Coax size between repeater and duplexer
I’m thinking I’m going to build a repeater. I’m making a shopping list. I want to use two Kenwood tk-8180 radios and a mobile Celwave 633-6a-2 duplexer.
I keep seeing images of people using what looks like rg400 coax from the radios to the duplexer. I used lmr400uf ultra flex from DX Engineering to connect my base station and I have some left over. But the lmr400uf is still stiff for such a small distance from radio to duplexer.
If I use a smaller coax like the rg400 vs the lmr400uf will it make that much of a difference?
thank you!
4 answers to this question
thank you!
Use one of the many coax loss calculators to see if the loss for that length is acceptable to you.
40 minutes ago, WRYZ926 said:
Even small coax like RG8X, RG316, and RG58 will work just fine for short cables. RG316 is popular to connect repeaters to duplexers. They are generally 3 foot or shorter so loss is not an issue.
Yup,,  pretty much what you see used for Repeaters with Duplexers built into them. . Keep the lengths as short as possible, defiantly no longer than 3'
We run separate duplexers with all of our repeaters. The repeaters and duplexers are all mounted in a server rack so no coax going between the repeaters and duplexers are not longer than 2 feet, most are closer to 12-18 inches in length.
If the cables are going to longer than 3 feet then definitely go with coax that has less loss since you are going to always lose some power after the duplexers.
