hz on all channels, even though I set a different CTCSS. Duplex changes to “split” and TX Offset shows random frequencies like 930.1 MHz, instead of standard +5 MHz. I’ve tried: Re-entering and saving multiple times Clicking another field to lock before saving Using the latest CHIRP daily build (if compatible) Confirming the radio model and cable are correct Question: Has anyone else experienced this issue with the KG-935G Plus or similar models in CHIRP? Is there a known fix or workaround to retain Tone Squelch and Duplex settings correctly? I want to ensure my repeater channels are reliable for daily and emergency comms. Any insights would be appreciated. Thank you in advance.
IIRC something like this will occur if you are using the 935G software instead of the software specifically for the 935G PLUS radio.. are you sure you are using the Plus version of the software and not the regular 935G software? You can download it here: https://www.buytwowayradios.com/downloads/dl/file/id/1572/product/5920/wouxun_kg_935g_plus_programming_software.zip If you are already using the correct software then my only other response is "this sounds like a Windows issue".
Remember that I personally work in the commercial two-way field. Ham's and GMRS folks have the ability to disconnect their gear. Police and fire don't. And again, a public safety dispatch site really can't. They need stuff up and operational all the time. The stuff I am talking about is what gets done with their setups and what keeps them on the air. If you disconnect your antenna line from your radio then it's no different than leaving it connected IF everything is properly grounded and bonded. Because the lines, tower, and equipment is all still grounded. Something I forgot to mention with grounding and bonding. And the reason you bond the coax cables to the tower at the top, every 100 feet down and then at the bottom where the cable turns out of the tower and goes to the building is the magnetic pulse that happens if the tower does get hit. Due to the extreme currents that are present during the event (strike) there is a significant magnetic field that surrounds the tower. We all know that a wire will have a field around it as current passes through it. It's how motors work. Now crank that from a 6 volt battery to lightning. EVERY conductor that's around that structure taking the hit is exposed to that field. And remember that we pass coils of wire in magnetic fields to generate power. Again, little DC generator hooked to a light bulb with a couple small magnets will light a light bulb when we spin the generator with our fingers. Turn that up to lightning power and magnetic fields. So we BOND the coax shield, since it's a conductor back to the tower to equalize that induced current and voltage and shunt it back to the tower and ultimately to ground. There is a LOT of science to bonding and grounding of towers and antenna systems. There are some of use that have went down that rabbit hole and have a reasonable understanding of this. And I will say this, keeping it simple. Cars get hit by lightning, even though they are on rubber tires. And the reason is that 6 inches of rubber ain't enough to keep an arc that's thousands or tens of thousands of feet in length from hitting a car with 4 inches of rubber. And they get hit because they aren't grounded. You ever get a bite from a car getting in or out? It's a thing. But a glass jar isn't gonna keep that genie in the bottle any more than 4 inches of rubber is gonna keep your car from being hit. IT has to be grounded properly or you are INVITING a strike. -
WSIQ820 joined the community
Hello everyone, We are new to GMRS and just purchased radios. I’m having trouble with my Wouxun KG-935G Plus programming software. I keep getting this error when trying to program: It appears when I try to select "COM6", which is what is set up in my device manager. Has anyone experienced this and found a solution? Then it closes. My programming goal: I live in St. Cloud, FL, and work in Orlando (32819 area). I want to be able to communicate directly with my spouse/family in St. Cloud when I’m at work. Here is what I’ve done so far: I applied for access on two repeaters (one near St. Cloud, one near Orlando) but haven’t received approval yet. I want to program my radios so that: We can use repeaters for long-distance contact if/when approved. We can still talk radio-to-radio (simplex) if needed. My questions: How should I program the channels correctly for both repeater and simplex use between Orlando and St. Cloud? Do I program the repeater channel as is and, a separate simplex channel for fallback? Is there a workaround for this Debug Assertion Failed error so I can finish programming? I tried reinstalling the software and running it as admin, but it still crashes. Any guidance, screenshots, or .dat file examples would be greatly appreciated. I’m new to programming GMRS for repeater use and want to set it up correctly for emergency and daily family communication. Thank you all in advance for your help!
WSEZ969 joined the community
WSIT997 joined the community
You assume disposability. I don’t know very many people who buy Midland or Baofeng radios with the idea they’re disposable. While some people do indeed reduce the choice to only price rather than considering features, user interface, performance, and reputation. Considering features certainly doesn’t make a person “borderline delusional and severely mistaken”; it reflects intelligence and thoroughness.
Terri, Again I want to express my appreciation for your calm and thoughtful comments and informative posts in response to curmudgeonliness. Happy Independence Day!
Pheday joined the community
That’s true, the owner and those authorized to use the owner’s call sign, which is limited to the owner’s relatives except in an emergency.
Nit pick time - a private repeater that carries only traffic from the owner is not required to ID as long as the owner does.
Funny that you mention this bc we had a set of 4 Midland 1050’s (maybe) used at a rural property. They worked well enough but could not quite cover the whole place. I think all of them had the batteries replaced at least once. They do have the weather alerts and they are the reason I’m familiar with the feature. The only drawbacks I found were that when on Wx alert mode, the battery life was poor and the limited coverage (I think they were <2 watt with a 2-3” antenna). Oh, and they’re camo so when they get dropped from an atv, tractor, or pocket they’re hard to find (we’re down to 2 of 4). For FRS they have been pretty good. I’m looking to get a pair of GMRS radios to keep around the house. But, you make a good point and I should dig into the GMRS Midland’s.
WRVG568 joined the community
WRPG745 replied to a topic in Guest Forum
any FM radio replacement will work, but I suggest you disassemble it first and see what the mounting post looks like. Your reference photo has the folding style like this one from Amazon
