OffRoaderX
    270
  1. So you'd need two different radios, or one radio with two different antennas to make use of these and the existing GMRS channels? Does not seem very user-friendly... If they are unused, throw 'em to the H.A.M.s.. they'll use it.. they'll use anything.
  2. You are correct that linking GMRS repeaters is not allowed but you are incorrect if you think that means there are no linked GMRS repeaters.
  3. I got sidetracked and never got to finish the quiz.
  4. This is correct - if you go this route, create a new FRN and buy a new license.
  5. Not to be a d*ck, but did you read the manual? Page 5 says: The only issue is that I think you need to have a speaker plugged in to hear it scan.
  6. No, it looks like there is now a GMRS version/flavor of the 5RM.. One is H.A.M.s radios, the other is GMRS.. So my earlier statement stands amended.
  7. What part is false/what are they claiming? When I look them up they just say they are H.A.M.s radios..
  8. Did you check the manual to see if that flashing pattern means anything specific?
  9. There is absolutely nothing wrong with the Midland Ghost antenna based on ACTUAL TESTS AND DATA that I have done (not based on "Some People's" opinion).. However as others have posted, the Ghost antenna form-factor may not be the best choice, but if you use it, it will perform fine as long as its not blocked/surrounded by any metal.
  10. Is a 5rm a GMRS legal radio ? : No - the 5RM is a H.A.M.s radios what’s the difference between a uv-5rm. And a 5rm: a UV-5RM and 5RM are the same thing. I assume you are asking about the 5RM vs the AR-5RM - the 5RM is locked and the AR-5RM is not locked. If my assumption was wrong, please elaborate. EDIT/UPDATE! -- There is NOW a 5RM GMRS version available in addition to the H.A.M.s radios version of the 5RM.. So look carefully at the description before purchasing.
  11. When someone is listening to you over the radio, the only thing they know about you is going to be your callsign, assuming you aren't an idiot and have not broadcast your full name for everyone to hear. So usually, over the radio, which is what the context of this discussion is, it is VERY difficult to look up someone's address without going through the FCC website.
  12. Wong.. again... Stalkers, haters, and other radiotards often look up FCC call signs to get home addresses.
  13. I *think* there is an FCC rule buried somewhere about not using repeaters without permission? But I will yield to anyone that knows/cares more about it than I do.
  14. They can complain to the FCC who, based on their record of enforcement over the last 15 years, statistically speaking, will do nothing.
  15. Correction: Based on the FCCs "enforcement" record over the last 15 years for H.A.M.s radios, GMRS, and CB radio, they apparently do NOT like to enforce their rules.
  16. CORRECTION: Not "illegal", but a violation of FCC rules..
  17. I know a guy here on this forum that regularly/ALWAYS gets 200+ miles on all of his radios.. He apparently does this by purchasing every radio ever made and if it does not get 200+ miles, he just throws it directly into the trash.. All of his "friends" also do the same thing, so this method obviously works.
  18. ...that can also receive VHF & UHF, including 70cm. But chances are he was a a GMRS channel and was hearing linked repeaters.
  19. "some people" are so funny, all trying to prove who's smarter over something that does not matter in any way - The FCC doesn't even care. "some people" should bicker over something that actually matters.
  20. Yah, that's what i thought.. I dont know if the OP as already installed the software, it had a driver issue, so now he's installing the drivers, or if he's just clicking willy-nilly.. When I installed the software the separate driver setup/install was not needed as you eluded to in your previous post. MrSig: Did you install the actual software, and ran into a problem with the drivers, and that is why you are trying to run the Driver Setup program?
  21. I dont know man, I am not such a petty control freak that i would care about something like that.. jeezus.. go outside and touch some grass.
  22. Charging for its use does not make it "commercially operated".. But, to (i think) answer your and the OP's question, it does not break any rules to charge for the repeater as long as its not "for profit" ..
  23. If that makes you sad, you should set up your own repeater so everyone can use it for free and teach them all a lesson.
  24. Often times there is no benefit to most people. When asked, I generally recommend to never bother with an update unless said update fixes some specific issue that you need to be fixed. "some people" often just blindly apply any update they come across and they sometimes learn the hard way that the risk of permanently brick'ing the radio is high.
  25. What is the name of the Executable file you are running when this happens?
