wayoverthere
    28
  1. I was able to locate the relevant posts, which mention leaving a comment or dropping an email to (n1usa at ARRL dot net). post link
  2. Unless they've changed how it ships (which...I don't think so), all you need to do is dial to the channel named "rept16", push the channel knob in (which opens the menu, dial till you find "t-ctcs" or "t-dcs (as appropriate), push the channel knob again to choose your code (more scrolling with the channel knob, and one more push to confirm. Then hit 'exit". The "rept" channels are all preprogrammed with the appropriate +5.0mhz offset, and unless they've updated the firmware, those preprogrammed (30) channels are the only ones that will allow you to transmit, everything else is receive only.
  3. Looking end-on, I think it's one space after yellow, then the black...it's hard to tell though.
  4. Tagging this for a later look. I currently have one of the radios out of the car; I may have some time on my hands tonight, and if so i'll see if i can crack the mic open to at least see what the colors are coming in from the cord, and where they go.
  5. Was one of them this group? https://m.facebook.com/groups/338406913899977/permalink/807291797011484/ There's also a link their webpage, in the linked Facebook post. https://okgmrsclub.org/. The first, the email is his callsign at outlook.com, if you can't get it from the qrz page. The 3rd is similar except with the number spelled out, and it's Gmail rather than outlook.
  6. I'd be curious about the power outputs, though, especially on the yaesu. I know there's been some reports of reduced output on gmrs on mars-modded ft-5dr, at something like 1.3 watts, iirc. Power in the ham bands apparently remained unaffected.
  7. I'm seeing the same from my 2730...rather than a separate run, I wired the radio to the same 10 gauge cables that feed the audio amp, direct off of the feed from battery to underhood fuse block...seeing 14.1 there as well (I over-spec'd the wiring to the amp in case I wanted to bigger in the future, it's only ~140 watts rms to the sub) I do trust that a little more than the btech, which reads 14.2v when the digital display on the alinco psu in my shack shows 13.8v. I think I trust my multimeter a bit above both, though.
  8. No experience with that specific alinco, but I've had a dm30tr powering 3 and sometimes 4 radios at a time without a hiccup. That aside, I'll also agree with the others that the PSU is something to use to power a mobile on 120v at home, it won't be necessary in the truck. Realistically, a healthy alternator is going to be feeding right about 14 volts to the battery (plus or minus a couple tenths...was just checking mine at the battery last weekend, 14.1v) to charge it, which the wouxun will be perfectly happy with.
  9. I will second @Sshannon...receive tone is optional. Imo, the easiest way to think of it is like a filter. If you set a tone, you only hear signals with a matching tone. (This is why you need a tone to use the repeater). Leaving the receive tone off is equivalent to no filter, so you hear all the signals that are stronger than your squelch setting. While it can be nice to filter to only hear a repeater on the repeater channel, not all repeaters use an output tone, and it can complicate initial setup because it's an additional variable to make sure is correct...confirm things are working at the simplest level first.
  10. Eh, I'm just relying on a small bit of anecdotal evidence, there may well be more above what I've heard. I agree that "most all" may be a bit of over-generalizing if we're considering all radio traffic...the phrase may be accurate for amateur traffic, but I suspect air traffic is pretty significant in the overall scheme of things.
  11. What I've heard up this way (mostly the air traffic control) was around 118 and 121mhz, but yes, definitely AM....I guess that's the bit excluded by "most all".
  12. Also good to mention, though maybe not as common...these may be called DCS, or DPL.
  13. You'd look at the listing for the repeater to see what tone it wants for the input. On your radio/software, it may be called PL tone, or it may be called ctcss. My btech/baofeng stuff shows the menu item as "t-ctcs" (transmit ctcss tone). Some radios just use the straight tones (like 141.3), while others like many Midland and the wouxun kg935g use codes that correspond to the tones. For the latter, there is usually a table in the manual that shows what code matches which tone.
  14. This, sometimes it isn't so much an issue with the site, as either an issue with the data pushed out from FCC, or where FCC has an issue pushing out the data at all (happened for a bit in oct,iirc).
  15. I voted no as well..won't knock it if someone else wants them though. I figure the antennas are enough of an advertisement as it is, given most times the truck is wearing 2, and sometimes 3 if I want to hook up the 6m handheld or the cb.
  16. It's not so much "hooking up to it" like it's a connection ....the repeater is transmitting on a frequency (the "output"). The way gmrs is arranged, the repeater output channels each share a frequency with a simplex (direct user to user) channel. If you're listening on the same frequency that it's transmitting on, you'll hear it if you're within range (unless some other setting prevents it). In most cases, yes, either those people are part of a group that set up the repeater, asked permission, or the repeater was set up as "open" use. Granted we have a little more elevation here in CA, but there's repeaters 30ish and 60ish miles out (both gmrs and 70cm ham) that I can reach with a handheld.
  17. Pretty sure I've seen reddit posts that someone was successfully able to send aprs messages between the gmrs pro and a yaesu ftm400.
  18. https://www.arcantenna.com/products/tra4503-m2m-400-490-mhz-white-low-profile-omni-antenna https://www.arcantenna.com/products/tra4500n-m2m-400-490-mhz-white-low-profile-omni-antenna If I'm looking at the right antennas....4503 requires a ground plane, 4500N does not; both are NMO bases.
  19. Such as this? https://theantennafarm.com/shop-by-categories/shop-all/antenna-accessories/misc-antenna-parts/11713-taf-disc346-detail
  20. New one for me as well. It's also a little funny reading the article @Lscottllinked talking about how busy .52 gets, because it definitely doesn't in my part of central CA...may be different elsewhere. I've caught a couple SOTA/POTA activators, one up toward Yosemite and the other in Kings Canyon/Sequoia, but outside of them, a couple local hams that pop up once or twice a month, and someone that has their APRS beacon set there, .52 is largely dead.
  21. Would a pouch in lieu of the clip be feasible? I got a 2 pack with a belt loop for $20 off of Amazon, which also included shoulder straps (which I don't use)...have them attached to my backpacks. Looks like the ones with a clip are a little more... https://www.amazon.com/Carrying-Arcshell-BaoFeng-GXT1000VP4-Unication/dp/B091G3M83X/
  22. Was a little slow on the uptake last night...forgot I had a different pic on that side vs the forum ? that one isn't even one of mine, just something I found on the net awhile back and the expression amused me
  23. Like for yours.... https://mygmrs.com/user/michaellax comes back with this:
  24. It's not something that has a link, but it can be done via url...the format is: "https://mygmrs.com/user/username" ...just replace "username" with the user you want to look up, and it will come back with the user page that also displays their callsign.
  25. This...not so much that they're visible within the forum, but from the main page (mygmrs.com), if you look up a call sign, it will show if that callsign has registered on the site, including if their username differs from their callsign
