107
Everything posted by Lscott
See attached file for the KPG-91D. So far I don't have a copy of KPG-66D yet in my archive. The install serial is in the archive file. Normally the "E" versions are for European radios and the "K" is for US. Sometimes the "E" unlocks all market versions. The later "K" version may lock you into using narrow band FM. Just have to try it. KPG91D-V2.13.zip Serial Number.txt
You can get a decent dual or quad channel scope from Rigol or Siglnet. https://www.rigolna.com/products/digital-oscilloscopes/1000z/?srsltid=AfmBOoq2bRx15El9ycZvSSCi6OgpdDeIvbIipWFNl2DJeCLXNXmRZwKT https://siglentna.com/digital-oscilloscopes/sds1000dl-series-digital-storage-oscilloscopes/ Myself I have my eye on a spectrum analyzer. Either the SSA3032X or the SSA3032X Plus. https://siglentna.com/spectrum-analyzers/ssa3000x-series-spectrum-analyzers/ https://siglentna.com/spectrum-analyzers/ssa3000x-plus/
In that event you won't be worried about the FCC rules, you'll be too busy running from the zombies to care.
Part 95.1761 seems to say if you had a radio certified for Part 90, for example, it would also be OK so long as it's programmed to comply with the rules for power, frequency, and bandwidth on GMRS. This is one where you can go down the rabbit hole over if that's the case. Several years ago I had asked about old Part 90 VHF radios on MURS. Since some of those were certified before MURS was created so they could be grandfathered in, again so long as they were programmed to meet the frequency, power and bandwidth specifications. For Ham gear there is no transmitter part certification so on the face of it such gear couldn't be used even in the gray zone of the rules.
Looks like a good bit of the cost savings was doing away with the traditional controls, no knobs - push buttons etc. That means everything has to be done through the touch screen. Tiny menu settings and fat fingers don't make for a pleasant operating experience.
I've standardized on BNC wherever possible. You can usually find and adapter for some weird RF port to a BNC. For example I have a few Icom HT's that use a rather strange port. I had to special order adapters so I could use an external antenna with them. https://forums.mygmrs.com/gallery/image/500-ic-f3162dt-front-and-back-sidepng/?context=new BNC jumper cables are easy to find. As long as they are kept short the usual RG-58 coax doesn't cause much of a loss.
Then add in network linking things get more involved. My pet peeve with DMR repeaters are the frequency of changing of supported talk groups and networks. Some are rather extensive systems. See attached file for an example. I've spent hours reworking some of my DMR radio codes plugs due to changes. Then a few weeks, or months later, it's all changed around again. Further trying to find the current configuration may not be easy. Some repeater owners/operators just changes things and don't document it. Some I've just given up on, too many changes. While I like DMR the frequency of changes, and no coherent place to look for them, takes the shine off the mode. In fact it could turn people off to using it altogether. N8NOE.pdf
True. But if you have young kids involved trying to remember complex instructions, codes phases etc. then encryption is just the simple set and forget solution. Yeah, digital signals are not that present to hear mostly. However low baud rate audio frequency shift radio teletype can have a bit of a "musical" rhythm to it.
First order of business is do some research on-line, see if anyone else has tried it. If so after reading reading the procedures you might change your mind, or go out and buy the required test equipment and give it a try. Also you'll need the service manual(s) for the radio to study before you even start. Just remember the "Golden Screwdriver" has killed many radios when used by unskilled/unknowledgeable hands. The worse that can happen is you get a non-functional radio. Which is basically what you have now anyway since it won't work on the frequencies you need.
Some people just like their privacy, that's why they want it.
There are a few encryption options recognized by various manufactures. The typical digital encryption requires a radio with a native digital voice mode, usually DMR, NXDN and P25. One already mentioned was AES256. Some include it for free, Anytone does this, while others charge a lot of money to install it on the radio as an option. Then you may need a special bit of software, and or hardware, to function as a key loader. Another one is the 40 bit RC4, or ARC4. It's a much weaker algorithm, but good enough to keep the scanner guys away for a while. It's also included for free on some radios. Others it a fairly cheap option to add. The keys are typically loaded through the radio's programming software so no additional software or hardware key loaders are usually required. You're more likely to find more radios that have have RC4, or an option to install it, than some of the others out there. This is a point to consider if inter-operation between various manufactures is a requirement. Note that encryption is a No-No on Ham and GMRS in general. However a few people have radios programmed with licensed LMR frequencies where it's legal to use on those.
Utilizing GMRS vs Ham repeaters for a newbie!
Lscott replied to WSJF256's topic in General Discussion
I have a buddy who did that on some public safety frequency using a Baofeng while mobile some years back. When he told me I got him to stop explaining it was the quickest way to get nailed. Now he’s now a licensed a Ham and has his GMRS one too. He’s very happy with both now. He showed me an article in the local town paper a year or so later where his actions were used to justify moving to a digital radio system for the affected agency. Plus it went on to say the FCC was actively DF’ing his signal at the time. He’s lucky. -
Yes. That was similar to the remark by the VE I had talked to. He said it was a technical rule violation, BUT the FCC would simply ignore it and no action taken. I guess I should have explained it better. There is what the rules say, then there is what really happens in practice. -
Most people would point out emergency communications. However there there are some specific requirements that must hold. In the end it's still up to the FCC if they think the transmission was a rule violation or not. So, the safe answer is no. I had a short discussion about this with a VE once. He said it was a question people frequency got wrong. I even thought it was OK. The sections in the Part 97 rules I found makes no mention about unlicensed operators using an amateur stations in an emergency. https://www.law.cornell.edu/cfr/text/47/97.403 https://www.law.cornell.edu/cfr/text/47/97.405 -
If you and all of your buddies don't have Amateur licenses then NO you can't use the Ham repeaters under any condition. If you and all of your buddies don't have a GMRS license, or operating under the license of a qualifying family member, then NO you can't use any GMRS repeaters either. Messing around on the Ham repeaters will likely get you nailed fairly quickly. Why? Because Hams have a sport they call "Fox Hunting." Some are VERY VERY good at it and have some expensive equipment specifically for direction finding use. It's a popular sport. https://en.wikipedia.org/wiki/Transmitter_hunting https://www.arrl.org/direction-finding The guys with the Doppler direction finders can get a directional fix in seconds with a decent signal. It's very similar to the old "LoJack" system used by police. https://radiodirectionfinding.wordpress.com/wat-is-een-amplitude-rdf/ -
As an example. One would think in a modern country like the UK monitoring like we do here, basically everything, is legal. Nope. https://www.monitoringtimes.com/html/mtlaws_may04.html
You would be shocked to see how many people don't know this fact. I can imagine US tourists using their FRS radios while the ship is docked in a foreign port and those frequencies are used by the local fire and police.
Not all Kenwood radios you can program out of the official band split. One notable example is the NX-411. That radio can be used on the Ham 33cm band. The programming software simply won't accept the out of band entry like most of the other KPG radio programming packages for Kenwood. This particular radio required hex editing the code plug. I wrote up the procedure and posted it on another forum. A fellow Ham, a computer professional, used that to write a custom utility to automate the process. Oh, hex editing is your only option if you're stuck with any of the Kenwood "ProTalk" radios. Those allow ONLY a limited selection of discreet frequencies to be selected in the programming software. The hex editing process is similar to the one used on the NX-411 I mentioned. That's why I stay away from the "ProTalk" models no matter how good the deal, price, looks. Not worth the trouble, unless you plan to program it once and never touch it again. How to Hex edit Kenwood code plugs - 20241011.pdf
I thought I read somewhere the audio popping was due to the DSP core on the radio chip switching digital gain control settings. Apparently some manufactures have figured out how to mitigate the problem. The attached files are for the ROC, radio on a chip, used in the UV-5R radios for reference. Note other well known radios use a similar radio on a chip design, but with much better front end filtering etc. Examples are the Motorola XPR7550's which some won't use anything else, and the newer Kenwood NX-1K series. RDA1846 - Edited.pdf RDA1846 Programming Manual.pdf SCHEMATIC Baofeng UV-5R.pdf
Oh well. Don't feel bad some of us are engineers, and have an excuse for poor spelling, but we can do Math OK: 1 + 1 = too.
I can't say with any degree of certainty that mounting the antenna over the solar panels will result in any negative effects. My point was to mention there could be some. The sure test is try out a temporary installation. That could be as simple as a magnet mount sitting on the cross bar while parked. If there is any issue with the charge controller it should show up as soon as you key up the radio at high power. You would monitor the output of the charge controller for any anomalous behavior. I have a couple of these to monitor the output of some panels I have and the charge going into the battery bank, or discharge out of it. If you don't have one I highly recommend you get it for testing and monitoring. I got the version with the Anderson Power poles. They also have them with the MC4 PV panel connectors too. https://powerwerx.com/watt-meter-analyzer-inline-dc-bare-wire https://powerwerx.com/watt-meter-analyzer-inline-dc-powerpole https://powerwerx.com/watt-meter-analyzer-inline-dc-mc4
That could be a rather interesting install. The solar cells are basically diodes so I'm not really sure how that would affect any RF that would reflect off them, if at all. Then there is the issue about any RF getting into the charge controller, oops. The cells might tend to rectify the RF. The rectified waveform would be rich in harmonics so there is a remote chance the installation would be a rolling RF interference generator. I know some have tracked down very strange RF noise issues which were later found out to be caused by rusted metal junctions, again acting like a diode, on a tower generating the harmonics. Yes this can happen. In WWII GI's made "Fox Hole" crystal radios using a razor blade for the diode detector. The metal "cat whisker" on the blue coating, which is really an oxide of iron, formed the PN junction.
I’ve also tried it on various Kenwood HT’s. Some you can “push” to operate way out of band, others not so much. For example I have a NX-320 450-520 band spilt radio. The PLL won’t lock below 443 when I tried out a sequence of test frequencies. It does seem, from my experience, the narrower the band spilt the better luck you have running farther outside the official range. If a radio is available, some come in various band spilts so be VERY careful, with the 400-470 band spilt that’s perfect for Ham and GMRS. This seems to be more frequently found with the FM/Digital mode radios. Those are the ones I watch out for on my favorite auction site. Of course you can’t use digital voice on GMRS, at least not yet so you’re stuck with FM, but perfectly legal on the Ham bands.
Or keep it and use it for spare parts that are common with the 880-1 version. Sometimes finding spare parts for old radios is nearly impossible. That's why a few guys keep junk chassis's around to pick over.
