dwmitchell61
    Vancouver, WA
  • Interests
    Motorcycling, photography, kayaking, radio
1089 profile views
dwmitchell61's Achievements
  1. Considering the software BTWR supplies, from the manufacturer keeps getting flagged by Windows 11 Security as containing the Trojan:Win32/Wacatac.B!ml, maybe they should supply a download of CHIRP and the factory code plug for CHIRP? There is a problem when we and the Chinese are in a state of hostility, and they manufacture nearly EVERYTHING we purchase. But our government and the management of the large corporations deem the savings in labor costs are well worth the risk, I guess. "Most Favored Nation."
  2. Call it paranoia, if you will. But I don't trust anything software-wise that the Chinese have produced. If it is a true Trojan, you'll never know until all your money is gone from your bank account, or your computer gets held for ransom, or worse... They use your computer to do some nastiness, like espionage.
  3. Yeah, I know. Analyzers can get expensive. Slowly building my shack on a tight budget. I might look into a VNA, but you have to watch what brand if those you are buying, also. The Chinese aren't known for their quality checks, that's for sure.
  4. The SWR meter could be off, it IS an MFJ product. The BRC HP-500 antenna was advertised as a GMRS antenna. The "Frequency:" range was given as the GMRS, but they also mentioned the "Gain:" as being so much at "2m" and "70cm". I suggest buying the Comet CA-712EFC antenna before I would buy the BRC HP-500, for GNRS, anyway.
  5. Heck, if you have a window you could hang the antenna in, that would shorten the cable run and take the absorption of whatever kind of roofing down quite a bit, also. Composition shingles are coated in pebbles, basically.
  6. Bingo.... Set the priority channel to the channel your club uses or turn it off altogether. I had that issue on my Wouxon amateur handheld.
  7. Yes. The settings are correct. I double checked. I use the programming software. That way I can use the slots for the normally unused channels 8-14 to put in more repeaters and set it all for wideband operation (among other things). It makes it a lot easier than using the front panel, also. I replaced a broken Comet CA-712EFC with this one. The performance for a 17 foot antenna compared to the 712 at 10 ft 4 in is abysmal. Internally the BRC HP-500 seems to be just wire antenna elements. The Comet CA-712EFC was a coaxial collinear internally with coaxial stub matching transformers at the base.
  8. What kind of feedline (RG-58?) do you have to the base station Ed Fong antenna and how long is it (guessing around 40 feet)? Receive will be sensitive to excessive feedline losses. It isn't a big deal at the lower frequencies of CB radio, but when you are operating at GMRS in the UHF spectrum losses build rapidly. Forty feet of RG-58 has 5.4dB of loss at 450MHz (more at 465MHz GMRS). Every 3dB of loss halves the power, 6dB halves that. So you'll end up at about 16.7W at the antenna using RG-58. Forty feet of LMR400 has 1.08dB of loss and with it you'll 30.6W out of your 40W. In North CACKALACKY (my late wife and love of my life grew up in Havelock) you have humidity and storms. I would suggest N-type connectors and look up how to seal up the connections properly to keep moisture out of your feedlines. I use a connector silicone paste made to seal connections, it goes right in the connection. Then wrap the connection tightly with the silicone rubber "self-amalgamating" tape real good. Over that use the black vinyl electrical tape. And lastly, put a wire-tie (tie-strap) around the vinyl tape to keep it from unwinding on you. I use Times Microwave LMR-400 coax and it will cost you a "Ben Franklin" for 40 feet with N-type connectors. Don't forget a loop just at the antenna in the coax for strain relief (takes cable weight off of antenna connectors and puts it on your mast). Shhhhhheeeewwww! Did I forget anything? Hope this helps.
  9. I have a 40W Midland MXT-400. A 1 foot jumper of TM LMR-400 connects the output to an MFJ-842 SWR/POWER meter rated 140MHz-500MHz. A 3 foot RG-8X jumper connected to my window feed through (MFJ-4601N, N connectors). On the outside I have a lightning protector (also N connectors). The feed line is 30 feet of TM LM-400 connecting a BRC HP500 antenna. The SWR meter indicates 35W output from the radio with approximately 2W reflected power and the needles cross at 1.4SWR. A call to an individual I hear booming in from a repeater loud and clear with only two bars on my signal meter tells me that my signal is staticky and broken. So it appears that the receive is a LOT better than my transmission. I suspect that I have an antenna marketed as a GMRS antenna that is in fact a UHF antenna trimmed for SWR, but not necessarily a GMRS resonant antenna. The ad says it is 3 5/8-wave on 2m and 7 5/8-wave on 70cm, and the frequency is 460-470MHz (GMRS) and "C-loaded" (ceramic capacitor at the bottom, probably?). Any thoughts on this? Thank you, Dave KJ7WUZ/WRHW845
  10. I am curious as to how the heliax obviates any common mode current on the outer skin of the shield. Maybe I am misunderstanding the cause of common mode current on the feedlines? I thought it was due to imbalance in the antenna system. The PPT presentation you linked to above, on Page 6, states" "– Coax is not a part of these imbalances" So, I am wondering how your expensive heliax transmission line solves the issue. I have a lot to learn and don't know it all and am open to some mentoring from an "Elmer" It would seem that using ferrite beads of a proper mix rather than the old, trusty "ugly balun" method would be more effective at higher frequencies like GMRS. Thank you and 73 Dave, KJ7WUZ/WRHW845
  11. Ed Fong, PhD is an electronics engineer that is reputable and knows what he is doing. He developed these antennas from a request that he design an antenna given explicit criteria for a corporation in the communications business. There is no need to criticize unless you are willing to back your critique with explicit engineering facts. You don't have to buy Doctor Fong's products, but the proceeds do go to supporting the college students in his college courses. As for the big brand name antennas, I would suggest you take the time to look inside the next one you buy before you put it on your tower or mast. You might just be shocked by what you find, and maybe even a bit disappointed if you know anything about soldering and antenna theory. I intend to purchase his antennas for my use when I go portable. I just don't want to have to carry around some 10 foot to 17 foot fiberglassed fragile antenna that could be broken, then spend another $200-300 replacing it. Stay well, see you on the air, stay well and try to stay positive 73 Dave, KJ7WUZ/WRHW845
  12. I don't have an appropriate soldering station for the shielding. I tried to build a coaxial collinear antenna with a 25W iron on RG-8X and it was a mess. Even tried a butane soldering iron. If it's just the center pin, then that is manageable.
  13. This sounds like it may get expensive... Windstorm brought down mast & destroyed my base antenna. So's I buys a new antenna. The XYL says radios have to leave the bedroom, son has moved out, I now have a radio shack (and XYL used to manage Radio Shack here, LoL). Make a long story short. New mast, new antenna, new location, in the air, all guyed up, cables awaiting window feedthrough... I look over and find my Welsh terrier hanging from the GMRS coax and she's having a great time. I look and there are holes all the through the external insulation. Now I get reports I am "loud and clear but scratchy". Looks like I am going to lose some length in the cable... About how much is a crimper set for doing N-type connectors on LM-400? Maybe someone at the club will graciously let me borrow theirs?
  14. The words he speaks are true... I have a repeater 8 miles out on my HT ham radio. I can reach it using 1W loud and clear. My "base station" putting out 40W cannot reach a repeater 26 miles out, due to a mountain between us. I can, however, reach another about the same distance because there are no hills between us.
  15. On channel 1 I am receiving a constant beep. I thought I heard some family chat in the distant background. One of the neighborhood kids must have set his radio down with an emergency beacon or something turned on. No channel 1 until the battery runs down, I guess.
