110
Everything posted by Lscott
Ok. Just wanted to be sure.
Oh, I hope you tried changing the timing parameters on the other radio(s) not on the 905G.
It was worth a shot if it fixed it. Perhaps a firmware update at some point might do the trick.
Correct or recommendations for an antenna
Lscott replied to 1977Hahn's question in Technical Discussion
I have one of the 2x4SR antennas, and a buddy here at work put one on his pickup truck using a lip mount on the front hood near the roof pillar. They work OK, but being a 5/8 wave design you need a REALLY good ground plane. I did an SWR scan using a RigExpert AA-1000 and downloaded the data to a CAD package for plotting. As promised the SWR was under 2:1 around the GMRS frequencies and very surprisingly very low on the MURS frequencies. https://rigexpert.com/products/antenna-analyzers/aa-1000/ The antenna is somewhat sensitive to mounting location even with a good ground plane. If you want one antenna to cover Ham and GMRS its a good option. -
Do the TX'ing radios allow changing the timing parameters for encoding the DTMF tones? I know on the commercial Kenwoods I have there are timing parameters I can tweak. Maybe your radio needs longer duration tones and slower sending rate to give it more time to decode.
On the Ham side DTMF tones have been used to access other linked analog repeaters using for example Echolink. I'm not sure if any linked GMRS repeaters use a similar system to access a specific linked repeater.
If it’s working for you cool. Sounds like you’re one of the few people that utilizes the radio’s full set of features, most don’t. Myself I would like to see Kenwood come out with a version of the TH-D74A but use DMR in place of D-Star. That would be a killer radio. I’ve scanned 220 around here by me and it seems basically dead. I have a cheap TYT TH-350 triband I use as a scanner at home. Mostly used to monitor the local mall security frequency, house keeping along with the neighborhood FRS stuff and the local GMRS repeater. For a CCR it’s an OK radio.
Most Linux distro's have a VM function. If it isn't installed then you can add it. If you don't want to go that route then you can get the VirtualBox add-in for Linux here. https://www.virtualbox.org/wiki/Linux_Downloads Your next stop is to pick up a copy of Windows. An older version will likely work just fine for your needs. Look here. https://winworldpc.com/product/windows-nt-2000/final CHIRP will run on Linux. Some instructions are found here. https://chirp.danplanet.com/projects/chirp/wiki/Running_Under_Linux Good luck.
I have an FT-817 and the included 6M antenna sucks. You realize for a 1/4 wave 6M antenna the required ground plane radials need to be about 60 inches long. The body of the radio is nowhere even close to that. Now holding the radio, well now your whole body might function as a sort of ground plane but the vertical element is still a crappy very short loaded helical design with high losses. Does the antenna radiate, yeah, but poorly. There is a reason why you don't see a bunch of HT's with the 6M band included. Most 6M activity is during band openings and then it's typically on sideband anyway, not FM. I just check "repeaterbook.com" and there are a total of just 15 6M repeaters listed for the entire state of Michigan for example, it's not that popular for FM, at least around here.
Those radios use an RJ-45 style plug I believe. I would check the connector that plugs into the radio. All the contact fingers should be clean. You can try to wipe the contacts down with alcohol, the programming cable, and use a Q-tip to do the socket in the radio. Sometimes gently bending the contact fingers out a tiny bit helps if you can get to them.
The antenna efficiency of an rubber duck 6M antenna on an HT is going to be really poor. Unless you plan on using an external 1/4 wave antenna with a ground plane it’s more of a marketing gimmick. The 2M VHF rubber duck antennas I’ve seen where it was stated as a negative 5 db gain in some cases too. A 1/4 wave UHF antenna for Ham 70cm and GMRS is about 6 inches long. That’s small enough to fit on an HT where the body of the radio is just about big enough to make a reasonable ground plane. Even better when holding it. I made a 1/4 ground plane antenna, with radials, using some heavy buss wire and a PCB BNC socket. The measured 2:1 bandwidth covered almost the 430 to 470 MHz range with a nearly perfect match around 448MHz. Good enough for Ham and GMRS. I used the antenna zip-tied to a baseball cap while walking around the Dayton Hamvention a couple of years. That let me hang the radio on the belt using a short jumper cable and speaker mic. I only needed about 1 watt for good communications with the antenna up in the clear. I might have looked like a nerd but I wanted something that worked, cheap and simple to build.
IF range was only determined by power then your range varies by the square root of the two powers. For example comparing 45 watts to 15 watts you get: sqrt(45/15) = 1.73 In other words your range should increase by a factor of 1.73 going to 45 watts verses 15 watts. There are other factors that will conspire to reduce this. You need to pay attention to the cable between the radio and the antenna mount. The RG-58 cable that’s typical used is fairly lossy at UHF. The loss can be compensated for by using a gain antenna. High gain antennas have their issues so they might not be a good fit for your application. If you mainly operate in very hilly or mountainous terrain a simple 1/4 wave antenna likely will work better. For flat open terrain a high gain antenna performs well. There are a few antennas that require no ground plane allowing more options on mounting locations. Some of the other forum members likely have some good recommendations for this type of antenna. A few people even keep more that one type in the vehicle and swap them out depending on operating requirements. Maybe a high gain one for use in a convoy while travailing on a highway then a short 1/4 wave for off road use.
Yup. The D74A is a nice radio. I also got mine from HRO and had them do the MARS/CAP mod for the same reason. The only negative is the battery pack capacity, it doesn’t last that long.
https://en.wikipedia.org/wiki/Superheterodyne_receiver
Yeah, check it out for the specific radio you're looking at buying. With all the features radios have now it's easy to overlook a detail like this and end up with something you can't use and paid a premium to get it. Some of the Ham radios include a feature called "APRS". You can get the details of what that might do for you here: http://www.aprs.org/
Transmitting in VFO/Frequency Mode - Possible?
Lscott replied to htims05's question in Technical Discussion
The rules are written the way they are because the underlying assumption is the user is a non technical person who has no idea what the difference is between Hertz and Hurts. The rules are designed to prevent interference to other services regardless of how a user manipulates the radio’s controls, either deliberately or by accident. Hams are held to a higher technical standard, and assumed to know where the bands are located frequency wise. There are few out there that would be challenged using two soup cans connected by a string, it’s not a guarantee somebody is competent just because they have a Ham license. It’s not a perfect world. -
A number of people recommend the FT-60R. About the only thing it doesn't have is GPS. A number of radios that have GPS it ONLY works in the digital modes. So if the others in your party don't have similar radios it's sort of useless. Plus the GPS function simply TX's position messages that are displayed on a compatible radio. Again if the others don't have such a radio, that can display the text messages, the feature isn't going to be useful. Before spending the money you need to check into this very carefully or you'll end up with a nice radio with GPS nobody else can take advantage of on the air. https://www.yaesu.com/indexVS.cfm?cmd=DisplayProducts&encProdID=6EC43B29CEF0EC2B4E19BB7371688B7F Brochure. https://www.radiotrans.com/archivos/catalogo/FT-60_EN.pdf On line sellers. https://www.hamradio.com/detail.cfm?pid=H0-007323 https://www.theantennafarm.com/catalog/index.php?main_page=product_info&cPath=115&products_id=432 For the RX/TX frequency expansion. If done by HRO they will warranty the radio. https://www.hamradio.com/detail.cfm?pid=71-002354 https://www.theantennafarm.com/catalog/index.php?main_page=product_info&products_id=417
I think gman1971 can answer that. He's pretty much the Motorola expert on the forum. He's help me out with some issues with a few XPR6550's I recently got.
Per the FCC rules they state the following: https://www.ecfr.gov/current/title-47/chapter-I/subchapter-D/part-95 "§ 95.1761 GMRS transmitter certification. ..... No GMRS transmitter will be certified for use in the GMRS if it is equipped with the capabilities to operate in services that do not require equipment certification, such as the Amateur Radio Service. All frequency determining circuitry (including crystals) and programming controls in each GMRS transmitter must be internal to the transmitter and must not be accessible from the exterior of the transmitter operating panel or from the exterior of the transmitter enclosure. " Yes there are radios that "allow" FPP, front panel programming, but with conditions. Many require a deliberate hardware modification, typical diode, resistor or solder shunt removable, and enabling in the radio's programming software. Others require entering a "secret code" to switch operating modes, typical of the Chinese radios. So, as long as the radio is configured to comply with 95.1761 it is operating under GMRS rules it's legal. The moment this is violated you're not compliant so the transmitter is now operating with illegal functionality and loses it's certification, even if it isn't being used. Of course it can be switched back, in which case the radio again would be in compliance, and the certification once again applies if it had it to begin with. My Kenwood commercial radios can be modified for FPP, needs the hardware mod and the feature enabled in the software. There is a warning that radios MUST NOT be returned to the end user(s) with FPP feature enabled, so it's disabled in the software with the modified code plug written to the radio. Of course if the radio is ONLY going to be used on the Ham bands it's not a problem. The problem revolves around the last sentence quoted above. Some feel just because the feature is there then there is no issue with enabling it. The FCC is clear that's not the case. There is no mention that one must be using the feature, the mere fact it's "possible" to access through some action(s) performed by the user is enough to void the certification. This includes changing the "mode" though any means accessible by the user external to the radio, such as pressing a sequence of buttons etc. during power up or any other time. There is a VERY fine line with switching modes through a sequence of button presses. There is a reason why it's NOT documented, at least for anything an end user gets to read. The user isn't supposed to even know about it. This could be considered a violation of the above section of the FCC rules. If there is any debate it would be over this point alone. Everything else is fairly clear cut IMHO. -
KG-905G Disappointing Short Distance Test
Lscott replied to fillmoreranger's question in Technical Discussion
Don't forget about the effect from the apartment's building materials. If you have cement walls there is likely rebar in it, wood and brick may have foil backed isolation in the walls, metal tint on the windows, high lead content glass, metal blinds etc. Some newer construction has sheet metal wall studs in place of the old wood ones as another item. There is a pile of construction material that can screw with a UHF signal. The building where I work has two of the above, poured concrete walls with a loose metal mesh and the office walls have metal studs. Needless to say the reception is rather poor for weak signals for anything other than a signal a mile or so away, and trying to TX is worse. -
"Hedy Lamarr style" - Frequency Hopping
Lscott replied to MichaelLAX's question in Technical Discussion
Oh, if anybody is interested in that book I mention in a prior post you can download a PDF copy from here: https://dokumen.pub/qdownload/tapr-spread-spectrum-update-tales-from-the-rebel-alliance-9780964470750-0964470756.html- 21 replies
- raddioddity gm-30
- pofung p15uv
(and 1 more)
Tagged with:
We don't have to agree, but the discussion was beneficial for those that choose to just sit back and read. If it got people to think about other points then it served it's purpose. 8-)- 21 replies
- raddioddity gm-30
- pofung p15uv
(and 1 more)
Tagged with:
Frequency hopping IS a form of spread spectrum transmission. Regardless of what algorithm is used to determine the next frequency hop some communication needs to take place between the two radios so they remain synchronized. Otherwise the RX radio would need to monitor several frequencies and try to "guess" where in a fixed sequence the TX radio is currently. I did read about some radios used during Vietnam that used encryption, and I think some form of FHSS, and wasn't well received. The chief complaint was the delay in decoding the audio and for the radio's to sync up. The second(s) delay was critical under battle conditions where rapid communication was necessary. https://en.wikipedia.org/wiki/AN/PRC-77_Portable_Transceiver Types of spread spectrum modulation. https://en.wikipedia.org/wiki/Spread_spectrum- 21 replies
- raddioddity gm-30
- pofung p15uv
(and 1 more)
Tagged with:
Comments on commercial radios for Ham use, analog/digital.
Lscott replied to Lscott's topic in Amateur Radio (Ham)
Since I don't really need the radios for critical communications I can afford to wait for a good deal. That's part of the fun collecting them, finding a good deal. The second part is trying to discover where the radio came from originally. I managed to find this out on just a few. The best one came from "Nine Mile Point Nuclear Station" out east. I think another poster knew about it and commented they replaced all their analog radios with digital. Nice confirmation of what I figured out from the names in the memory tag fields and frequencies programmed in to the radio. -
It's different because it happens under automatic control and is an intrinsic feature of the transmitter's frequency and modulation circuits, and not subject to operator control on a per frequency hop, nor even what the hop pattern that's implement, fixed or pseudorandom.- 21 replies
- raddioddity gm-30
- pofung p15uv
(and 1 more)
Tagged with:
