Muzic2Me
Everything posted by Muzic2Me
  1. So how do you like the Icom's?..I have seen a lot of them on-line.
  2. I think I studied for a week on what I wanted. I'm wanting to purchase an Amateure Band radio. Got any ideas. I want something with a great receive end. Kenwood TM-V71A dual band 144/440. Familiar with?
  3. Question... where do you go to find if any upgrades of firmware for my rig. Is it normally on the manufacturers site?
  4. I have the Wouxon 935 and it allows plenty of memory to allow for this. Scan the VFO frequencies and pick what you want and save.
  5. Just wondering if anyone was aware of any unlisted open repeaters in the Lonoke County, AR. I see the Vilonia600 listed ( roughly 30 miles away. Lots of hills from me to it, but was checking more for my area. Thanks in advance.
  6. IT's coming along MichaelLAX. THanks!! Now I'm pondering. I'm studying for the Technician license now and trying to decide whether I spend on a GMRS mobile/base or go ahead and get a dual band. I would like to get both. I have been researching just how much wattage I can get by with for a GMRS mobile/base and still hit a repeater around Approx 30 miles. I see a lot of reviews on 5 watts HT reaching them, but that is with a good line of sight and high Antenna.. We shall see..........Thanks again for the info on my previous issue.
  7. I have not checked every tone, but I did tone-scan about 10 transmitting tones; especially the one that wasn't picking up from the repeater. These of course were on GMRS simplex on low power. The daughter is getting some great experience. She did well, helping me out!! call sign and all. I will check even more tomorrow. I even tried both channels. KG-935 has dual channels. I am wondering, since this radio is a GMRS Tx/Rx only, if something is going on when it's in the VFO mode when I'm Rx on the 70cm band when this is happening. Unfortunately, my other HT's are just some Midland 1000's, so I can't check that out on them. Too bad I wasn't able to key up those guys to ask. Guess it is time to go get some HAM. I was even wondering if there was another repeater out there with that 151.4 Rx tone on same Freq out there that wasn't listed. Shout out again for all help with me. Thanks everyone.
  8. Mbrun.....Yes, that is exactly what I am trying to figure out. I do have another HT. That sounds like a great idea. I do not know why I did not even think of that. I was so focused on this repeater and code, I guess. I will do that now and keep you'll posted. Thanks million. and thanks to all that were pitching ideas and checks for me also. Great community on here!!
  9. Sshannon...I have no clue. I thought my hardware was "out of calibration" to put it in my words for the Rx tone. Then he checked his, I was not there, but he said his was opening at 114.8. So that's when I had no clue. 443.200/448.200 +5 114.8. Maybe this is one I just bury and move on to the next head scratching experience.... I can/did put in a receive of 151.4 and could hear the same peeps as when I entered no tone.
  10. Would that be the Tx code(uplink)? And does not require a "Rx tone? I'm new so forgive me, but certainly an enjoying learning the massive amounts of theory and information that goes along with. this has been a head scratcher for me...lol
  11. It seems to work when 151.4 is the Rx ctcss. I do understand removing the Ctcss Rx, but i think I am trying to see, like I said if i have an issue now. Thats all. Thanks for the head scratching.
  12. 443.2000 +5 MHz CC1 114.8 Little Rock, Shinall Mountain Pulaski N5CG OPEN FM AllStar DMR. Here is all it lists for extra info
  13. If you're referring to the 2nd tone as the one that works for me, it is 151.4. I do not see any other tones for this repeater, other than the one listed on the directory. I am located NE away from the repeater. roughly 30 miles give or take
  14. Shinall Mountain - N5CG Little Rock, AR Repeater ID: 05-179 Downlink: 443.20000 Uplink: 448.20000 Offset: +5.0 MHz Uplink Tone: 114.8 DMR Enabled Color Code: 1 DMR ID: 31052 County: Pulaski Call: N5CG Use: OPEN Op Status: On-Air
  15. So possible hardware issue if I’m using 1 tone he’s using another and we hear the same channel?
  16. You are correct. And yes, I can hear the same as channel without any tone.
  17. Wouxon kg-935g
  18. I agree. My reasoning for kinda asking was if I need to send this back for any type of repair bc it’s not working properly. I guess I could check others, but that was truly the only one I actually getting to monitor. Thanks on the info also. Just a head scratcher
  19. My GMRS HT monitors only, 70cm and i have the listed receive tone for a freq in for a week and it worked fine. Over the weekend something has changed. It does not receive with that tone from that repeater in now. So, I have scanned-tone and its a diff. Rx tone. Now I can hear with the new RxTone. asked someone else to try using the original tone that I had previously used and it works on theirs......Any reason.did my stuff break a leg.?
  20. I could hear the repeater ID, so if I wanted to verify repeater vs. simplex, I would just add ctcss Rx tone. If I hear; it’s repeater. Thanks for all the supportive statements and help. To everyone!
  21. Way over there is right. Although, maybe someone can answer this. I had a repeater programmed in and everything was good. I could receive transmission. Then over the weekend. I could see my Rx bar receiving, but no audio. I then removed ctcss code and could hear. I then tone-scan and picked up a different Rx tone and it opened my squelch with a Rx tone. Only thing I can think of is that the Rx tone was changed???. It doesn’t match with the online directory, but works… hmmmm
  22. That makes sense. Thanks for the feedback. The longer I mess with this it will all click the Switch on one day.
  23. Sounds good. Thanks! I'm still learning. I have always been the " I want to know how it works" and not "just click here, turn up the volume and your good to go" type at anything. It makes me understand better, but sometimes a frustration too. lol. Still understanding the receive Freq/Channels 15-22 for simplex and the repeater channels 23-30 are the same Rx, but with the offset of 5 for transmit to repeaters input. on Ch 23-30. So, I am assuming that if I have no Receive tone for the Repeater channel. I could be hearing the Simplex channel. Or regardless if I have a receive tone on the repeater channeI, I am still hearing it on the simplex channel, b/c they are the same Rx freq? I guess what I am saying that in a pre-programmed HT, the only diff. is that Repeater channels have the TX already config for transmit at offset. "Thats clear as mud".
  24. No question… is the stupid question.. with that said. Newbie… I installed a temp antenna for my HT at the homestead. I’ve programmed a repeater in to see if I was able to Rx. I haven’t heard anything on it( non-actively listening). Today I was scanning and it hit the repeater channel. Question: I removed the Rx tone from this repeater channel and heard Morse code when it stopped the scan on this channel. Is it possible I heard the repeater, or possibly the simplex channel? any info would be great! Thanks in advance
  25. Good one!!!
