About KevinJ
- Birthday 06/11/1986
Name
Kevin J
Unit Number
Location
Indiana
Interests
Serving my God and Lord and Saviour Jesus Christ, my wife and children, and my community. I joke that I am like a modern renaissance man in that I am a jack of all trades but a master of none and l believe all good men should be.
KevinJ's Achievements
KevinJ reacted to a post in a topic: Map of all repeaters that hit a given point?
Looking for recommendations on mobile units/setups
KevinJ replied to WSEK693's topic in General Discussion
I won't tell you because I don't have much experience yet with gmrs mobiles, but I have two ra87s I'm setting up as a local private repeater (at first) and although I haven't used them I was pleasantly surprised with the quality and feel you get for the price, you can buy the repeater "core" set, just two mobiles and the data cable, usually on eBay for about 300 bucks! But I really want to get my hands on a couple few(or more) of the wouxun kg1000g plus mobiles. There are quite a few more affordable than the kg but I hear it's the "creme de la creme" of gmrs mobile units. I just never, NEVER see them on sale like I see almost all the other brands on sale. -
KevinJ reacted to a post in a topic: Line of Sight vs Power.
What Gives? Why Is The CA-712EFC Perpetually Out Of Stock?
KevinJ replied to tcp2525's topic in General Discussion
I have noticed this, several sites list a later this month date for next shipping batch, but they all do seem to be purchasable/backorder-able as they still have a clickable add to cart button. -
KevinJ reacted to a post in a topic: I have a duplexer mounting question
KevinJ reacted to a post in a topic: Repeater Linking??
so if this happens is the unit junk? or is it serviceable/repairable? Should I check it periodically when I get it all together and running? Or is it something that I will know because it just stops working or works very poorly? Mine is a Jiesai?(weird label design) model SGQ-450K strait outta Guangzhou CHYNA
Hello everyone, I hope you are all having a good evening after a good day! I have been looking for a few weeks now and googling and searching the interwebz, and I can not find information on duplexer mounting do's and don'ts. I want to know what options I have for mounting/securing my duplexer. I will use two ra87s in a powered desktop cabinet made for them that comes as a kit. But how far apart should the duplexer be from any electrical devices including the radios? Do I mount it vertically or should it be lying down? I read somewhere that changing their orientation from how it was sitting when tuned can cause them to change their tune slightly. It is an 8-cavity cheap Chinese notch style. I was either going to make a stand and mount it vertically above and behind the radio set, or possibly make a small cover-like shelf and then bolt the duplexer to it in a flat horizontal position either on the top or even upside down underneath the top of said cover/cabinet. I am just trying to reduce any interference it may get from household items and appliances as well as making sure I don't accidentally mess the thing up and have to get it re-tuned or replaced.
KevinJ reacted to a post in a topic: I need help with antenna mounting options/ideas
TrikeRadio reacted to a post in a topic: I need help with antenna mounting options/ideas
SteveShannon reacted to a post in a topic: I need help with antenna mounting options/ideas
KevinJ replied to KevinJ's topic in General Discussion
I wanted to thank all who replied or even viewed this thread, due to the fact I rent and all other things considered, I am more than likely going to use a non-penetrating type roof mount. They are not expensive, I can easily get one onto the garage roof, and I'm certain I am resourceful enough to build my own and maybe even improve upon the simpler designs I have seen. I will keep all the information I have been privy to hear today! Thanks again to all! God bless and have a wonderful day! -
Thanks for the heads up, that's actually what I was thinking after I zoomed into the photo on my phone after making this post. I may have to go with some sort of weighted non penetrating mount, something like the Baird's. I could easily place one on the garage or porch roofs without even needing ladders. Alternatively I see a wall mount Baird makes that I could bolt to the side of the garage, whatever option I choose I am trying my hardest to get the base of the antenna at least level with the top of the peak of the house or preferably a few feet higher, while doing the least amount of permanent modifications or damage to the house as I do rent not own. -
That is a magnificent mast friend! How tall is that mast w/o the antenna? How much does that weigh combined? is it guyed? (it doesn't appear to be in the photo but want to be sure). Is there a way to test or verify what I can mount to my chimney? The last question, Did you ask yourself any of these things first or did you just choose a mount, a mast length and then got er did? A BIG QUESTION TO ALL: Should I have it grounded for lighting? -
I have seen some chimney mounts that are really catching my eye, probably be easier over all to get up there and do that myself vs needing to rent or hire a bucket truck. If I put the mount just below the pitch(point?) on the gable(side of house?) it would be about 6 ft above the lines plus any mast height, but using a penetration less weighted roof stand or a chimney mount seems to be the best options so far. -
To be clear, when I say J pole, I am referring to the mount style/system, NOT the antenna type. J poles or just J mounts are the ones the dish TV companies use to attach the tiny dishes to the sides of structures and stuff. One of the antennas I was looking into is this one in the video below. -
Well my neighbors a few houses down have what I believe is a 40 footer that is standing unused. I wanted to ask them if they would be interested in having it removed, but my issue with that is I don't know who to find to put it up here, especially when it will have to be put up between the lines and the house. A j pole sounds best and easiest to keep it on my side of the duplex I live in. Has anyone ever mounted a J pole with masonry hardware to a chimney? If I use the side, I will have to mount it in a way that clears the over hang. The antenna I wanted to pick up is made by a guy named Steve(?memory) he posted a video about the best antenna(?memory again) and he sells them, he goes over a lot of tests and it seems a very legit antenna to use and not very expensive at around 130ish. -
I've seen those used, and was definitely a thought. My biggest concern is whichever I use, is how I'm gonna get the blasted thing up there. Those lines are not even more than 3 ft or so from the side of the house. Real tight work area. My one idea so far is a boom style lift or bucket truck to lift over the lines and attach it to the very tip. I seen a j pole style that's about 4 ft long. Thanks for the info! My uncle has one of those dish mounts he said I could have! -
Okay, so I need advice on where and what method(s) I have available. I've looked around and seen to see some roof mounts that work, but not sure. I will post a photo of my apartment/house so you all can advise. I would like to be able to clear the trees but if I cannot, just as long as I can get it above the roof, I will be happy! ADDED FOR CLARITY:Below is a link to the type of mount I am speaking of when I say J pole/J mount. Like this.... https://www.amazon.com/Skywalker-Outdoor-One-Piece-Mounting-Diameter/dp/B01MSFGZIW/ref=asc_df_B01MSFGZIW?tag=bingshoppinga-20&linkCode=df0&hvadid=80814156492394&hvnetw=o&hvqmt=e&hvbmt=be&hvdev=c&hvlocint=&hvlocphy=&hvtargid=pla-4584413735935415&th=1
JBRPong reacted to a post in a topic: Local repeaters
Raybestos reacted to a post in a topic: Local repeaters
LeeBo reacted to a post in a topic: Local repeaters
same here, requested 4 nearest me when I joined, but only 1 has responded at all, basically just use it if it's listed as open and the tones are there to access it, just announce yourself and thank them for the use, it usually goes well.
WRXB215 reacted to a post in a topic: Official Method of asking for permission?
TrikeRadio reacted to a post in a topic: Official Method of asking for permission?
WRXR255 reacted to a post in a topic: Official Method of asking for permission?
WRUU653 reacted to a post in a topic: Official Method of asking for permission?
SteveShannon reacted to a post in a topic: Official Method of asking for permission?
GMRS Transitioning to Hobbyist-Type Service?
KevinJ replied to intermod's topic in General Discussion
As a member of not just the radio/coms hobby/community, but also the guns and cars hobby/communities, I gave this line a standing ovation and IMHO am dubbing it "Best quote I have ever read on an internet forum to date" -
The best answer I have received on this question is, if the tones are listed, and it's set to open, it's almost always a go-ahead, but never hurts to ask or give thanks when using the repeater. As I was told when I asked most people tend to want you to use their repeater if its status is open with the tones listed. I did just that, I programmed my handheld, and the next time I was near enough, I announced myself and asked for a radio/mic check and also thanked the owner of the system. Have not had any problems or anything as of yet.
