WSIK532 Posted June 14 Report Posted June 14 Here is my findings. I have setup an HT programmed via CHIRP with two different tone settings for this REPEATER: WRPB502 WX4DAB REPEATER 1 set with TSQL 123.0 REPEATER 2 set with TONE 123.0 Second Radio is on GMRS CH15 which is received on REPEATER B clear... but cant transmit back out of REPEATER 2 or 1 to Second Radio.... Any thoughts? Quote
WRXB215 Posted June 14 Report Posted June 14 How close are they to each other. You might be experiencing desense. Make sure you separate the two radios by about 50 ft or so and try again. Quote
WSIK532 Posted June 14 Author Report Posted June 14 3 minutes ago, WRXB215 said: How close are they to each other. You might be experiencing desense. Make sure you separate the two radios by about 50 ft or so and try again. Still not getting any response from the repeater itself.... Quote
WSIK532 Posted June 14 Author Report Posted June 14 7 minutes ago, WRXB215 said: How close are they to each other. You might be experiencing desense. Make sure you separate the two radios by about 50 ft or so and try again. I just emailed the owner. just to see what he says. Quote
WSAQ296 Posted June 14 Report Posted June 14 Clarify, because while you understand your original post, I do not. You have two identical radios programmed and one does something the other doesn't? or you have two channels and one doesn't work. Tsquelch means it will only allow you to hear signals with a matching PL tone. So if you're wrong, you'll hear nothing. TONE is transmit, and if it's wrong you won't activate the repeater, but you'll hear it just fine because you have nothing filtering the receive. SteveShannon 1 Quote
WSIK532 Posted June 14 Author Report Posted June 14 one is setup to hit the repeater, the other one is not. the radio thats setup to hit the repeater i set two channels up based on the info I got from the repeater section of this site. one channel is setup 123.0 using tsquelch , the other channel is set with tone option 123.0. I wanted to see which is correct to get a response from the repeater. i posted a picture of how I programmed the main radio with the setup in my original post. Quote
WSIK532 Posted June 14 Author Report Posted June 14 2 hours ago, WSAQ296 said: Clarify, because while you understand your original post, I do not. You have two identical radios programmed and one does something the other doesn't? or you have two channels and one doesn't work. Tsquelch means it will only allow you to hear signals with a matching PL tone. So if you're wrong, you'll hear nothing. TONE is transmit, and if it's wrong you won't activate the repeater, but you'll hear it just fine because you have nothing filtering the receive. one Radio is setup to hit the repeater, the other one is not. the radio thats setup to hit the repeater I set two channels up based on the info I got from the repeater section of this site. one channel is setup 123.0 using tsquelch , the other channel is set with tone option 123.0. I wanted to see which is correct to get a response from the repeater. i posted a picture of how I programmed the main radio with the setup in my original post. Quote
SteveShannon Posted June 14 Report Posted June 14 30 minutes ago, WSIK532 said: one channel is setup 123.0 using tsquelch , the other channel is set with tone option 123.0. I wanted to see which is correct to get a response from the repeater. Both will work equally well. With Tone you’ll hear everything transmitted by the repeater, even if your TX tone is incorrect. That’s why I recommend starting with Tone. With TSQL you’ll only hear radios transmitting on that frequencies using that CTCSS tone. Raybestos 1 Quote
WSIK532 Posted June 15 Author Report Posted June 15 6 hours ago, SteveShannon said: Both will work equally well. With Tone you’ll hear everything transmitted by the repeater, even if your TX tone is incorrect. That’s why I recommend starting with Tone. With TSQL you’ll only hear radios transmitting on that frequencies using that CTCSS tone. ok . Quote
