TOM47
Everything posted by TOM47
  1. ?THAT VIDEO CONVINCED ME TO GIVE MY DAUGHTER (WHO IS REALLY HARD ON ELECTRONICS) ONE OF MY KG-935G'S!
  2. NOT MUCH. JUST PREFER THE BRAND AND SOFTWARE. OTHERWWISE SIMILAR FEATURES AND MORE EXPENSIVE!
  3. REPLACED THOSE I GAVE AWAY WITH A COUPLE OF WOUXUN KG-XS20G'S.
  4. I HAD TWO BUT GAVE THEM TO RELATIVES TO GET THEM SRARTED, GREAT ENTRY GMRS MOBILE.
  5. THAT IS CORRECT, HOWEVER THE Nagoya UT-72G IS A High Gain Magnet Mount GMRS & MURS Antenna (462-467 & 151-155 MHz) . THE G AT THE END OF THE MODEL NUMBER MEANS IT IS PRETUNED FOR GMRS AND NEEDS NO TRIMMING!! Nagoya UT-72G High Gain Magnet Mount GMRS Antenna (462-467 MHz) (buytwowayradios.com)
  6. ANOTHER WORK AROUND IS TO PRINT TO PDF THE CONFIGURATION FROM ANOTHER WOUXUN RADIO THAT YOU HAVE PROGRAMMED ALREADY LIKE A KG-1000G, THEN COPY AND PASTE INDIIDUAL ITEMS INTO THE KG-95G SOFTTARE. SLOWER BUT WORKS.
  7. The Retevis RT97S is an exciting new UHF repeater certified by the FCC for use on GMRS! The Retevis RT97S has FCC ID 2ASNSRT97 Retevis RT97S Portable GMRS Repeater – myGMRS.com
  8. HAVING TROUBLE WITH Y VISION AND TYPING SO CALL MEAT 6027999581
  9. YOU WILL SEE TWO VERTICLE SCROLL BARS ON THE RIGHT AND FAR RIGHT, BRING ONE OR BOTH DOWN UNTIL YOU SEE A HORIZONTAL SCROLL BAR ON THE BOTTOM TO MOVE THE VIEW RIGHT. ALSO IF YOU CLICK ON THE CHANNEL NUMBER ON THE LEFT IT WILL HIGHLIGHT THE ENTIRE LINE.
  10. I HAVE NO IDEA WHY YOURS DOES THAT!
  11. SO CAN MY KG-935G! JUST TO BE SURE I TESTED SCANNING BOTH A & B AT THE SAME TIME JUST NOW START THE SCAN FOR EACH BAND AS ACTIVE.
  12. I USE THE RED WOUXUN PCO-001 CABLE AND WORKS PERECTLY Wouxun USB Programming Cable (PCO-001) (buytwowayradios.com) DO NOT USE THE MINI CD DRIVERS How to install the Wouxun programming cable and driver (buytwowayradios.com) HOPE THE ABOVE INSTALLATION INSTRUCTIONS HELP!
  13. I HAVE ONE OF THOSE SUPPLYING POWER TO ONE OF THE KG-XS20G'S RIGHT NOW, WORKS GREAT!
  14. CHECK OUT THIS POWER SUPPLY FOT THE KG-XS20G Amazon.com: ACEXL Cigarette Lighter Adapter-Ac to Dc Converter-Car Plug Adapter Outlet-Car Cigarette Lighter Socket-110 to 12 Volt-Car Adapter to Wall Outlet-12 Volt Power Supply-24Watts : Automotive
  15. Amazon.com: Cigarette Lighter Adapter-Ac to Dc Converter-Car Plug Adapter Outlet-Car Cigarette Lighter Socket-110 to 12 Volt-Car Adapter to Wall Outlet-12 Volt Power Supply-24Watts : Automotive WILL SUPPLY ENOUGH POWER FOR THE KG-XS20G FROM A WALL OUTLET.
  16. I JUST NOTICED THAT THE KG-XS20G HAS THE SAME PRINT BUTTON AS THE KG-935G SOFTARE! REAL HANDY.
  17. UNTIL THEY COME UP WITH A WATER/DUST PROOF SOLUTION TO KEEP FROM MISPLACING THE HATCH COVER ROTATE IT OUT OF THE WAY?
  18. YOU WILL NEVER GET ONE THAT WAY, EVERYONE WHO BACKORDERS WILL GET THIERS FIRST!
  19. VERY TRUE. WISH BTWR WOULD OFFER THAT ANTENNA AS A INDIVIDUAL ITEM, COULD NOT FIND IT!
  20. JUST GOT THE EMAIL THAT THEY ARE MAILING TODAYTHE KG-935G THAT I ORDERED 10-4-21! MAYBE YOURS WILL BE SOON
  21. I HAVE TWO IN USE AND ANOTHER IN PROCESSING AT BTWR. LOOK AT THE BTWR VIDEO ON THE KG-935G AS WELL AS RANDY'S. I AM DISABLED FROM A STROKE AND GLACOMA WHICH MAKES PROGRAMMING ANY RADIO FROM THE FACE IMPOSSIBLE FOR ME. THE SOTWARE PROGRAMING IS EASY COMPARED TO THE 805G, 905G, 1000G AND XS-20G, HOEVER VERY SIMILAR. PERFORCE FAE EXCEEDS THE 805G AND 905G. THE ONLY NEGATIVE I HAVE ENCOUNTERED US THE HATCH COVER SHARED WITH THE 905G THAT SCRES DOWN TO MAKE IT WATER RESISTANT. THAT FEATURE IS DEFEATED WHEN USING A SPEAKER MIKE. MANY OTHER FEATURES. WOULD LIKE TO SEE AN INDEBTH REVIEW / TUTORIAL BY GADGET TALK. KG-935G 100721.pdf
  22. ANYONE NOTICE THAT THAT THE NEW KG-935G SOFTWARE HAS A PRINT BUTTON? PRINTS ALL THE CONFIG SETTINGS. HAVE NOT SEEN THIS ON OTHER WOUXUN GMRS SOFTWARE.
  23. THAT WILL WORK UNTIL YOU MOVE AROUND ANDENCOUNTER MULTIPLE REPEATERS ON THE SAME FREQ. THEN IT IS EASIER TO SET UP NEW ENTRIES.
  24. ARE YOU PROGRAMING IT USING YOUR PC? IF S0 CREATE A NEW ENTRY WITH THE RX FREQ 462.625 AND TX FREQ 467.625 AND PUT IN THE TONES OR EACH AND THEN GIVE THAT CHANNEL ENTRY A NAME. RITE IT TO YOUR RADIO AND SAVE THE FILE WITH THE DATE/TIME SAVED!
  25. THAT DEFINATION IS NICE AND ACCURATE HOWEVER WE DID A GUPLEX TEST ON A REPEATER WITH DIFFERENT HT'S, 805'S, 905'S AND 935'S. THE KG-935G WAS THE BEST, DIFFERENT STATIONS IN DIFFERENT LOATIONS. CALL AND ASK BUY TWO WAY RADIOS ABOUT THIER TESTS.
