TOM47
Everything posted by TOM47
  1. GREAT RADIO, BUY IT,?
  2. WHAT DO YOU MEAN BY PERMANENT SOLUTION? rs=w:776,h:388,cg:true (517×388) (wsimg.com)
  3. N9TAX Labs - Antennas, Amateur Radio, Antennas, Ham Radio
  4. NO - ARIONA IS!
  5. NOTE THAT IF YOU RETURN IT BACK TO GMRS YOU WILL HAVE TO RENTER YOUR CHANNEL SETTINGS.
  6. HOLD DOWN THE V/M BUTTON WHILE POWERING THE RADIO ON TO SET TRANSNITTING FREQ RANGE
  7. I NO LONGER REMEMBER BUT ALL WERE VERY SERIOUS AND PREVENTED USE. BOUGHT THEM FOR GIFTS AS THE DB20'S I GAVE OUT WORKED SO WELL. SORRY FOR LATE RESPONSE.
  8. Amazon.com: DHT Electronics Handheld Antenna Cable for Wouxun Baofeng Quasheng Linton - Adapter for UHF Base and Mobile Antennas - SMA Female to UHF SO-239 Female Connectors 6'' Pack of 2 : Electronics or Amazon.com: onelinkmore SMA Female to SO239 Female RF Two Way Radio Coax Adapter UHF Jack SO-239 Antenna Cable Connector for CB Radio Walkie Talkie SDR UV-5R Series Handheld Radio Pack of 2 : Electronics
  9. I HAVE Wouxun DWC30WIN 30A Switching Power Supply with LCD Display FOR TWO KG1000G'S Wouxun DWC30WIN 30A Switching Power Supply with LCD Display (buytwowayradios.com)
  10. I HAVE A FEW KG-UV9D MATE'S THAT WILL DO ALL AND MORE. https://www.buytwowayradios.com/wouxun-kg-uv9d-mate-kit.html
  11. ANY CHANCE THE KG-935G CAN BE UNLOCKED TO TRANSMIT OUTSIDE GMRS?
  12. WRITTEN INSTRUCTIONS FOR USING THE SECTION WOULD BE HELPFUL. I HAVE BEEN HAVING A HARD TIME WITH IT.?
  13. KG-95G IS A GREAT GMRS RADIO, I FAVE A FEW!?
  14. I NEED EASY TO READ SCREEN THE LARGER THE BETTER DUE BAD EYE SIGHT.
  15. WHAT GMRS bureaucracy and red-tape.?
  16. wouxun_kg_905g_owners_manual.pdf
  17. Retevis RT97S Portable GMRS Repeater – myGMRS.com THIS MAY BE ONE? The Retevis RT97S is an exciting new UHF repeater certified by the FCC for use on GMRS! The Retevis RT97S has FCC ID 2ASNSRT97.
  18. THAT IS WHAT I AM USING WITH A FEW OF MY KG-1000G'S AS BASE STATIONS.
  19. I HAVE BOTH THE KG-935G AND KG-905G HERE IS A GOOD COMPARISON - THE KG-935G IS A BETTER !
  20. THE UT72G IS THE ONE ALREADY TUNED FOR GMRS Nagoya UT-72G Magnetic Dual-Band GMRS Antenna – myGMRS.com I HAVE A FEW, WORK GOOD!
  21. ALLTHIS HAS BEENVERIFIED BY THE MENISTRY OF TRUTH!
