GrouserPad
Everything posted by GrouserPad
Has anyone had luck using the manufacturer’s CPS (computer programming software) with the db20g? Program allows me to download from radio, and see the entire file, but it won’t allow me add PL tones no matter how I click the field? I’ve tried the keyboard, mouse and tried batch channel editing and nothing can be edited in the software other than the name of the channels. Am I missing something? Chirp is not supported yet with this radio far as I know.
TD-H3 transmitting but not showing up on SWR meter
GrouserPad replied to hxpx's question in Technical Discussion
Ok. BMS = battery maintenance system. Hard to keep up with acronyms sometimes thanks. -
Battery BMS? -
I’m not sure. It’s not my problem. I did nothing to them that should have made them fail. The very first tdh3 I bought still works today and it was programmed abd used identically as the other 4. And none of these were DOA. All worked out of the box. Then approx 2 to 3 weeks later I noticed issues hitting repeaters and at that point realize no output. So not sure when these failed after charging or after programming. -
A couple!?! Bruh I’m 4 out of 5 failure on these pos. -
Mine ALL transmitted out of the box. Then after a week or so quit hitting repeaters then I put them on the meter and nope.....wattage output is gone. Doesn't even register on the meter. . . .
My record with them is bought 5 sent 4 back for no output. The one working one is awesome though haha
Well shucks that is the first I have heard of the battery situation. Thank you for that. I ever buy another TDH three which is highly unlikely. I’ll keep that in mind very good heads up.
Don’t feel stupid. Ask your questions. There’s a great group of people here that are willing to help. A lot of this isn’t common sense knowledge and alot of the info online is hard to navigate for a newcomer.
Way to block TX on non-ham freqs 5RM/K5+
GrouserPad replied to UncleYoda's topic in Amateur Radio (Ham)
How about duplex? Will it let you set duplex to off ? my bad I just seen you were talking about in VFO mode. So disregard my post ! -
Wouxun KG1000+ Transmit sounds bad at high power
GrouserPad replied to GrayGoat's question in Technical Discussion
I get people telling me the same thing from time to time. With no mic gain you just need to talk softer or further away. A good habit is to never use more power than you absolutely need! Use low power for all wheeling situations. When I use my kg1000+ people say I sound over modulated but when my family talks on the same radio to me I think they all sound fantastic which makes me wonder if some types of voices don’t do well on the kg1000+. -
No Matter What The "Experts" Say You Simply Can't Do This With A PL-259
GrouserPad replied to tcp2525's question in Technical Discussion
Agreed, and I could replace a pl259 in the field with a soldering iron and a sharp knife. I personally could not do that with an N type. -
I’d still prefer a good ol’ pl259 connector myself. And just replace it at 3 year intervals. The 259’s hold up for years and years on some of the toughest heavy equipment in horrid conditions and transmit cb just fine. -
I haven’t successfully been able to change any privacy tones in channel mode on a uv5g pro. Hella frustrating. My uv5g’s won’t save anything I set into them from the keypad menu. I have heard deleting the channel, going to vfo, typing in the freq and entering the tones, then saving this vfo info into the save channel slot it can be done via radio keypad. . . Just heads up if maybe you’re trying to do it through the actual channel menu on the radio not in software.
Nahh get that antenna outside above the roofline and you’ll still gain ALOT of performance no matter what your topography is !!
Man I feel like the tdh3 IS a nice radio that would hang with radios 4x its price if the transmitter section wouldn’t crap the bed. Everything about the tdh3 is freaking awesome. But what’s the point of having a fully featured radio if this POS doesn’t transmit.
My 4 non transmitting tdh3’s all receive exceptionally well. They work great on receive. FWIW. -
@hxpx
I have tried everything from firmware, to reset, to ptt+Star+power on reset, to using cps, and chirp, and copying the files from my only working tdh3. Nothing fixed my transmit issue. The dead or no output radios will work a few hundred feet apart but they all register no wattage on my meter. Learn from me!!! Don’t waste your time on trying to get them to work. You won’t. I’ve wasted HOURS messing with mine and still no joy. -
Ok I see now, it was the PRIORITY SCAN(function 19) function that was causing me an intermittent receive cutout every 5 seconds or so when the radio would scan in the background for priority channel activity. This scan looks for whatever channel you select for the priority channel.
Nice choice on radio/coax/antenna. I really like those radios, only quirk is be aware if you set a background priority channel. Two of my 1000+ radios exhibited a faulty acting receive when a priority channel was set. It seemed to create a cutout every so often. Also, I've been using the latest version of Chirp to program mine and it's been working awesome. The CPS software is good to but for some reason my computer settings make the cps text awful to read so everytime i use the cps I had to fiddle with the gridfont in the settings tab to make the text look decent.
Yes I have a 50watt dummy load. I just now downloaded new firmware, and downloaded the Tidradio CPS off their website which I created an account to use. It wrote to the radio and I updated the firmware. Still not showing any wattage on the meter. I I programmed with a baofeng kenwood cable, a mirkit brand ftdi kenwood cable still no joy. I give up.
