TOM47
Everything posted by TOM47
  1. YOU CAN TURN OFF THE DUAL DISPLAY ON THE 935 TO LOOK SIMPLE LIKE THE 905. HAVENT SEEN ANY DIFFERENCE IN SQUELCH ADJUSTMENT. YES I GET BETTER TX & RX ON THE 835 INCLUDING LOCATIONS WHERE THE 905 OULD NOT CONNECT TO REPEATERS LIKE FROM AN INTERIOR SINGLE STORY BATHROOM..
  2. HAVING BOTH MODELS THE KG-935G OUT PERFORMS MY FOUR KG-905G'S WHICH HAVE THE STOCK ANTENNA AND THE 15" NAGOYA'S. DON'T BOTHER WITH THE KG-905.
  3. WELCOME ABOARD, TAKE A LOOK AT THE WOUXUN KG-XS20G www.buytwowayradios.com/wouxun-kg-xs20g.htmlTO USE WITH A NAGOYA UT-72G MAG MOUNT Nagoya UT-72G High Gain Magnet Mount GMRS Antenna (462-467 MHz) (buytwowayradios.com)ON A BAKING SHEET WITH THE Amazon.com: Cigarette Lighter Adapter-Ac to Dc Converter-Car Plug Adapter Outlet-Car Cigarette Lighter Socket-110 to 12 Volt-Car Adapter to Wall Outlet-12 Volt Power Supply-24Watts : Automotive FOR AN INEXPENSIVE MOBILR/BASE ALTERNATIVE
  4. JUST DID A RADIO CHECKS FROM TWO KG-905G'S WITH THE SAME NAGOYA ANTENNA AND A KG-935G WITH STOCK ANTENNA. NEGATIVE CONTACTS USING THE KG-906G'S HOWEVER MADE LOUD AND CLEAR CONTACT WITH THE KG-95G TO A REOEATER AT LEAST 45 MILES DISTANT FROM AN INTERIOR 1ST STORYBEDROOM WOOD FRAME STUCCO CONSTRUCTION.
  5. REALLY NICE PHOTOS AND GREAT REVIEW OF THE KG-935G, MY EXPERIENCE ALSO - THANKS FOR THE TIP ON THE CASE, GOING T0 ADD ONE TO MY NEXT ORDER. I HAVE ONE KG-935G NOW AND ANOTHER ON BACKORDER MAYBE SHIP THIS WEEK, TOM
  6. I HAVE ALL THREE, THE 805G/905G/95’s. AND HEAR NO DIFFERENCE IN TX OR RX! THE KG-935G IS MY FAVOEITE DUE TO THE DISPLAY. i EXPECT UPS TO DELIVER ANOTHER KG-XS20G THIS WEDNESDAY! THE ORDER FOR THE SECOND KG-935G STILL SHOWS "PROCESSING" ON BACKORDER.
  7. STARTED OFF LATE 90'S / EARLY / 00'S WITH UNIDEN & MIDLAND FRS/GMRS HT'S FOR COMMUNINATING WHILE QUAIL HUNTING THEN ATER A STROKE PARALYZING MY LEFT SIDE AND ELIMINATINATING ANY HUNTING ACTIVITY I GOT BACK INTO GMRS RADIO WITH SOME KG-805G'S THEN KG-905'S AND FIMALLY WITH THE KG-935'S. WITH BAD EYESIGHT THE DISPLAY ON THE 935G WAS AN IMPORTANT FEATURE AS WELL AS THE SOFTWARE PROGRAMING BEING SIMILAR TO MY KG-XS20'S & KG-1000G'S. I CAN ONLY PROGRAM USING SOFTWARE DUE TO MY PHYSICAL LIMITATIONS USING THE DISPLAYS. I HAD ALS0 PREVIOUSLY USED THE GARMIN RINO RADIOS FOR CLIENT HUNTERS WHILE GUIDING FOR ELK AND TURKEY IN NORTHERN ARIZONA YEARS AGO.
  8. I RECIEVED MINE A COUPLE OF DAYS AGO, SO NOT MUCH TIME TO COMPARE IT TO MY KG-1000G'S, HOWEVER THE WOUXUN PROGRAMING SOFTWARE FOR IT SEEMED EASIER AND VERY SIMILAR TO THE KG-935G AND KG-1000G.
  9. ALTOUGH HE IS OVER THE EDGE ON HUMOR AND THEATERATRICS I FOUND HIS REVIEWS HELPFUL AND INFORMATIVE AND INFLUENTIALIN MY PURCHASINGDECISIONS! ALSO AND MORE INORMATIVE ARE THOSE ON UTUBE BY Gadget Talk
  10. Just ordered one today to test! said to ship 091021.
  11. NO, HAD A STROKE PARALYZED MY LEFT SIDE, NOW HAVE LOUKEMIA AND GLAUCOMA. SO MISSING PARTS OF WHAT'S ON THE SCREEN AND THE KEYBOARD TOGETHER WITH KEYING USING ONE HAND MAKES MY SPELLING AND CHECKING WHAT I POST EASIER IN UPPER CASE. SORRY TO GIVE THE IMPRESSIONS OF SHOUTING.
  12. WHAT I CONSIDER TO BE A VUNERABILITY OF A TELESCOPING SECTION ANTENNA IS THE POTENTIAL FOR DAMAGE WHILE EXTENDED, POSSIBILITIES FOR TO STAY TUNED FOR GMRS AFTER DAMAGE OR REPAIR?
  13. AT 6.29921 INCHES' OTHER THAN FLEXIBILITY iICAN'T MUCH, INSTEAD TRY A NAGOYA 771G Authentic Nagoya NA-771G Handheld GMRS Antenna (15.3 Inch) (buytwowayradios.com) FOR BETTER PERFORMANCE ON THE KG-905G. CHECK THE REVIEWS ON PERFORMANCE THERE!
  14. THE G AT THE END OFTHE NAGOYA 771 G MEANS IT IS TUNED FOR GMRS. THE AMAZON ONE IS A UHF ANTENNA FOER HAM RADIOS!
  15. FOR THE KG-905G CONSIDER THE Nagoya UT-72G High Gain Magnet Mount GMRS Antenna (462-467 MHz) (buytwowayradios.com) COMES WITH THE SMA ADAPTER AND CAN BE PLACED ON A FENDER IF THE ROOF IS OFF OR ON A BAKING TIN INDOORS AS A GROUND PLANE
  16. I HAVE A FEW DB20-G INSTALLED THAT I SUPPORT. THE BEST COMBINATION FOR THAT RADIO I HAVE FOUND IS THE NAGOTA UT-7G Nagoya UT-72G High Gain Magnet Mount GMRS Antenna (462-467 MHz) (buytwowayradios.com) FOR THE ANTENNA AND THE Amazon.com: Pyramid PS9KX Universal Compact Bench Power Supply-5 Amp Linear Regulated Home Lab Benchtop Converter w/ 13.8 Volt DC 115V AC 70 Watt Input, Screw Type Terminal, 12V Car Cigarette Lighter: Car Electronics FROM ANAZON TO USE IT INDOORS WITH A COOKIE PAN FOR A GROUND PLANE UNDER THE ANTENNA. TOO HOT OUTSIDE HERE NTHIS TIME OF YEAR. IF YOU END UP NEEDING A BETTER ANTENNA CONSIDER THE NAGOYA 770G ALSO TUNED FOR GMRS Authentic Nagoya NL-770G High Gain Mobile GMRS Antenna (UHF Male) (buytwowayradios.com) AND CHECK OUT DB20-G GMRS Radio Review and Tutorial - YouTube
  17. IF INSTEAD IH THE BATTERY ELIMINATOR YOU COULD CARRY YOUR CHARGER BASE WITH EXXTRA BATTERY AND Wouxun Vehicle Charging Adapter (CCO-001) (buytwowayradios.com) FOR THE CHARGING BASE!
  18. WITH AN EXTRA BATTERY AND YOUR CHARGER BASE USING Wouxun Vehicle Charging Adapter (CCO-001) (buytwowayradios.com) MAY WORK FOR THAT SHORT ROAD TRIP?
  19. THE THE UT-72G WILL DO MUCH BETTER THAN THE STOCK RUBBER DUCK ALSO THE BATTERY ELIMINATOR Wouxun ELO-005 Battery Eliminator for KG-905G and KG-UV8H (buytwowayradios.com)
  20. YES, HOWEVER THE UT-72G Nagoya UT-72G High Gain Magnet Mount GMRS Antenna (462-467 MHz) (buytwowayradios.com) IS A LITTLE SMALLER AND COMES WITH A SMA ADAPTER FOR THE KG-906G. ALTHOUGH I ALSO HAVE THE KG-1000G WITH THAT NAGOYA 770G AND IT IS A PERFECT COMBINATION!
  21. I HAVE A FEW OF THE UT-72G'S TUNED FOR GMRS THAT WORK GREAT ABAILABLE FROM Nagoya UT-72G High Gain Magnet Mount GMRS Antenna (462-467 MHz) (buytwowayradios.com) FOR A GROUND PLANE AN OLD BAKING SHEET OR PIZZA PAN WORKS GOOD INDOORS OR ON JUST STICK THE MAGNET TO THE ROOF OF A VEHICLE.
