28
I'll give Btech credit for addressing one of the biggest usage complaints (ability to add additional tx channels), and it looks like they've introduced a few new features and accessories, like an adapter to use accessories with the k1 plug. That said, on the surface, it appears to be all firmware tweaks, without addressing those hardware shortcomings. I hope I'm wrong on that, and like Marc, wish buyers the best of luck. That warning about not using high power unless necessary would seem to point to not, though....more of a band-aid to get around the issues with the first version.
first question: yes, that's correct. i'll share a real world example from the ham side (on 70cm, which is nearly identical, signal wise, to gmrs), with the caveat that i don't do much (if any) simplex on GMRS, as the family has ZERO interest. using my base setup (which is a pair of mobiles and a base antenna in the closet) chatting with someone who lives in the next town up the highway via the local repeater, which is 23 miles from me. discover he's in town shopping at the moment, talking in on his mobile from a shopping center 25 miles from the repeater, and just 6.5 miles from me. i switched over to the repeater input to see if i could hear him, but not much beyond an occasional burst of static. i can hear the repeater clearly on a handheld inside the house, and can talk in with no problem from outside in the yard, but going direct just over 6 miles apart was no go. second question: hard to say on "reasonable"...is it possible? absolutely. it's going to be very dependent on height, but it's a little bit of a stretch to assume radio towers. some may be one of the users here, with a 5 watt Retevis 'repeater in a box' on a 20' top rail mast, or mounted on a barn. dealing with the high level stuff we have in CA, i've talked into a gmrs repeater over 60 miles out from the 3rd floor of a hotel with a handheld, and managed 75ish to a ham repeater in the same area from a high spot in the hills (basically clear line of sight over the valley), but those repeaters i'm working with are on foothill ridges at 3000-4500 ft above sea level. obstructions are the biggest challenge for a largely line of sight signal like gmrs. here's a quick edit to the diagram in the first post illustrating my example (though i'm using gmrs frequencies in the diagram, illustrating hearing via the repeater was no problem, but listening on the repeater input, no luck.
There are cables/interface boxes made to link 2 handhelds together. The problem there would the radio doing the retransmittimlng part can overload the receiving radio due to it's close proximity. This would cause this shoulder height repeater to be to hear you from a shorter distance than if you were just going handheld to handheld...while some are worse than others, and some handle adjacent frequencies better than others, almost any radio will desense to a degree to protect the receiver from a strong signal nearby. You can see the same issue when transmitting from one handheld to another in close proximity;the receiving radio sees an incoming signal, but doesn't receive any audio. As @axorlovsaid, there isn't anything magical about it, at the most basic it's a receiving radio connected to a transmitting radio. In practice, better filters against adjacent frequencies in mobile and repeater receivers help make it possible, as do things like duplexers that separate the transmit from the receive. Does that help clarify?
Static while in motion, roof mag mount
wayoverthere replied to WRVS497's question in Technical Discussion
I'll also mention the 'no ground plane' category for jeeps or less than stellar mounting situations...they have some 1/2 waves in the same price range And similar sizes, in black or silver, spring, polymer spring, or no spring. https://theantennafarm.com/shop-by-categories/shop-all/mobile-antennas/300-512-mhz-uhf/no-ground-plane-antennas/3236-laird-connectivity-bb4502ns-detail https://theantennafarm.com/shop-by-categories/shop-all/mobile-antennas/300-512-mhz-uhf/no-ground-plane-antennas/3231-laird-connectivity-b4502n-detail -
Line of sight is a big aspect that's present in the illustrations, but not really a focus. Handheld to handheld, I believe the general number is around 5 miles for simplex. However, for an affective repeater, the antennas are usually placed higher, sometimes hundreds of feet up a tower, or out here they're on the mountain ridges at thousands of feet above the valley floor. This gives them a much further line of sight than at ground level. The second aspect is antennas; repeater antennas will generally focus the RF energy better outward rather than upward...the usual illustration for this is comparing it to squishing a ball into more of a donut around the antenna. At the extreme this can be a tradeoff if you have large elevation differences where you end up under or over the "beam". Out here with the high level repeater locations, I have reached repeaters from 60-70 mi out on a handheld.
Kenwood HT LMR replacement batteries good brand / source ?
wayoverthere replied to WRMS528's question in Technical Discussion
One of my go to for aftermarket batteries has been cut rate batteries. Have them on a couple of my radios, and all good so far, along with one of their chargers for lithium batteries. They do offer a Nimh replacement battery for the tk370g. https://www.cutratebatteries.com/collections/kenwood-radio-batteries/products/kenwood-tk-370g-battery -
No, the higher frequencies of gmrs don't "skip" like the lower frequencies of cb do. That said, some areas see occasional ducting (affects vhf more than UHF, where gmrs resides) that see signals going a bit further than expected. APRS.mennolink.org is a good one to get an idea what ducting conditions are like at a given time.
You might find the TCARC one useful as well. The discussion thread on their forum indicated they were able to reach it with a mobile out to greenfield or so, and i can reach it with 18 watts and a 1/4 wave no problem. On the ham side, 444.975 (I think it's flagged as w6slo) should be an active one, linked up the coast to Monterey/Salinas and into the central valley
my gmrs handheld (which mainly resides in my desk at work now) has a set of extra repeater channels in it for travel use as well, in addition to the base 30 and the local/semi-local stuff. on the ham side, have mine arranged similar; in area first, abbreviating as needed and most common first. i've been adding out of area stuff as needed, grouped by areas..i have blocks for monterey/SF Bay/East Bay area, central coast (SLO/Morro/Pismo/Paso Robles), further north (Santa Rosa/Sonoma), and some Seattle stuff in one of the radios (for a trip that fell through). the radios that have banks, i'll sort them into banks based on area. I'll move things in and out of the scan list as needed when i travel.
I don't have a ton of them around, so I have them by their names as listed, shortened as needed, or a "nickname"...Auberry, Central1, and TCARC-G (Tulare County Amateur Radio Club has a couple GMRS machines up)
Clean install, and looks like it provides an okay ground plane and clear 360 degree view of the sky unlike some of the jeep installs. On the antenna, I say you've got it, run it. If it isn't performing like you want, then investigate other options. A basic 1/4 wave is only 6" tall, and shouldn't be any more of a height issue than the ghost, or laird has some 1/2 waves for 450-470mhz that check in around 12"
Yeah, it's kind of a mishmash...kind of like going to goodwill. There's an icom 718 on there tempting me, but it's at almost $400, untested. Also a pair of part 90 icom radios, 450-520 range https://shopgoodwill.com/item/159959792
If it covered more than just marine I'd be really tempted to bid just to have in the collection (I have a vx7, and a bunch of vertex standard stuff too), but I'm nowhere near the water.
Operation wise, that's the only one that comes to mind. Function...I have maybe 2 hours at most across the time I've owned it, and it's not actually holding 50 watts (or close)...it starts close and drops off, and doesn't stabilize till 25 watts. I'll see if can find a related post on another member's even worse luck with both the 50x1 and it's ham cousin (uv50x2). I would save for the wouxun and it's actual dual receivers. Edit: https://forums.mygmrs.com/topic/5077-btech-gmrs-50x1-50w/?do=findComment&comment=50477&_rid=2738
Standard horizon Hx460s. Never seen this before. Looks similar to the vx6/vx7, and looks like it might take the same batteries, but it's a marine vhf handheld. Inexpensive, too. https://shopgoodwill.com/item/159898068
Glad to help.
From what I saw in the FCC information, the v2 looks like it may allow adding some additional transmit channels (mostly for when you have multiple repeaters in range on the same frequency). With the 50x1, the preprogrammed 30 is it. Anything else you add is Rx only (coming from owning one).
GMRS / HAM radio pair suggestions
wayoverthere replied to WRVX677's question in Technical Discussion
(Disregard....this would be for the k1 plug, not the multi pin) Wouxun...kg805g, and the uv7d (dual band, 2m and your choice of 6m, 1.25., or 70cm as the 2nd). Ip54 and ip55 water resistance, same battery, same k1 cable, and same desk chargers. Edit: missed it was the multi pin similar to the xpr rather than the k1 plug....disregard. -
I'm holding out for one I can run off of one of the USB power adapters ?
What I was able to find indicates your local BLM field office would be the starting point for authorization. The description file linked from this page isn't loading for me, currently. It looks like the fees vary based on the population served, but if it can fall under 'other', it doesn't look outrageous. https://www.blm.gov/programs/lands-and-realty/communication-sites
Cross Boarder, USA/Canada, GMRS Communications
wayoverthere replied to Lscott's topic in General Discussion
More pondering...though they can't get licensed in Canada, what if you, as a us citizen, have a license and also have family in Canada that qualify to operate here under your license? Under us law, it'd appear they're operating legally and it's the Canada gov that they might have an issue with.- 26 replies
I don't know that I'd buy them specifically to diagnose this radio, but a dummy load and a meter (surecom sw102 isn't horribly expemsive and will have you covered for both swr and power output) are helpful things to have in the radio hobby. The meter will tell you if you have power going out, and the dummy load reduces the possibility of interferece while testing. If it's strictly a utility thing, I agree with @Sshannon that it's probably more economical in the long run to just take it as an opportunity to upgrade.
Popularity of GMRS with Over-The-Road Truckers?
There's a few that pop up on a couple of the ham networks when they're in range There seems to be a few still there. If I'm near the big freeways solo I'll usually throw a cb in the truck and try for responses occasionally, especially if there's something interesting going on. Gotten a few coming back in the last couple years on not too many tries, actually. -
Not to mention...unless youve prearranged with someone else to meet there, it may not do much good to look for simplex contacts in a portion of the band where others aren't expecting to find simplex contacts...if that makes sense.
Minor clarification: if you set a receive PL on simplex, you won't hear other traffic on the channel unless they're using the same PL. (exception: the older midland mxt 115 & 275 will want to leave tones off on simplex, since you can't set rx and tx separately) while it's usually not necessary (unless you know you need a specific tone for another party to hear you), it won't hurt anything to run a transmit PL on simplex; if the other parties listening aren't running a receive PL, they'll still hear you. If they ARE running a receive PL, they won't hear you either, unless you're using the SAME PL...if you run without any, they still won't hear you.
