WRKC935
    17
WRKC935 last won the day on May 26 2024
WRKC935 had the most liked content!
5 Followers
About WRKC935
  • Birthday 11/06/1971
    Johnstown, Ohio
3469 profile views
  1. Well, I am in process of replacing 600 and some foot of 7/8 line on a tower with this exact problem. It IS water ingress. The only fix is full replacement of the feed line. Water gets in two ways. First is a break in the jacket, if the jacket fails the water runs down the cable and in the crack. Second is a break in the antenna radome (fiberglass outer housing). Water runs in, through the connector and into the cable. Either way, it's in the cable. But once it's in the cable, it's in the cable. If you want to try to take the cable down and put it in a dehydrator and get the moisture out, OK. But while you have the cable down, just go ahead and replace it anyway because that's the only option that will work. And while you are replacing the cable, replace the antenna. Then worry about water proofing the connections once everything bad has been replaced. Not sure why I got back on here just to post this. But I really have no intention after reading much of the stuff on here of making it a habit.
  2. Well, you win, keep using this site to post links to your videos and make money off doing that. They don't seem to care that you are cashing in, so why should I give a damn. You decided to bring MY DISABLED SON into this discussion which just shows what type of person you are. How DARE YOU. So sit there on your throne and do your thing. I have better things to occupy my time with. Go feel bad about that. EDITED For language. I was obviously mad for obvious reasons. Still done. Just not going to leave this post the way it was.
  3. Need to know how to fully delete my account? All content, my repeaters, the whole thing?
  4. WTF??? My sons confined to a wheelchair... you asshole, what kind of bullshit is that? You implying something here? Keep running your mouth about my kid. I knew you were a jackass, but now your bringing my son into this. Who the hell do you think you are?
  5. OK, so yet another video about nothing,,, getting posted on here to get clicks and get you paid. Of course, content of the video. Especially one that is controversial, gets you more clicks and therefore more paid. Never mind that the regulations specify you can't use the channels. Rules are for bootlickers right? Nevermind that your efforts and video's were quite possibly a part of what got the FCC to do an about face on linking and shut all that down. So the rules only apply when they make YOU money. Maybe someone at the FCC needs to look into how you are cashing in on spreading misinformation. Maybe they will come down on you like they did the guy from Info Wars. Hard to tell. How's that AI chat bot working out for you?
  6. (c) 467 MHz main channels. Only mobile, hand-held portable, control and fixed stations may transmit on these 8 channels. Mobile, hand-held portable and control stations may transmit on these channels only when communicating through a repeater station or making brief test transmissions in accordance with § 95.319(c). The channel center frequencies are: 467.5500, 467.5750, 467.6000, 467.6250, 467.6500, 467.6750, 467.7000, and 467.7250 MHz. Meaning they are there, as part of the frequency allocation, but are NOT to be used for general simplex communications without communicating through a repeater. So they are extra channels how? Regulations say they can't be used for simplex operation, so they really aren't for general use.
  7. Be aware that the 'coverage map' on the mygmrs.com web site is NOT a generated heat map like the one displayed above. It's a simple circle around the TX site that gives an average expected coverage based on path loss across flat ground. Meaning, if you look at the map for Johnstown675 on here, it ain't right, or even close, depending on the direction you are from the repeater. The map of my repeater (WRKC935 / Johnstown675) shows coverage in Pataskala, Newark, downtown Columbus, and several other area's that I have no coverage in. Those coverage holes are caused by the topography of the area. Case in point is the Granville ridge. I have good coverage on 161 / St Rt16 going east right up to the point you cross where Granville is and St Rt 16 comes in from Pataskala. After that the coverage stops for a time and then picks back up closer to Newark and continues out to St Rd 146 and further. Same thing happens going West, Works great until Little Turtle exit off 161. Then falls off getting on the 270 outer belt. But if you continue west on 161 it's good most of the way to St Rt 23 (High Street) in Worthington. Then it falls off until you get west of Columbus and then picks up until you are out to St Rt56 on I-70. I have talked from the Honda plant Northwest of Marysville, From Mechanicsburg, and from London (42 / I-70 ) from a portable. So my point is that you should NOT have an expectation that all area's in the green circle are going to work based on the mygmrs.com maps. And you are further limited due to using a handheld radio. The power is lower and the antenna's do not have the gain that a mobile or a base station would have. I say all this based on the programming that you have in your radio you posted the codeplug of. If you have the Pataskala repeater programmed, I know that machine has limited coverage in that area due to antenna height. If you are in the Pataskala area, and are having coverage issues getting into the Johnstown repeater, that's why you are having issues. I can't talk to it from Pataskala with a 50 watt mobile. The coverage just isn't there.
  8. First thing is NOT giving them what they want, which is to be recognized and acknowledged for what they are doing. If at all possible, when the show up and there is a conversation going on, continue the conversation without commenting on the problem. Keep right on talking. If one of you gets covered up by the guy, DO NOT directly say that. Claim it's noise, or something else. If possible have a conversation going on a different channel so that it seems transparent. But DON'T say anything that gives them recognition. That is what they want. If you clear the frequency, again the person 'wins' by default. Don't let that happen. If needs be, get several other people into the conversation. Get a conference call going on telephones so everyone knows whats being said. And just keep talking like the person isn't even there. This will frustrate them the most. If they aren't having any effect, they will go find someone else to screw with. Make sure when they get on initially, ask them to REPEAT their call sign. Act like it's just another conversation. Act like they are having sign issues if you do this. Tell them they aren't making the repeater very well and advise them to try again when they get closer. Mention that they might want a better antenna. This is regardless of how good their signal is. Full quieting or not. THey are weak and barely making the repeater. But address them the same as you would anyone else that had a poor signal and them tell them to give you a call once they get closer. Throw your call and wait. That typically will confuse them and again cause them to be frustrated. I can't explain the mentality of folks that do this. And I use to do it all the time to certain individuals on CB because they had it coming. But to take time out of your day to just be an asshole. I don't follow that thought process, and I even identify as an offensive asshole, so I speak from some level of experience here. But DON'T give them ANY level of satisfaction if you can help it. If you aren't showing any level of frustration with them, they will be more frustrated than you are. They are looking for a captive audience. Don't be one.
  9. While I disagree with it needing to be done by 'someone with proper knowledge and equipment' the nano VNA is fine for a NOTCH duplexer, in my opinion, that's the opinion of a guy that's been donig this for 15 years professionally and over 20 years in general. The little flatpack notch setups aren't going to be tight enough that if they are only close they will not be close enough. And there are tests that can be done to ensure they are at least that close. I have tuned them with nothing more than a radio, attenuator, RF signal meter and a bit of know how. And when I put them on a regular VNA they were dead on. Biggest concern is does the VNA output the frequency it says on the display. Easy test is put a frequency in it that you have a receiver for and verify it can be heard in the receiver. If you can hear it as a carrier, then it's on frequency enough to tune a flatpack. If you decide to take it on yourself, you need to know a few things. First is the open port on the fatpack needs to be connected to a dummy load. If it's not terminated, ti's not going to tune up right. Second is how you actually move the notch. Guys without any experience will just start cranking on whatever cavity they feel the need to and NOT move a little at a time. Once you move one cavity off far enough the notch in that cavity will disappear. Once that happens, it's a PITA to figure out. So make your changes up or down about a half turn at a time and do ALL three cavities with each step move. You will want to set your VNA with a wide frequency range to start. Once you are close, then you drop the bandwidth down to 1 Mhz and finally 500Khz to walk it in all the way. Remember that you are notching the TX out of the high side (receive side) and the RX out of the low side (transmit side). They should be marked high and low. So follow that and you will be fine. DO NOT however attempt to tune one the way I talked about before with just using a radio, attenuator and RF meter. I have tuned hurdreds of duplexers, built up combiner networks from parts, learned all the math and crap that goes with doing that. It's not stuff for a beginner to attempt.
  10. So are they using an MDC control list, or a RAC (repeater access code) to open the repeater? Moto did support those on some of their repeaters. I am not so much interested in locking people out of my repeater at present, but If I could figure out an MDC switch that would turn on such a filter switching the repeater to 'private use' when needed that might be something.
  11. No idea, But figuring that you are reading the labels of the crap you have in your medicine cabinet for daily consumption, you would be far better equip and experienced to answer those questions. But from Googling the names of the medications, and the fact you brought them up. Well it does explain a few things. Guess you subscribe to a statement a friend once made to me. Better living tomorrow through the pharmacological discoveries of today. So just remember to stay on your meds and we will all be just fine.
  12. Hit a repeater at 25 miles with .1 watt? Yeah, it's not hard. Several ways to do it. First is vertical height, if you get the radio in the air far enough it's not hard. Aircraft will do it in any situation. Beyond that, two tall hills over a valley would work as well. Issue is to have unobstructed line of site. Second is antenna gain. Lots of it. Toss up a 12 foot dish that you can pull close to 30dB of forward gain. Same way I do it with 23dBm (200 milliwatts) for 23 miles at 4.9Ghz. Of course path loss at 4.9 is WAY higher at that distance than 460 Mhz. At 460 the path loss is 117dB. At 4.9Ghz it's 137dB. SO 20 dB more. You have to remember that a repeater, or at least one with reasonable coverage is going to have vertical height already. Repeaters with antenna's at 50 or 100 feet don't talk 25 miles period. The curvature of the earth makes the line of site horizon 14 miles for a 100 foot high antenna. Beyond that you need to increase height to maintain LOS.
  13. Count for what?
  14. Set your Repeater tuning steps to 25 as well.
  15. GRID DOWN!!!!!! GRID DOWN!!!!!
