WSIC904 Posted July 2, 2025 Posted July 2, 2025 Hello Group. Is the UV-5R and UV-18 Pro Max capable of dual receive? Thank you! WSIC904/KB9VVT Quote
1 WRTC928 Posted July 7, 2025 Posted July 7, 2025 On 7/2/2025 at 10:08 AM, WSIC904 said: Hello Group. Is the UV-5R and UV-18 Pro Max capable of dual receive? Thank you! WSIC904/KB9VVT By "dual receive" do you mean capable of listening to two frequencies at the same time? What Baofeng calls "dual monitoring"? If so, then yes, the UV-5r can do it and according to its advertising the UV-18 can too. If we're splitting hairs, the Baofengs don't actually listen to two channels at the same time; they flip rapidly back and forth between them, but for most people's purposes, it's close enough. OffRoaderX 1 Quote
0 OffRoaderX Posted July 7, 2025 Posted July 7, 2025 On 7/2/2025 at 8:08 AM, WSIC904 said: Is the UV-5R and UV-18 Pro Max capable of dual receive? Yes. Quote
0 WSIC904 Posted July 7, 2025 Author Posted July 7, 2025 3 hours ago, WRTC928 said: By "dual receive" do you mean capable of listening to two frequencies at the same time? What Baofeng calls "dual monitoring"? If so, then yes, the UV-5r can do it and according to its advertising the UV-18 can too. If we're splitting hairs, the Baofengs don't actually listen to two channels at the same time; they flip rapidly back and forth between them, but for most people's purposes, it's close enough. Yes, dual monitoring on both bands, A and B. Quote
0 WSIC904 Posted July 7, 2025 Author Posted July 7, 2025 2 hours ago, OffRoaderX said: Yes. Thank you! Quote
0 UncleYoda Posted July 8, 2025 Posted July 8, 2025 2 hours ago, WSIC904 said: Yes, dual monitoring on both bands, A and B. Sounds like you're misunderstanding. There is no "dual monitoring on both bands". It alternates automatically between checking Display A and Display B. It only receives on one or the other at one time. And the dual watch setting is called TDR on the UV5R function menu. Quote
0 OffRoaderX Posted July 8, 2025 Posted July 8, 2025 4 minutes ago, UncleYoda said: Sounds like you're misunderstanding. There is no "dual monitoring on both bands". It alternates automatically between checking Display A and Display B. It only receives on one or the other at one time. And the dual watch setting is called TDR on the UV5R function menu. Which to a normal person, using normal ears, appears to be "listening to two channels at the same time"... Next you going to explain to us how "movies don't really move"? Geezusphuckingkrist "some people" are insufferable.. SteveShannon 1 Quote
0 UncleYoda Posted July 8, 2025 Posted July 8, 2025 Calm down Queenie. I was trying to get him to understand it's not "dual on both". Sounded like by both bands he may also be thinking of bands A and B as the two frequency bands in VFO mode, rather than Line A and B. Quote
0 WRTC928 Posted July 8, 2025 Posted July 8, 2025 3 hours ago, WSIC904 said: Thank you OffRoaderX and UncleYoda. What am I? Chopped liver? Quote
0 WSIC904 Posted July 10, 2025 Author Posted July 10, 2025 On 7/8/2025 at 4:35 PM, WRTC928 said: What am I? Chopped liver? My apologies. Thank you WRTC928. WRTC928 1 Quote
0 WRTC928 Posted July 10, 2025 Posted July 10, 2025 5 minutes ago, WSIC904 said: My apologies. Thank you WRTC928. I'm just jerkin' your chain, man. Quote
0 LeoG Posted July 12, 2025 Posted July 12, 2025 On 7/8/2025 at 5:35 PM, WRTC928 said: What am I? Chopped liver? More like Goose Pate' WRTC928 1 Quote
WSIC904
WSIC904/KB9VVT
12 answers to this question
