Wouxun KG-1000G Plus Single vs Dual Display question
I am trying to switch between dual display and single display on my KG-1000G Plus. When I hit the TDR button on the mic (#8) all I get is a double beep. When I enter the TDR function in any of my channels I also just get a double beep. Also when I press the AREA button I get a double beep. I want to stay in single display mode and customize the text in the unused area. Somehow, when I was trying to do this the unused area now says RPT-TX all the time. The owners manual is not much help. Any help is appreciated. Thanks!
13 answers to this question
  • 1
3 minutes ago, BobDiamond said:
AUTOLOCK is OFF (Menu #47). I also cannot change between channel and frequency mode
So the mic button #6 and/or menu #7 work mode aren't working either?
  • 1
6 minutes ago, BobDiamond said:
FIXED!!! I had MENU #54: RPT-MODE enabled to RPT-TX. I must have done that by accident as I was walking through all the menu options. I turned that to OFF and now everything is working properly. My mistake!!
Glad that you figured it out.
  • 1
Thanks. You helped me. By asking about the other MENU settings related to TDR I went through the others and saw that somehow I had enabled the REPEATER-MODE.
Glad I was able to help you. I didn't even think about repeater mode since I have never messed with that setting. The radio is set to receive or transmit mode  when in repeater mode.
6 hours ago, OffRoaderX said:
Unlock the keypad.
The keypad on the mic is unlocked. The manual says to use the TDR function to toggle between single and dual display mode. The mic has #8 assigned to toggle TDR but all I get is a double beep. The manual also says by default TDR is assigned to Hotkey "C". But I get a double beep when I hit that button too.
Is the radio unlocked? Pushing the D button on the radio will also lock and unlock the radio. You will see a key sample on the screen if it is locked. Otherwise TDR should work when you push the #8 button on the mic as long as the radio is not locked.
Radio is NOT locked. I can lock or unlock it with the D button as you said. All other Hot Buttons (A, B, C) give me a double beep. And the #8 on the mic for TDR also give me a double beep. I am in channel mode on the radio. Does that matter?
TDR should work as intended in channel mode. Getting the double beep sure sounds like the radio is locked. I tested the TDR on my KG-100G Plus and the only time I get the double beep is when the radio is locked.
Double check menu #47 AUTOLOCK and make sure it is set to off.
Other than that, I really don't know what to tell you. I tried duplicating your problem and the only way I get a double beep is when the radio is locked.
Same here.. that should never been enabled.. I guess now we know why..
although my NEXT suggestion would have been to do a factory-reset, which would have set that setting back to off, thereby fixing the issue, so technically, given a long-enough timeline, I was right.
Doing a factory reset was going to be my next suggestion also.
