Mrsig Posted Monday at 12:11 PM Report Posted Monday at 12:11 PM How do I open the Retevis RT97L Repeater Software that I just downloaded? My computer ask what to open it with.. Help. Quote
0 MarkInTampa Posted Monday at 01:00 PM Report Posted Monday at 01:00 PM 1 hour ago, Mrsig said: How do I open the Retevis RT97L Repeater Software that I just downloaded? My computer ask what to open it with.. Help. The software is compressed with RAR, kinda like a zip file but different format. You can download WINRAR (if running windows) for free and it will extract files. Also, download in install the driver FIRST before installing the software or plugging the repeater into the computer. BTW, stopped at Beef's in Bushnell yesterday coming back from Savannah to Tampa for dinner. It will be nice to have a repeater in the area. SteveShannon and WRUU653 2 Quote
0 Mrsig Posted Monday at 03:17 PM Author Report Posted Monday at 03:17 PM Thanks i will do that. I wish I knew I would of given you a tour of the ranch & range. Quote
0 Mrsig Posted Monday at 03:33 PM Author Report Posted Monday at 03:33 PM Drive will not install. It failed. Quote
0 OffRoaderX Posted Monday at 04:34 PM Report Posted Monday at 04:34 PM 1 hour ago, Mrsig said: Drive will not install. It failed. Can you give the exact wording, or a screenshot of any errors or messages you received? Quote
0 Mrsig Posted Monday at 04:42 PM Author Report Posted Monday at 04:42 PM "Driver install failure!" is what I get when I click on install. Quote
0 LeoG Posted Monday at 05:24 PM Report Posted Monday at 05:24 PM What version of Windows are you running? Quote
0 LeoG Posted Monday at 07:38 PM Report Posted Monday at 07:38 PM Should work. I had trouble with Win7 Uninstall the previous programming software if you haven't already. See if there's a line in the program area of the control panel to remove the driver. If not go to the device manager and locate it and remove it. Reboot the computer and install the driver. Hopefully it'll work. Or you might be able to "update" the driver in the device manager with the same file. Likely this with throw an error as "current version installed" Quote
0 OffRoaderX Posted Monday at 07:40 PM Report Posted Monday at 07:40 PM 1 minute ago, LeoG said: Uninstall the previous programming software if you haven't already. See if there's a line in the program area of the control panel to remove the driver. If not go to the device manager and locate it and remove it. Reboot the computer and install the driver. Or you might be able to "update" the driver in the device manager with the same file. Likely this with throw an error as "current version installed" I am going to guess, based on his previous responses, that he is going to have zero clue what any of those words mean. ..just a guess though.. Quote
0 LeoG Posted Monday at 08:05 PM Report Posted Monday at 08:05 PM That's OK. I tried. If you can't work the inner workings of the system they you are reliant on everything working right the first time around. I just spent an hour with my wifi router that I use to connect my laptop to my printer. No internet connection. It's been working for over a decade and then it went plop. Had to reset my router completely and now I only have the default name which I hate. Took me an hour to get things back to operation because I refused to give up my original specs. But eventually I had to reset it. Quote
0 MarkInTampa Posted Monday at 08:09 PM Report Posted Monday at 08:09 PM Try right clicking on the install file and left click "Run as Administrator". Quote
0 Mrsig Posted Monday at 11:27 PM Author Report Posted Monday at 11:27 PM I have Windows 7 not 10 Just rebooted and can not find CH341SER.INF any place on the computer so I will try to down load and in stall again. The program works not hooked to the repeater yet. Thanks for the help guys. Quote
0 Mrsig Posted Monday at 11:36 PM Author Report Posted Monday at 11:36 PM Still getting when I go to install it "Driver install failure!" Quote
0 Mrsig Posted Monday at 11:44 PM Author Report Posted Monday at 11:44 PM This is what I get. Then when I click install I get. Quote
0 OffRoaderX Posted yesterday at 12:01 AM Report Posted yesterday at 12:01 AM 16 minutes ago, Mrsig said: This is what I get. Then when I click install I get. What is the name of the Executable file you are running when this happens? Quote
0 MarkInTampa Posted 23 hours ago Report Posted 23 hours ago You can try just installing the software without the driver and it may or may not work. It's basically the driver for the USB to serial cable. Some cheap cables have counterfeit version of the USB to serial CH341 chip built into the cable and require a prolific driver to work. If it is a genuine USB to serial chip built into the cable Windows will autodetect the cable and install the drivers automatically. If it's not a genuine chip or a "cloned chip", Windows will show it as a unknown device. You can try plugging in the cable, bring up Windows device manager and check to see if the drivers installed properly by expanding the "Ports (COM & LPT)" and see if you have any new COM ports listed when you plug in the cable. If device manager detects it as a "prolific chip" with a triangle (triangle means no or bad drivers - Windows see's it as a counterfeit chip) next to it or "unknown device", then you need to figure a way to get the drivers installed. My guess is if they list the driver for download - it's probably a counterfeit/cloned chip and needs it to work but you might get lucky. Quote
0 MarkInTampa Posted 23 hours ago Report Posted 23 hours ago 54 minutes ago, OffRoaderX said: What is the name of the Executable file you are running when this happens? The driver on the website is CH341SER.EXE - dated 10/6/2014 within the RAR file if that helps. I'm assuming that's what he is trying to install. Quote
0 OffRoaderX Posted 23 hours ago Report Posted 23 hours ago 14 minutes ago, MarkInTampa said: The driver on the website is CH341SER.EXE Yah, that's what i thought.. I dont know if the OP as already installed the software, it had a driver issue, so now he's installing the drivers, or if he's just clicking willy-nilly.. When I installed the software the separate driver setup/install was not needed as you eluded to in your previous post. MrSig: Did you install the actual software, and ran into a problem with the drivers, and that is why you are trying to run the Driver Setup program? Quote
0 Mrsig Posted 13 hours ago Author Report Posted 13 hours ago The program software is installed the only thing I think is wrong with it it shows 467. as RX & 462. as TX. I Don't know why it is the RT97L. I was told to run the Driver software first but could not get it to run. The Repeater should be hear Thursday. Thanks for the help guys. Quote
0 MarkInTampa Posted 13 hours ago Report Posted 13 hours ago 36 minutes ago, Mrsig said: The program software is installed the only thing I think is wrong with it it shows 467. as RX & 462. as TX. I Don't know why it is the RT97L. I was told to run the Driver software first but could not get it to run. The Repeater should be hear Thursday. Thanks for the help guys. That would be correct. The repeater listens on 467.x (RX) and outputs (transmits) on 462.x (TX). It would be wrong if it was the other way around. WRYZ926 and SteveShannon 2 Quote
0 Mrsig Posted 7 hours ago Author Report Posted 7 hours ago Ok thanks. So if I Rx is 467.5000 & Tx is 462.5000 I would have to have a "+ 5.000000" so it will work correct? I will a 159.8 Ct for a private line. Quote
0 SteveShannon Posted 7 hours ago Report Posted 7 hours ago 44 minutes ago, Mrsig said: Ok thanks. So if I Rx is 467.5000 & Tx is 462.5000 I would have to have a "+ 5.000000" so it will work correct? I will a 159.8 Ct for a private line. No, the fact that it already shows the proper TX and RX frequencies indicates that you don’t need to do anything else with the offset. Quote
0 MarkInTampa Posted 5 hours ago Report Posted 5 hours ago I'd suggest leaving the factory channels as they are. It's pretty much plug and play out of the box. Just change the tone required (in your case 159.8) for what channel (frequency) you want to use. Then go to "edit" on top of the screen and "option features" and change the default channel if you are using something other than .550 (channel 1) if you have a power outage but don't know if this step is actually required. That should be about all you need to get up and running. SteveShannon and WRYZ926 2 Quote
0 Mrsig Posted 4 hours ago Author Report Posted 4 hours ago Thanks so much. I should be hear by Friday. Just need to get some one on my tower now. Thanks for your help. Quote
Mrsig
25 answers to this question
