Everything posted by TrikeRadio
Faile to upload via Chirp with TD H3
TrikeRadio replied to WRZI299's question in Technical Discussion
I use the USBc cable into the programing connection under the mic cable connection. You are using a programming cable into the two prong microphone holes? -
But California also has MOUNTAINS. Putting just one ore two on peaks can cover hundreds of miles of area and range.
The repeater channels on your radio are just channels on your radio set up to transmit on one frequency (+5 mhz) and listen on another frequency. This is how they contact and listen to repeaters. (They send to a frequency that the repeater receives and then it will re-transmit on the frequency you and others are listening to) Repeaters can be owned / operated by local individual owners or by clubs. The input (tx) tone and output (rx) tone can be any of the CTCSS or DTS (digital) codes that the repeater owner chooses. You have to know the proper TX tone to activate the repeater. The RX tone can isolate only transmissions from the repeater, or you can leave the RX tone off so you hear anything on the frequency. And repeaters are local. Usually with a range of a few miles up to 100 miles if they are powerful and/or up on a high location.
Welcome to GMRS. I am also in S. Cal, new callsign since June of this year. Which repeaters have you been able to use?
also... don't be surprised if your request for access either takes a long time, or you never get a reply. Some repeater owners don't check their messages here on mygmrs very often. Another reason to just pay to join a club and use their repeater. they respond faster to requests. But I totally understand. When I started I tried jsut the free ones that I had tone access to... before I paid to join a club or two
I think that might mean you are actually hitting it. (Unless that is your own radio doing a "roger beep" which you could turn off). I'm not sure how many people use that repeater so you may or may not get a response. Call it with your call sign and ask for a radio check for your new radio... as a test see if you get a reply but yes... outdoors where you have a clearer view of the direction of the repeater might help... but you may be hitting it from inside the house too.
Have you tried to see if you can get a response from the Ranchino repeater? (I think it is the only one you mentioned that has the input tone publicly listed.) The others.. I guess you will just have to wait for their permissions to get the input tones. I can say that the Mesa Crest club (which yes it costs a very small fee) is well worth it... great coverage and good people on it. They also have a repeater on Santiago Peak as well as their main one. Good luck and welcome to the world of GMRS.
"Tones" I think he meant...(Typo I'm sure) It means your RX tone/code/CTCSS for the repeater. You may have the RX tone wrong that might be why you cant hear them
Yeah even if their new callsign shows up on the FCC site... usually takes a day or two for MyGMRS to add it or recognize it.
Excellent! Yep you never know until you actually try. Glad it is working for you!
Can you tell us what city or location you are in? Do you know what elevation or line of site there might be to the repeater? Is it on a local mountaintop, tall building, tower? 20 miles is not generally a problem for a 50 watt mobile unit or even a lesser wattage radio even with some obstructions. but line of sight to a repeater is always the biggest factor. EDIT (Oh I misread your statement about distance. I see now you said you are 20 miles from the edge of the repeater's 35 mile range circle so.. yeah that might be tricky to hit consistently) also... simplex (radio to radio without a repeater) can work even without great line of sight if you are close enough, so... how far are you trying to connect between two radios?
Programming Tidradio td h3 using USB-c
TrikeRadio replied to VETCOMMS's question in Technical Discussion
I have two TD-H3s and I can confirm that the provided USB cable can be used in the SIDE PORT USBc port (not the bottom one on the battery that is for charging) to both connect to CHIRP and program the radio, and you can update the Firmware using it. But yes you do have to either let the software select the correct PORT or you have to manually select the correct port for the usb cable. You CAN get a separate programming cable, but it should not be necessary. -
That is the best part of it all! My family looks at me and wonders why I mess with radios. I guess I'll need to have a natural disaster happen around here to validate my radios.
I have not seen much as far as posting about any GMRS/HAM communication assistance in the Western North Carolina regions where the hurricane flooding was so bad. Does anyone have any news or stories if radio operators have been able to help out in that area? Would be nice to hear some good news coming out of Ashville and surrounding areas if radio operators have been able to make a difference.
In any case, you should call the repeater and at least state your callsign. Don't just key it to see if you get a tail. You may or may not hear it. - you can ask for a radio check or just state " testing repeater (whatever it is called or the channel or frequency) and you call sign to see if you get a repeater response or an actual person responding that they hear you.
Anytone AT-778UV programing software
TrikeRadio replied to hartmans2587's question in Technical Discussion
Hope that gets you connected. Good luck, and feel free to ask questions if you need help. -
Some repeater owners request or "require" you to get permission. if you can find the repeater on the repeater map here at mygmrs.com you cna usually submit a request, but you can also likely ask on the repeater itself. But it kind of sounds like you are trying to reach it on the regular "channel 22" instead of the repeater channel for 22. Check your documentation. the repeater channel which might be called repeater 22 or r22 or just channel 30 sometimes is what you want... and of course enter your transmit tone (if you know what the actual input tone is...how do yo know it is 141.3?) on that channel and try. with 15 watts you should be able ot hit most any repeater in your local area as long as you have line of sight to it.
Which specific repeaters and what is your "area of LA"?
https://chirpmyradio.com/projects/chirp/wiki/Home -
My name is Glenn and I have a GMRS problem. Back in 2012 I innocently bought a pair of cheap Midland GXT1050 walkie-talkies, lying to myself that they were only for practical purposes. I knew deep down I desired to tinker with radios as I did when I was a child playing with CB. Reading the manuals and searching the internet I learned that there were things in GMRS called "Repeaters." I quickly returned these repeater-incapable radios and bought a slightly less inferior set of MOTOROLA MR356R, which also came in a dirty bubble pack. I applied for and received my first GMRS FCC license in February of 2012. I freely admit I used them for some time, I even "checked in" to a few "nets"... but eventually I weened myself from my addiction. I let me license expire on 02/28/2017. I thought I was free. I thought I had escaped. I was wrong. Years later in 2024 I heard that the dealer of GMRS callsigns had lowered the cost to a mere $35. "Go ahead, everybody's doing it. You can handle it," I thought. I returned to the dark ally where my FRN was still waiting for me, I navigated the dank smoke filled corridors of the FCC website and claimed a new GMRS callsign that would last me ten years, and would drag my entire immediate family back into the authorized, but despised world of GMRS. I bought a set of Tidradio TD-H3 HTs because of a shady street dealer who recommended them on youtube. I was excited, I was thrilled. I knew I could take it slow and control myself. "They are just tiny radios", I said, "I can handle it this time." Soon I was checking in on a local GMRS NET as a "guest", but I wanted more. I signed up and payed money to a group who owned the repeater. I got a group member ID. I could now call the repeater whenever I wanted! But I was calm. I had this under control. I was using the radios for practical purposes, communicating with friends whom I cycled with in a group on weekends. It helped I maintain group safety, I kept saying to myself. Then it started. I did not want to go overboard and buy a mobile unit, but maybe I could get a mag mount antenna for my car and use my little HT with a hand mic to just "Try it out" first. Then I bought a few other removable antennas for my HTs to see which worked better when cycling. I bought different hand mics and even a boom mic headset to see if that worked better while cycling. I have caught myself watching video reviews of Mobile Units and checking prices. I have looked up repeaters along the route I drive to where other family lives. I have even contemplated paying more money to another repeater club which has more activity on it than the one I currently have access to! I don't know where all this is leading. But here I am. I am a GMRS user. There, I said it.
