WRCZ387
2
Everything posted by WRCZ387
Antenna Recommendations for Apartment
WRCZ387 replied to Daedalus0101101's topic in General Discussion
Maybe these will help: https://www.jpole-antenna.com/shop/462-mhz-land-mobile-gmrs-j-pole-antenna/ You'll need to buy coax for it https://dpdproductions.com/collections/gmrs-base-mobile-antennas/products/gmrs-blade-indoor-antenna Comes with 18' of coax -
It probably would Awhile back someone was using DMR or some other digital mode on .700 in the Tampa Bay area & it made .700 unusable I used to hear P25 on another repeater, but that wasn't that often, that was usually the repeater owner & anyone who has P25, I don't think that many users do, I have a P25 capable h-t, but I'm not going to use P25 I could be wrong, but there would probably need to be a complete switchover to digital, or separate frequencies mandated for analog & for digital for things to work with no interference
WRCZ387 replied to Lscott's topic in Multi-Use Radio Service (MURS)
Alinco DJ-MD5T programmed for GMRS, MURS, NOAA receive, rail receive Alinco DJ-500TB programmed for GMRS, MURS, NOAA receive Alinco DJ-A10T programmed for MURS, NOAA receive, rail receive Icom IC-F50IS programmed for MURS, NOAA receive, rail receive [this is the h-t that I use at work] -
You're welcome 73
http://www.hamradiolife.org/icom/icomcps/cs-f-500_V2dotO.zip If he needs to buy a cable, go to bluemax49ers.com, use the software advisor to look up what he needs, they sell two cables, FTDI & prolific, he can download version 2.3 of the software from there also Hope this helps 73 Edit: I apologize for the poor typing, I slept in due to the hurricane, just got up, no caffeine or sugar yet, ugh
what is the best 40 to 50 watt mobile radio for severe rf environments?
WRCZ387 replied to piggin's question in Technical Discussion
You may want to look at Used-Radios.com™ for a radio or radios, they'll program up to 16 channels for you to get you going Then BlueMax49ers - Beyond Cables That Work! for cables & software so you can add to/edit your channels down the road If you see a rig on Used Radios that interests you, you can check the software advisor on Blue Max 49ers for compatible cables, available software & pricing before you buy the radio I have been getting into Icom commercial h-t's, I know other users like Kenwood & Motorola, nothing wrong there, everyone has different preferences, needs, tastes, etc I have a couple of Part 97 amateur h-t's that I switched to commercial mode, but I'm treating those as backups, I prefer my actual Part 90 LMR's, I have & like both Alinco & Icom Although I do have, & like the Part 95 Alinco DJ-G46T GMRS h-t also 73 -
I would have ordered one for my work h-t SO fast.....
Amateur radio maker getting into the GMRS market.
WRCZ387 replied to WRUI365's topic in General Discussion
Call or e-mail Remtronix & ask them to e-mail the software to you I have a loaner unit to test & they e-mailed me a copy of the software You'll need an Alinco ERW-15 USB cable, or, the RT Systems USB-29A cable also works, that's what I used, the cable terminates in a 1/8" stereo/two-band plug I used it today in the car with a 1/4 wave NMO mag mount, it sounds great on receive, it has a clear speaker, I was told the transmit audio is good I'm going to give it more of a workout this week, both in the mobile & portable with different h-t antennas -
I saw that, the PMR446 & A10/A40 series probably have common roots https://www.alinco.com/Products/bis/DJ-A10/DJ-A10_40.pdf -
I believe that it is superhet, it's based on the Alinco DJ-A446 PMR446 h-t https://www.alinco.com/Products/bis/DJ-A446/DJ-A446.pdf If you have DJ-500 series/DJ-MD5 series/DJ-A10/A11/A40/A41 series, the batteries, chargers, DC adapter, etc are compatible I've corresponded with Remtronix & they said that Alinco is gathering info for features for a GMRS mobile I have 6 Alinco Part 90 h-t's, both mono-band + dual-band, & I've had good luck with them -
Just because you can, doesn't mean you should
I just looked at the CHIRP supported radios list, it's not on there
Nope, nope, nope, nope I enjoy my QSO's on GMRS, I'm good with those I actually have no interest in conversing with train engineers, boaters, cops, firefighters, etc Maybe in person, not on the radio I'd rather spend my $$$ on radio equipment, not FCC &/or civil fines thank you very much
Just curious, like the OP, why did you pick 151.625 originally to program into your radios? There are various frequency lists posted on the Net for preppers, SHTF, etc, Red Dot & Purple Dot were on the lists Most of my h-t's have the capacity of storing 128 channels, [1] has 199 channels, [1] has 4000 channels, so when I first got into GMRS a few years ago, I went all out [yes, crazy] on programming for every which way I thought that I would need, or might need Now, I've read a lot more [thanks to everyone on mygmrs & radioreference], I'm a little more knowledgeable, & I'm more responsible on what I have in my rigs I do have the NOAA frequencies, & [3] local rail frequencies programmed in, but I make sure that they are on 'NO TRANSMIT' before I unplug the h-t from the pc, let alone before I leave the house
I had 151.625 MHz programmed in my h-t's for "just-in-case" or "just because" But then I gave it some thought, considered the fact that it's a business band frequency & I decided to delete it If I can't communicate on FRS, GMRS or MURS, forget it
It's based on the IC-F21 commercial model, so I'd say it is a robust radio, but not to the tune of $150.00 I lucked into a used one a few months ago for $49.00, I replaced the OEM antenna with another one [the original was starting to deteriorate], I need to get a NiMH battery for it, it came with a 600 mAh Ni-Cad I have a programming cable that fits anther Icom & found the software online, so I reprogrammed it to my preferences, since out-of-the-box, channels 1-8 are repeaters, channels 9-15 are the 462 MHz interstitial, & all channels are set to narrow band, so I tweaked it a bit Programming it with multiple key/PTT presses? No thank you If you're an Icom aficionado, & want a Part 95 h-t, I'd say get one, but I wouldn't pay more than $50.00 max depending on it's condition & what accessories it has, just my .02 cents 73
You're welcome I would start by searching those models right here on myGMRS, check out the opinions+experiences of other users, plus read the user reviews on the radioddity & buytwowayradios web sites GMRS is getting more popular, word is getting around about it Some people use it for off-roading, some use it for family comms, some users are going on to chat & make friends, for some users: all of the above I watched two YouTube videos a couple of years ago about a town in California where the residents are using GMRS for communicating with each other before/during/after wildfires I think that the usage is going to depend on the area, whether it's ham or GMRS Just tonight I was discussing ham radio usage with someone who uses both ham & GMRS, in this area [Tampa Bay, FL], the hams seem to be using 2 meter simplex more than the repeaters unless it's a net, the same may be happening in your area, there's more simplex usage vs the repeaters It's an obvious point, but I'll say it anyway, no matter which radio you choose: antenna-antenna-antenna, it will make you or break you, whether base, mobile, or portable/hand-held With GMRS being UHF: height is might, get your base antenna as high as possible, & use quality coax so you don't lose too much of your signal between the radio & the antenna, especially if you're going to use h-t's for now, you want as many of your 4-5 watts to get to the antenna While I'm thinking about it, you may or may not want to replace the stock antennas on your h-t's, you'll have to test your situation out & see what results you get 73
Hey, I'm all for cheat sheets; I have no ego, pride or vanity to bruise I always say: "I know just enough to get me in trouble"
The only parts that I remembered clearly are h-t's only & 0.5 watts only on the 467 MHz interstitials I still have my h-t's set at 2-2.5 watts on the 462 MHz interstitials I guess that I need to do my homework
I stand corrected, I just went & reread the rules, my goof I either misread something somewhere, or I was thinking of pre-2017
Yes. GMRS operates on UHF & uses a +5 MHz offset. Most of the time, but not always, GMRS repeaters use tones for both the input & the output frequencies, I believe that amateur repeaters usually use a tone just on the input, but I'm not a ham, so take that with a grain of salt just in case GMRS h-t's are legally limited to 5 watts maximum output, mobiles, repeaters & base stations are limited to 50 watts maximum output I don't know how much you want to budget for your h-t. At the inexpensive end is the Radioddity GM-30 for $39.99 https://www.radioddity.com/products/radioddity-gm-30 If you want to go a bit higher in price, there are several Wouxun GMRS h-t's that are popular & have good reputations that start at $99.99 & go up from there https://www.buytwowayradios.com/wouxun-two-way-radios.html?tw_service=783 Both the Radiodditty & the Wouxun h-t's are repeater capable as well as simplex 73
Do you use the NOAA Weather Radio feature(s) on GMRS?
WRCZ387 replied to radiozip's topic in General Discussion
I do the same I have the NOAA freqs programmed in my dual band h-t's, & in my VHF mono band h-t's, they came pre-programmed in my Alinco DJ-VX50 I work outside, I'm in Florida close to the Gulf, from May to November I'd rather have them & not need them rather than be kicking myself for not having them, better safe than sorry I also have lightning/radar/weather apps in my phone for additional info/backup 73 & a safe summer to everyone -
They probably spent so much on weapons & etc that Baofengs are all that they can afford with what they have left
You just might have something there I just checked over at Signal Stuff, & they're out-of-stock on the 19" pink dual-band in BNC They must have had a run on those for some reason...... Do the Abree 42" tactical antennas come in pink? If not, can you spray paint them?
Looking for antenna upgrade recommendation.
WRCZ387 replied to WRWE456's topic in Multi-Use Radio Service (MURS)
Smiley Antennas [centered at 155 MHz] https://www.smileyantenna.com/category-s/1514.htm The Antenna Farm For mobile https://theantennafarm.com/shop-by-categories/shop-all/mobile-antennas/108-230-mhz-vhf/457-commercial-vhf-antennas For h-t https://theantennafarm.com/shop-by-categories/shop-all/hand-held-antennas/commercial-radio-ht-antennas/671-vhf-hand-held-radio-antennas/672-kenwood-vhf-antennas/13041-laird-connectivity-exh155sfk-detail 73
