Hello folks, I have a wouxun KG-S65G among a few other HT's.  Does anyone know if either a Nagoya 701G or signal stick 440 will fit this radio? There is a small wall on either side of the radio that is keeping some antenna's from fitting properly. The Smiley's I have will fit but only without the cone and there's a significant gap . My 771g will fit but is longer than I want on this radio. Thanks
6 answers to this question
I have the KG-S88G which is of a similar form and the 701 fits fine. That said the Wouxun stock Antenna I think is better than the 701G. I do use the 701G on a Boafeng UV9G and I think it is a little better than the stock on this radio.
Thank you for the reply I also have a baofeng but it's a uv5G plus and two TD H3's . I'm addicted to these little radios.😁
2 hours ago, WRYZ926 said:
I've tried the Nagoya 701G and 771G on my KG-935G and the stock Wouxun antenna performs better. I do see an improvement when using the 771G on my Baofeng UV-5R GMRS radios.
I'm going to do some testing with various antenna's on this wouxun this weekend 👍😀. It's just that little tiny wall on either side of the radio, one by the on/off knob and one on the antenna side that makes me question the fit .
The Signal sticks come with male and female SMA connectors as well as BNC. I use the signal stick on all my HTs.
I’ve been meaning to grab some for a long time now. I think you’ve got me motivated to pull the trigger finally.
