https://baofengtech.com/wp-content/uploads/2025/06/F8HP-125m-release.zip
Because that radio, bolted to your desk with a power supply and a big antenna on your roof becomes a "control station" if you are talking through a repeater. That's clearly defined in Part 95. I know at least one or two people are going to loudly disagree with me but they are already on my ignore list. I think this is probably thread number 7.5 debating this in the last two years. If folks "interpret" the rules differently (which means they don't understand them) that's nice for them. Doesn't affect me or the 1000s of other folks with GMRS "control stations".
WSJW650 reacted to a post in a topic: BTECH F8HP vs BTECH uv5x3 vs other
1629dill joined the community
but a fixed station is
WRQC299 started following Help identifying this tone when using GMRS Repeater
WRQC299 reacted to a post in a topic: Help identifying this tone when using GMRS Repeater
Download link to Terry CPS please
Yep, I think it is. It's just well set up so it's easy to get around on and you have access to all the radio functions.
CPS easier than Chirp?
The thing that really sets the BF-F8HP Pro ahead of the others is the CPS. It makes it really easy to program the radio. We have Terry to thank for that.
amaff reacted to a post in a topic: Help identifying this tone when using GMRS Repeater
It says that clearly. But why should there be a difference between a 'mobile' radio talking through a repeater, and the exact same radio used as a 'base station,' bolted to my desk or whatever with an antenna on the roof, talking through a repeater? That's the part that doesn't make any sense to me. I don't do that. I'm not the 'hop on the wednesday night net' type and have little use for a radio that's not in a vehicle or backpack. But I don't get why putting the radio in a fixed location should change anything about its legality.
OffRoaderX reacted to a post in a topic: My First Contact!!
TrikeRadio reacted to a post in a topic: My First Contact!!
I'm thinking about getting a Radioddity DB25-G GMRS Mobile Radio 25 watt.
WRYS709 replied to WSBX980's topic in Guest Forum
Oh dear! That was my experience when I purchased a triband HT specifically to add 220 MHz coverage. That HT has been collecting dust for years now. -
Doesn’t the Quenshang UV-K5(8) family of radios have the most sophisticated library of alternative firmwares at this point? For about $20 from AliExpress and the free IJV-3 firmware, I finally have a 5 watt HT thst an communicate with 2 meter SSB Ham Radio stations. With my 5/8 2 meter telescoping antenna I made a 65 mile QSO to another Ham and he found my DSB transmission good reception quality.
SteveShannon reacted to an answer to a question: Mounting NMO antenna to aluminum truck cab?
What’s vague about it? Base stations are not listed as being permitted to transmit on the 467 main channels. That’s pretty clear.
Lscott reacted to a post in a topic: BTECH F8HP vs BTECH uv5x3 vs other
Northcutt114 reacted to a post in a topic: Simplex listing?
A rule soooo vague.. you just do what you think and you be safe, But only if your are concerened anyway... The older i get the less concerned i get
WRUE951 replied to JohnDeere7920's question in Technical Discussion
What you said: common sense is free.... -
I like the Baofeng K61. It covers pretty much all the frequencies I want, including the 1.25 meter band. It's intermediate in size between the UV-5r and the Uv-5RM, which is handy because it's small enough to shove into a pocket but not too small to be easily manipulated. In terms of features, as far as I can tell, the UV-5RM Pro GPS is virtually identical to the BF-F8HP Pro except for the ability to update the firmware in the future. It's about 2/3 the price of the F8Hp. I guess it's a matter of how much you care about the ability to update firmware.
Congratulations! I have an Anytone with the same mic. I like the big A/B button because it's easy to find without looking at it, which is nice in a mobile rig.
WRTC928 replied to WSBX980's topic in Guest Forum
I didn't say there's activity. I'm trying to breathe some life into the 220 repeater. Very limited success so far, but if I don't occasionally get on it and put out my call sign, nobody will know. -
nokones replied to JohnDeere7920's question in Technical Discussion
My guess is, voice and data service when outside of LMR/LTE/5G coverage. -
And always respect the Queen!
Well done!
WSJS887 joined the community
Thanks all for the guidance. Got a couple of the simple GM-15 pros on order. Wanted something simple with a positive display and sync for me to learn on and that my family could intuitively turn on and quickly find a GMRS channel to transmit/receive on…..but also with potential for other frequency listening/emergency use only. That and $46 for two of them with upgraded antennas was too good of a deal for me to pass up.
If you want a "Bang for the Buck"radio the Baofeng K61 is hard to beat at $16 bucks and it's a Tri-Band that'll get you 2M,1.25M,70cm and it'll do MURS and GMRS. The Radtel RT-900 St $25 bucks gives you multiple bands from 10M,6M,2M,1.25M,70cm and it'll do MURS and GMRS. The BF-F8HP Pro will do 2M, 1.25M, 70cm,MURS and GMRS and the nice thing is that you have 10 channel banks of 100 channels each so you can put the frequencies you want into their own bank and not have to deal with the ones you don't want at that moment. The radios aren't necessarily "legal" to TX on all those frequencies but I honestly have never heard of someone being busted for using a HAM radio on GMRS or MURS so you'd probably be ok. P.S. I have a quick look at each radio on my YouTube channel by the same name.
As much as I like the BF-F8HP Pro (in many ways, "it's my baby"), I'd be remiss if I didn't mention that it isn't type certified for operation on GMRS frequencies (or any other frequencies outside of the Part 97 amateur bands). It does have the most complete feature set of any of the Baofeng analog models, though. If you're just listening, you can set "SK Disable" to "PTT" and the radio will not transmit, either from the radio itself or from an accessory microphone. Of course, if you eventually get an amateur license you can just re-enable PTT.
Congratulations! The Retevis RT95 is a clone of the Anytone AT-778, a model that I do not have any experience with; but I am sure many others here do, so good luck!
