Radioguy7268
    28
Radioguy7268 last won the day on June 25 2023
Radioguy7268 had the most liked content!
    Southeastern PA
  • Interests
    Radio tower site manager and GMRS user.
4108 profile views
Radioguy7268's Achievements
  1. If you ever (knew anyone who) used the toy whistle from a Captain Crunch cereal box to get free long distance calling, you might be of that age.
  2. Search up :"Carterphone decision" Once upon a time, there was money to be made in Long Distance calling.
  3. Compander = Compression/Expander It's a method to re-constitute your voice after the insignificant audio has been squeezed out of it. Just like concentrated Orange Juice doesn't taste the same as fresh squeezed - Compandered audio isn't the same as the Original audio. For 12.5 narrowband, it was considered a win in the overall audio picture, but you gave up some tonal quality while it did reduce background noise and hiss. In 25 kHz wideband, I never really saw the benefit to using it. It's also a system wide setting, so if only one radio on your channel is using it, all the other units will not hear him clearly & vice/versa. Better to have everyone using the Compander feature, and not all radios offer the feature - and not all radios treat the compandered audio exactly the same during compression/expansion. It can lead to odd sounding audio. I've also seen some radios display a lack of sensitivity at the edge of coverage when using compandered audio. I played around with that a bit in the late 90's with the onset of narrowbanding. the TLDR was: use if it it works, but you're better off to implement it from the start. Migrating a user group over to it was a PITA - especially if they had a mix of radio models.
  4. Law Enforcement Radio Network = LERN, or LEARN. It's a group of networked GMRS repeaters throughout New Jersey. They reach into southeastern PA, DE, & NYC. You're supposed to be Law Enforcement to use the system. Not sure if it's still linked. I rarely heard anyone on it when I used to monitor GMRS in the area. /off topic
  5. A mobile radio that sits on your desktop and has a power supply is NOT necessarily a Base Station. As Marc eloquently stated above, it's the operation that counts, not the configuration. A Base radio operates on the lower 462.xxx frequencies. A Control station may appear very similar to a Base, but a Control Station transmits on the 467.xxx frequencies, and listens on the lower (base side) of the pair.
  6. I have seen certain PL/DPL codes that cause issues with some radios. If you can see the receiver LED is active before you actually start hearing audio, try switching your radios to a different PL code on the same freq & see if the problem goes away. For most of what I saw, it was usually the lower frequency PL tones (below 80 Hz) that were the ones that caused problems.
  7. There is no coordination through the FCC. Self-coordination is the typical method. If you're already thinking about installing your own 20 watt repeater, have you determined that there are no other repeaters in your area that offer you the coverage you need? If so, you should have a pretty good idea already of what pairs may be available in your area. There's a pretty long thread on the site that goes over many of the issues of standing up your own repeater. https://forums.mygmrs.com/topic/1402-you-just-got-your-gmrs-license-now-you-want-your-own-repeater/
  8. Before you get too excited about the long range possibilities of a low band repeater, talk to anyone who has actually built one, or tried to use one. Beyond the problems of skip, near-far, and antennas that can double as fishing poles, you also find out that you need to have one antenna tuned for the transmit frequency, and another tuned for receive. Typical bandpass cavities are 5 ft. tall, you will need enough space for at least 6, and you better keep them in a climate controlled environment, unless you want to keep a separate set tuned for each season. You also need to know that a typical low-band mobile antenna is only good for about a 500 KHz spread while your proposed pair is 3 MHz apart. Noise is a huge problem, terrible at times. It's only gotten worse in the last 25 years. There's a reason why Commercial (paying customer) Low-band has become a wasteland. Actually, there's many reasons beyond the ones I've mentioned. Most manufacturers have abandoned the band.
  9. I once had a "channel saver" repeater set up to scan on 5 UHF trunked channels. The concept was that the system needed to be operational within one year on all 5 frequencies in order to file a Construction notice with the FCC. In order to do that, we built up a 5 channel scanning repeater (all the frequencies were fairly close together in the 451/452 range). A portable could key any of the 5 licensed channels, and carry a short conversation to prove operation - just not on all 5 channels at once. A split antenna system was already in place, and we just used a widely tuned bandpass cavity on the transmit side. We got the idea from Nextel, who was doing a similar thing on 800MHz analog channels they had acquired, but not yet transitioned into their iDEN system. Unusual, yes. But not bizarre But ultimately a waste of time and material.
  10. Glad to hear you got it fixed up. The wideband entitlement issue is troublesome, as Motorola is no longer supporting older 'legacy' software, and the EID's only work on the newest, current software. Otherwise, you are left with trying to hex edit the software & bypass the built in checks that forced narrowband in the newer software versions. As you discovered, R05.16 was the last legit version that allowed CP200's to be programmed wideband with 25kHz.
  11. A Fixed Station is one that's been repaired. /s
  12. Motorola moved all the current model software over to a new website. For most folks, that's at myview.motorolasolutions.com. Unless you want to go through all the steps to migrate your account over to Myview, only to find that they probably don't have the legacy # RVN4191 CP200 software ( I myself haven't checked lately), you're better off to do a google search and try find it on the web. The benefit there is that you would likely find a version that's been hacked to allow wideband. The last versions of the analog CP200/PR400 R05.18 software were narrowband only, and most GMRS folks want the ability to program 25kHz wideband. Note: the more recent CP200d is a different animal, and uses different software for programming.
  13. Do not mount antennas with 50 watts or more ERP inside the cab within inches of your head. Read up on Specific Absorption Rates and RF safety. Also realize that transmitting at 50 watts to someone who is holding a 4 or 5 watt portable is overkill.
  14. I am pretty old, and stuck in my ways, but I'm pretty sure that a "simplex duplex box" that doubles as a "GMRS specific box" requires about twenty some 8x10 color glossy photographs with circles and arrows, and a paragraph or two describing what each was to be used for. I'm thinking your description is a simplexer with delayed audio being re-transmitted back out on the same frequency it was received on. But I'll wait for those photographs and a clear description of the function of each magic box. Enjoy.
  15. I don't believe that the old TK-880 software is capable of using anything other than Comm port 1 through 4. In your Kenwood software, what Comm port are you assigning the software to use? What does your Device Manager say is the port assigned to your USB programming cable?
