6
Everything posted by amaff
Oh. Then you're good.
I'm guessing you mean for that channel on the radio. In that case, it SHOULD work. There's always a chance the repeater is offline for some reason. In which case, it wouldn't matter what you put in the radio. Can you hear traffic on 675? And do you still hear that traffic with the tone enabled? (IE: repeater channel 20 and simplex channel 20 are the same receive frequency, so on an open (no tones) channel, you can potentially hear simplex traffic even if you're on a 'repeater' channel)
For clarity, on the UV-5R-family, you need to set a +5.00 Mhz offset. On the radio, you'll set the direction (I think is the option) to "+", and the offset to 5.000 That way you're listening on the 462.xxx, but the radio will transmit on 467.xxx
The super restrictive programming is probably my biggest annoyance with a lot of the cheaper GMRS radios. My more expensive ones (in this case, KG-905Gs, so not SUPER high end stuff) let me program in what I want where I want, and enforce the GMRS rules properly for those frequencies. As far as I can tell, I could put a repeater channel in every slot of the radio. Pretty much everything else I have is jailbroken (with the appropriate rules programmed in manually) so I can set them up the way I want to. There's nothing in the GMRS rules that says "the radio can ONLY HAVE 22 simplex channels, 8 repeater channels, and if you're feelin frisky, a handful of DIY channels"
That is fixable
Pennsylvania people.. you need to take action now
amaff replied to kidphc's topic in General Discussion
Y'all got hard copies of your GMRS license? That's a thing? -
Not a question, but a hack I tried that has worked really well. The absolute worst part of my DB20-G is the mic hanger. It's probably 100% user error, but I could never get the mic re-seated without taking my eyes off the road and sometimes using both hands. It's just a cheap, flimsy design. I saw a family member using an inexpensive mag-mount for their cell phone a few months ago, and figured, no harm in trying on an inexpensive radio with an even more inexpensive handset. I took the mic apart (4 small screws) and removed the male 'bobbin' (or whatever it's actually called) part of the mic that slots into the stamped sheet-steel hanger. I was surprised to find a chunk of metal embedded in the back of the mic. It already feels pretty light and flimsy...I imagine it would feel even worse without it. I trimmed and bent the flat metal piece that mounts to the device (super hack job, but hey it works) and stuck it to the back of the mic. The only real issue was that the adhesive they come with is pretty terrible and fell off in the heat of the car, so I slapped it back on with some super glue and it's been stuck on since. The only thing I'd do differently is probably use one of the smaller round plates instead of hacking 1 of the bigger rectangles, but I'm not taking this apart to 'correct' that since I can't see it, and it doesn't affect the thing *at all*. This thing works *great*, holds the mic super securely (it's way lighter than a modern "Plus" sized cell phone), and you just need to get it close for it to snap into place. If you, like me, hate the mic hangers these cheap radios come with, this may work for you.
Awesome, glad that's all it was
I think they woke up on the wrong side of the bed this morning.
Yeah, it's showing correctly there
Doesn't look like it. I can add a Ham callsign, but if there's a spot to edit my GMRS callsign it's not obvious
Appreciate it. It's obviously not a massive issue. It's just an odd thing I noticed, and wasn't sure if it was just me.
I was poking around in my profile trying to find some settings to mess with and noticed this: Except that's not my callsign. The website shows it Correctly: Given, near as I can tell, they're the same account (I didn't have to do another registration for the forum, I just had to use my myGMRS login to log in to the forum....wtf? Doesn't look like I can edit it even if I wanted to, to correct it.
I think you're looking at Channel Spacing (which is, for whatever reason, bandwidth). 12.5 is narrow, 25K is wide. Step size I think can go down to 2.5K.
Try lowering the step size.
Clearly that's how it should be. But with the way this thing's set up...
TidRadio TD-H3 nothing heard for 2 seconds after transmit
amaff replied to SkyNet's question in Technical Discussion
Odd. I'm not seeing that on any of mine (FW 240401). Haven't heard of this being an issue on them either -
in before someone runs down that FCC ID to make sure it's legit
No worries, just sharing what was shared with me that worked. But it'd be nice if it was in the original post instead of having the next person have to stumble across it buried in the thread
100% that. That's why I'm curious if it'll let him transmit on the interstitials if he puts them somewhere other than those 8-14 memory slots.
It's not the same type of cable as the DB20-G. That's an RJ-45 connector. This one is a DIN connector of some flavor. The CPS for the DB20 is a little clunky. The main 'trick' is to use the ">>" buttons for practically everything instead of trying to do it in the spreadsheet, IMO
I don't know if this changed in later versions (I bought mine this year, so it's bee a few years now), or maybe it's something specific on the Radioddity DB20-G I have (tho these are supposedly fairly identical) but there's a step missing here you may want to consider updating for other johnny come lately noobs like me, since the "manual" gives F-all direction on how you should expect to do this. If you are programming in a channel in VFO mode on the radio, once you get to this step, using the Up and Down buttons won't do *anything* until you press the MON button. And thanks to the legend on the FB Anytone 779UV group that got me pointed in the right direction. The MON button will cycle through what type of tones you want (CTS / Custom CTS / DCS). And then once you're in the list you want to use, you can use the Up / Down buttons to cycle through the various tones / options (or presumably do a non-standard one if you need to, but I haven't played with that at all). But if you try and do this without that step, you'll just keep getting the "F-U" tone
I feel like we're talking past each other. A mobile GMRS radio should never transmit on the interstitial frequencies, *no matter what memory slot they're in*. They can (and should) comply with that by enforcing the rules on those frequencies no matter where in the radio's memory they are. You can 100% comply with the FCC's rules while not arbitrarily blocking out those memory slots. Lots of radios do it.
You can have a radio that works right out of the box (like the aforementioned 905G), but that also allows you to do more or less what you want while following the rules. Just for fun, and to illustrate: I have a repeater channel in memory slot 9, a low power channel in memory slot 11, and a normal 5W GMRS channel in 11. Given Sven's experience, it'd be interesting to know if it allows transmitting on those frequencies, so long as they're not in one of the magical memory spots. Probably not. But it'd be funny
