28
Everything posted by Radioguy7268
If you ever (knew anyone who) used the toy whistle from a Captain Crunch cereal box to get free long distance calling, you might be of that age.
Search up :"Carterphone decision" Once upon a time, there was money to be made in Long Distance calling.
Compander = Compression/Expander It's a method to re-constitute your voice after the insignificant audio has been squeezed out of it. Just like concentrated Orange Juice doesn't taste the same as fresh squeezed - Compandered audio isn't the same as the Original audio. For 12.5 narrowband, it was considered a win in the overall audio picture, but you gave up some tonal quality while it did reduce background noise and hiss. In 25 kHz wideband, I never really saw the benefit to using it. It's also a system wide setting, so if only one radio on your channel is using it, all the other units will not hear him clearly & vice/versa. Better to have everyone using the Compander feature, and not all radios offer the feature - and not all radios treat the compandered audio exactly the same during compression/expansion. It can lead to odd sounding audio. I've also seen some radios display a lack of sensitivity at the edge of coverage when using compandered audio. I played around with that a bit in the late 90's with the onset of narrowbanding. the TLDR was: use if it it works, but you're better off to implement it from the start. Migrating a user group over to it was a PITA - especially if they had a mix of radio models.
Law Enforcement Radio Network = LERN, or LEARN. It's a group of networked GMRS repeaters throughout New Jersey. They reach into southeastern PA, DE, & NYC. You're supposed to be Law Enforcement to use the system. Not sure if it's still linked. I rarely heard anyone on it when I used to monitor GMRS in the area. /off topic
A mobile radio that sits on your desktop and has a power supply is NOT necessarily a Base Station. As Marc eloquently stated above, it's the operation that counts, not the configuration. A Base radio operates on the lower 462.xxx frequencies. A Control station may appear very similar to a Base, but a Control Station transmits on the 467.xxx frequencies, and listens on the lower (base side) of the pair.
slight delay on reception of signals
Radioguy7268 replied to WSCQ874's question in Technical Discussion
I have seen certain PL/DPL codes that cause issues with some radios. If you can see the receiver LED is active before you actually start hearing audio, try switching your radios to a different PL code on the same freq & see if the problem goes away. For most of what I saw, it was usually the lower frequency PL tones (below 80 Hz) that were the ones that caused problems. -
There is no coordination through the FCC. Self-coordination is the typical method. If you're already thinking about installing your own 20 watt repeater, have you determined that there are no other repeaters in your area that offer you the coverage you need? If so, you should have a pretty good idea already of what pairs may be available in your area. There's a pretty long thread on the site that goes over many of the issues of standing up your own repeater. https://forums.mygmrs.com/topic/1402-you-just-got-your-gmrs-license-now-you-want-your-own-repeater/
Before you get too excited about the long range possibilities of a low band repeater, talk to anyone who has actually built one, or tried to use one. Beyond the problems of skip, near-far, and antennas that can double as fishing poles, you also find out that you need to have one antenna tuned for the transmit frequency, and another tuned for receive. Typical bandpass cavities are 5 ft. tall, you will need enough space for at least 6, and you better keep them in a climate controlled environment, unless you want to keep a separate set tuned for each season. You also need to know that a typical low-band mobile antenna is only good for about a 500 KHz spread while your proposed pair is 3 MHz apart. Noise is a huge problem, terrible at times. It's only gotten worse in the last 25 years. There's a reason why Commercial (paying customer) Low-band has become a wasteland. Actually, there's many reasons beyond the ones I've mentioned. Most manufacturers have abandoned the band.
Retevis RT97L portable repeater -- first impressions
Radioguy7268 replied to WRTC928's topic in Equipment Reviews
I once had a "channel saver" repeater set up to scan on 5 UHF trunked channels. The concept was that the system needed to be operational within one year on all 5 frequencies in order to file a Construction notice with the FCC. In order to do that, we built up a 5 channel scanning repeater (all the frequencies were fairly close together in the 451/452 range). A portable could key any of the 5 licensed channels, and carry a short conversation to prove operation - just not on all 5 channels at once. A split antenna system was already in place, and we just used a widely tuned bandpass cavity on the transmit side. We got the idea from Nextel, who was doing a similar thing on 800MHz analog channels they had acquired, but not yet transitioned into their iDEN system. Unusual, yes. But not bizarre But ultimately a waste of time and material. -
Glad to hear you got it fixed up. The wideband entitlement issue is troublesome, as Motorola is no longer supporting older 'legacy' software, and the EID's only work on the newest, current software. Otherwise, you are left with trying to hex edit the software & bypass the built in checks that forced narrowband in the newer software versions. As you discovered, R05.16 was the last legit version that allowed CP200's to be programmed wideband with 25kHz.
A Fixed Station is one that's been repaired. /s
Motorola moved all the current model software over to a new website. For most folks, that's at myview.motorolasolutions.com. Unless you want to go through all the steps to migrate your account over to Myview, only to find that they probably don't have the legacy # RVN4191 CP200 software ( I myself haven't checked lately), you're better off to do a google search and try find it on the web. The benefit there is that you would likely find a version that's been hacked to allow wideband. The last versions of the analog CP200/PR400 R05.18 software were narrowband only, and most GMRS folks want the ability to program 25kHz wideband. Note: the more recent CP200d is a different animal, and uses different software for programming.
Do not mount antennas with 50 watts or more ERP inside the cab within inches of your head. Read up on Specific Absorption Rates and RF safety. Also realize that transmitting at 50 watts to someone who is holding a 4 or 5 watt portable is overkill.
Is a duplexer required for a repeater
Radioguy7268 replied to WRWE744's question in Technical Discussion
I am pretty old, and stuck in my ways, but I'm pretty sure that a "simplex duplex box" that doubles as a "GMRS specific box" requires about twenty some 8x10 color glossy photographs with circles and arrows, and a paragraph or two describing what each was to be used for. I'm thinking your description is a simplexer with delayed audio being re-transmitted back out on the same frequency it was received on. But I'll wait for those photographs and a clear description of the function of each magic box. Enjoy. -
Having trouble with KPG-46 USB Programming Cable
Radioguy7268 replied to WSGZ436's question in Technical Discussion
I don't believe that the old TK-880 software is capable of using anything other than Comm port 1 through 4. In your Kenwood software, what Comm port are you assigning the software to use? What does your Device Manager say is the port assigned to your USB programming cable? -
Kenwood TK-880 displays "TEST" when powered on
When I get a used radio and program it, I will often put in a common frequency and label it as "TEST" instead of "Channel 1" That way, when I have the radio on my tuning bench, I know the frequencies (and codes) that are in the radio, and I know it hasn't been programmed to a customer frequency. I don't believe you are actually seeing a Test mode - ie: Something the radio is locked into. I believe you are seeing someone else's old programmed name for the first channel in the radios. Especially if the two radios talk to each other already. A Kenwood radio should drop into a "Program" message when you have the proper cable & software, and try to read or write the radio. Some of the older Kenwood software required you to run a regular Comm port (not USB) and the software only allowed a choice of Comm1 through Comm4 for serial ports. Trying to use a newer computer with old software can lead to some issues. -
"I can neither confirm nor deny." For the younger folks out there, check the reference to the Glomar response, and it's place in Government history. If you really want to get wrapped up into some deep rabbit holes, check out the relationship of Howard Hughes to the whole Glomar thing. Most kids (My college age daughter included) have only ever heard of Howard Hughes as "The Aviator" and Leonardo DiCaprio. They don't know about Glomar, TWA, or the Mormon Will and Ice Station Zebra.
I'd also point out that in 2017, when Hurricane Maria blasted through Puerto Rico, many people were basically left to fend for themselves, and went weeks and months without grid power, running water, or even cellular service. This was especially bad in the inland areas up in the mountains, but was still an issue even in areas outside of Ponce & San Juan. They aren't necessarily doing this for overall footprint, they're doing it to allow for localized reception in pockets and areas that aren't served by larger systems. They also want to maintain control and ownership of the repeaters, and not rely on someone else to keep a system powered up 24/7.
Guest, asking for input on a Community communication system
Radioguy7268 replied to a topic in Guest Forum
I don't think anyone really answered the OP's questions, although the information given is a bit lacking in details. A few questions that might help narrow things down. 1. What's your budget? Who will be in charge of decisions? Is this a centralized control, or left up to individuals that may or may not want to spend $$? 2. Do you plan to supply your own labor, or purchase a plug & play system? 3. Do you have ownership/control already of a location for the repeater? 4. Do you have a need to communicate with other existing radio users in the area? Will this be a private system just for your users? Or do you wish to share? 5. What is the elevation at this Community Center? Do you have the ability to place an antenna and/or mast/tower at this location? What's the surrounding terrain like? As far as a general shot at answers: Bare repeater. Used $500 to $1500 New $1000 to $5000 Need to allow for labor costs if you don't know how to program/install Antenna & Duplexer system New is the best option here, costs will vary greatly, but as little as $400, as much as $2500 Individual portables could be less than $50 or more than $500 depending on what folks might want. Bare bones GMRS repeater capable units are fairly cheap. Mobiles that mount in vehicles are more expensive. LoRa i'm assuming is LoRaWAN - which is effectively Long Range data bursts in the 900 MHz ISM band. Good for telematics & GPS, not so great for voice, but that begs the question of what's the primary use and purpose of this system? If you're looking to do chit chat for local folks on a wide open community channel that anyone and everyone could join in on, then GMRS might be a pretty good choice. If you're looking for exclusivity or privacy, and you want to do tracking or data transmission, there might be better options. -
Hypothetical Flat Earth Range Question
Radioguy7268 replied to HHD1's question in Technical Discussion
Search up the Rodinia 2.3 chip used on some EVX & XPR Gen2 radios. That is a 12dB SiNaD reading I'm quoting for that -120 dBm - and it's easily achieved with those Rodinia receivers. Fully quiet at -120 dBm. I'll agree that real world factors play into this stuff. Noise floor is the killer in most urban environments. There's a ton of trash and hash out there in the real world. Nobody is designing a commercial system around the theoretical basement level of what receivers can do. Previous forum discussion on Receiver design -
Yeah - the -120 dBm of the assumed average receiver is the true limiting factor. Google up EME (earth moon earth) contests - people using the moon to bounce/reflect signals. I've heard of people making it with 2 watts or less, but they're jacking up the receivers with all types of high end pre-amps and using CW. Voice would be problematic. There are real world receivers out there in UHF radios (Think DMR Digital Vertex EVX & Moto XPR's) that will go down to -125 without spending too much money (and still have decent selectivity). Those radio on a chip direct conversion receivers all the CCR folks love have some wild receive sensitivity, but they're also about as selective as a drunken politician spending someone else's tax dollars. The original Apollo comm's with the moon were all UHF with Yagi antennas. People still heard "One giant step for mankind" although how clear it was is debatable. Then again, those Flat Earther's would point to the limitations of UHF radio signals as proof that the landing did not take place on the actual moon. AI makes my eyes hurt. -
I read about the rash of robberies happening to GMRS users, so I started using FRS instead. /s
Glass mount antennas suck for UHF. They are marginally better than using a portable inside a vehicle, and I do mean marginally. 800 & 900 MHz work better, but still not ideal. I'd tell you to look for other options before spending money on a glass mount. A 6" UHF hatpin can be mounted in plenty of locations where it's barely noticed. Shark fin antennas made by Stico & others mimic factory FM antennas for the entertainment radio.
I've got a concrete ready-mix company in the Mid Atlantic area with over 100 trucks using M1225 and PM400 radios in their fleet. They've been a customer since 1998, and they're still using some of the original radios that we sold to them. They go through palm mics & external speakers (which get clogged with concrete dust) but the radios sit in trucks that are parked outside all the time. They see temps from Zero to 90 every year. They get about as much use and abuse as any radio I've ever seen, and the M1225/PM400's are nearly bulletproof in my experience. The M1225 is Part 95 type accepted. The PM400 is not, but is just the updated version. Either one can be bought used all day long for prices similar to any of the CCR models listed above. Many sellers will program them for you.
Motorola M1225-LS Repeater Question
Radioguy7268 replied to Spudhut's question in Technical Discussion
There are 2 different radios being discussed here: The M1225 LS model was built by Motorola as a UHF Trunking radio that had the ability to program conventional channels in addition to LTR (Logic Trunked Radio) channels. There was no add-on board in that radio. The standard M1225 UHF mobile radio only did conventional channels out of the box. You could use an add-on Option Board (most made by Scholer-Johnson, but sold by others) to add LTR Trunking capability to the standard M1225. Removing the board (or just disconnecting the flex cable to the LTR board) would revert the radio back to conventional mode. The Scholer Johnson add-on board would be in the top left rear of the radio under the housing & secured with 3 nylon screws.
