Sooo...jumping after reading. I understand that more Watts doesn't necessarily ,equate to more fars. I realize from here that my repeater pushing 24 Watts will work almost as well as 50 Watts. My question is about Watts vs fars and obstacles. Is Watts vs fars linear, geometric, exponential? For example: 5W output on the repeater vs. 24W output more drastic improvement than 24W to 50W. Second part is: does more Watts afford more 'muscle' to propagate through foliage?
marcspaz reacted to a post in a topic: Has anyone used the Midland or the Retevis repeaters?
marcspaz reacted to a post in a topic: New HAM with fading issue
Thank you Gang. I am aware that RG58 is not a good choice. That was what was on hand at the time to play here in the shack. I have and am using RG213 and KMR400 for testing and radio play.
WRDJ205 replied to WSBX980's topic in General Discussion
We use a Retevis 97S for woods and neighborhood communications. Incredibly easy to set up. I use an Ecoflow power bank and a j-pole antenna on a painters stick. -
I'm thinking about getting a Radioddity DB25-G GMRS Mobile Radio 25 watt.
WRDJ205 replied to WSBX980's topic in Guest Forum
I’m also using a DB-20 with the midland ghost. It is the second one though. The first got extremely hot so I sent it back. The second one is working very well. -
By no means is this scientific, but with a UV-5r on one watt and HYS 8" antenna, I can open and converse on a 2m repeater 20 miles away, although the report is quite a bit of static. From inside the house, I can't even open the repeater with that antenna. When I switch to the HYS 15" antenna, I can converse from inside the house with reports of "some" static. Clearly, the antenna does make a difference, and in my experience, a longer antenna usually works better. The trade-off, of course, is that it is less convenient than a shorter antenna. YMMV
WRUU653 reacted to a post in a topic: Radioddity DB20G
WRTC928 reacted to an answer to a question: Best HT Antenna?
Just an FYI, It's possible that one of the other radios chirp file will work with it but chirp isn't listing for the Abbree specifically at this time.
I had the same experience with the 2x4SR. SWR was (IIRC) ~1.5:1 on 1.25 meters and lower on all the others. Unfortunately, the local 1.25 meter repeater is as dead as disco. I can trigger it and get its automatic ID, but I never get a response from a live person, so I don't know if the antenna actually works well in that band. I'm studying for my General license mostly so I can use and become familiar with HF modes of communication before any sort of disaster occurs. Repeaters are good, but after Hurricane Helene, only one or maybe two (IIRC) repeaters were functioning in the affected area. It's not hard to imagine a scenario where all the repeaters within range of me are rendered inoperative for some period of time. Before that happens, I want to have HF equipment and know how to use it. I'd like to be able to get a signal out at least a few hundred miles. I probably won't get much excitement out of just "making contacts" but I could be wrong.
Gotcha. But I believe they're all on CHIRP now, so that should take care of that issue.
Yes the Retevis RA25, and now Abbree also has one on Amazon. And it's $10 cheaper than the others.
I think the issue he's pointing out is that the Radioddity and Anytone seem to be fully compatible (IE: running the same software and can read / write with each other's CPS) but the Retevis didn't seem to play nice with AT / RO software. And once he used the Retevis software, it worked. Small issue, but it sounds like there's some small difference. If you use a Retevis radio with Retevis CPS, you probably won't have any real issues.
I haven't had any issues. I think once you figure out the CPS, it's actually pretty easy.
Yup, I was able to save one of the default repeater channels into 39, but 31-38 aren't an option through the radio menu. Talk about extra handicapped...
And you can usually do the MARS Mod to these types of radios with will open up MURS, GMRS and CB bands. Not that I would condone using a non Part 95 certified radio on GMRS or a radio that puts out way more than 4 watts on 11m/CB or more than 2 watts on MURS
Was gonna reccomend the 778uv, which i own 2 of, or finding a good deal on a used anytone 5888uv, which i also own... great radios for the price....
Fun fact.... dummy loads can still get out there if you are close enough.... was testing radios in my buddies backyard one drunken evening, about 3 miles from the local repeater, and were able to hold a conversation on said repeater thru the swr/power meter and dummy load configuration, on a radio which showed just over 7 watts..... recieving side said audio was a bit muffled, but clear enough to be understood
REPEATER STATUS
WRFS362 replied to WRFS362's topic in South Georgia GMRS's SOUTH GEORGIA GMRS REPEATER STATUS
Hello Group! Here is a quick repeater system update! 9/7/25 SGA-575 is ON the air! New updated repeater is in and being readied to be installed in the near future. Also antenna crew is being scheduled to replace the existing antenna with one that has higher gain. SGA-600 is ON the air! Intermittent noise issues....Replacement duplexers have been received and tuned. Scheduling date to install them during last quarter 2025. SGA-650 is NOT on the air! Down due to hurricane Helene tower being destroyed. New site has been located and equipment is being ordered. Tower crew to be scheduled for work. Still no ETA at this time. Hopefully during winter 26-26 SGA-700 is NOT on the air! The tower site is being reconfigured. The repeater will be off for a few months while work is being completed. Thanks, Scott Haner - SYSOP WRFS362 -
Congrats on the tech.......EMCOMMs are ok....most of the CERT members I knew only used the radios for local nets. There is a lot more to this hobby as I'm sure you will find out. The other tests are not that hard either compared to the 'old' days.
Looks like in my absence, you got some positive suggestions to solve your problem. If you are still running into trouble let me know some specifics and I will re-lock my radio and work them out for you!
I posted that comment hoping I would get some feedback from a Retells Ra-25 owner. I have never laid my eyes on the Retevis, but I once helped someone online debug their codeplug. The problem I had was I could not open their Retevis codeplug in either my Radioddity CPS software (preferable) or even my older Anytone CPS software. So I had to download the Retevis software to open it, modify it and save it back to send it to the user. I notice that @wayoverthere just mentioned a similar anomaly above: Hence my reluctance to recommend someone purchasing the Retevis over a choice of either the Radioddity unit or the Anytone unit.
I'm running MX-Linux 23.3 based on Debian. Ubuntu and Mint are both offshoots of Debian. I'm using WINE to run my CPS programs and they pretty much work without issue. You should be able to find WINE, WINE Tricks and Play on Linux in the Repos of your Distro. Once you get that installed it's just a matter of making the .exe file executable in the permissions then you can open with WINE and either run it or install it.
That radio has SMA Male in the radio so you'll need SMA Female to BNC Female for it. Then which ever antennas you'd want to use. I have the stubby on my work radio but can quickly change to the 771 length antenna when I need more range and I don't have to ware out the threads in the radio. Like I said, I wish I'd have done this from the start, it really makes antenna changes a breeze.
Ok thanks. I was looking at some of those, and wasn't sure if I needed both the different ones. I have TD H3's.
Depends on the antenna connection on your radio(SMA Female(most common) or SMA Male(less common)) then you just get a BNC Male antenna to connect to the BNC Female connector. https://www.amazon.com/dp/B0FD3BSMSK?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1 https://www.amazon.com/dp/B00CVQL14A?ref=ppx_yo2ov_dt_b_fed_asin_title https://www.amazon.com/dp/B01N5Y8H9L?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1 https://www.amazon.com/dp/B085MDL66C?ref=ppx_yo2ov_dt_b_fed_asin_title https://www.amazon.com/dp/B0F9FB4J3D?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
The IC-2730 is also MARS-moddable, but doesn't support D-STAR.
