amaff Posted July 23 Report Posted July 23 I know there's at least a couple others here running GMRS radios in race / track cars. Whatcha running? Up until now I've been making do with a handheld based system in my car (with an external antenna). Nerdie racing car harness with Fuze molded ear plugs / buds, and a KG905-G on the door bar, but I've never been thrilled with it. It's performed fine (100% coverage at most tracks I run, 80%+ at worst), but it's something extra to manage and care for and the only decent mount I could find for it had it rotating around to where the screen wasn't visible (did I just bump the channel knob? uh oh...) and if I was lucky I would just be able to reach the volume knob to adjust it while belted in the car w/ a helmet and HANS. Always had to make sure it was turned off for the night, always had to make sure the battery was charged. Before: So I wanted a mobile radio solution. But most mobile radios obviously won't work with a K1 connector based car / headset harness. Cut to learning this weekend about the BTech UV25X2. Compact 20W radio, but has an adapter with a K1 connector to plug a headset in. It is technically a ham radio (actually, I don't know how they get away with it, the thing near as I can tell is WIDE OPEN, not just restricted to 2m / 70cm ham bands), so, caveat emptor and all that, know what you're doing when you're messing with it because it definitely WILL let you do things you maybe shouldn't be. Changed the power connector on the back over to a more weather resistant 2-pin deutsch connector. No I'm not using the cigarette socket in the car, this was just for testing on my desk. In the car it's wired to a switched bus-bar and battery ground in the car. Integrated the mounting bracket with my switch panel with a pair of rivnuts: I don't plan on running it at full power most of the time, but I tested with it to make sure everything works. Good SWR, and higher than the advertised 20W. (1.12 SWR @ 8.6W on Low power). I need to finish cleaning up the wiring and zip tying / wire-wrapping everything, but it's in and I got to test it out simplex with my son on an H/T, and also to a handful of local repeaters, both with the handset it comes with, and with the full helmet & earbuds setup. Seems to work great, good signal reports all round, we'll see how it holds up SteveShannon and mb523 2 Quote
nokones Posted July 23 Report Posted July 23 I had a leather case speciality made by Leathersmith and I bolted the case on top of the switch panel. You might be able to see it if you expand on the attached picture of the inside. Depending on where I was racing, I used either VHF of UHF in the Astro 25 Digital mode with an XTS portable. I used a Racing Electronics Harness with a PT-T on the steering wheel and Racing Electronics Helmet Kit with their custom molded ear inserts. Since, the body panels were composite I ran with a non-groundplane Antenex NMO mount antenna on the roof. I never had any coverage problems and my crew were using the Otto Behind-the-head headsets with the remote antenna attached to the headset and a XTS portable. I thought about going with a mobile, but I never saw the need. Although, I have been a GMRS licensees since the mid-90s, I never used any GMRS freqs. I used Part 90 freqs I was licensed for in both the VHF and UHF bands. amaff 1 Quote
amaff Posted July 23 Author Report Posted July 23 GTA... @nokones you wouldn't happen to know Butch Kummer would you? He runs in the South East so, maybe not, but that community isn't *that* large Quote
nokones Posted July 23 Report Posted July 23 8 hours ago, amaff said: GTA... @nokones you wouldn't happen to know Butch Kummer would you? He runs in the South East so, maybe not, but that community isn't *that* large No, I don't know that name. The class has essentially gone away. I guess it was too expensive for most of the drivers and now they are running Miatas now. Quote
amaff Posted July 24 Author Report Posted July 24 I finished tidying up all the wiring and snipped all the zip tie tails. I...made a bit of a mess Quote
WRKC935 Posted July 25 Report Posted July 25 In this sort of application, there is something to be said for commercial radios. It was mentioned 'did I just bump the channel knob' and that's a thing if you have one. Personally I would be looking at a CDM750 for this specific application and dealing with the 4 total channels that can be programmed in it. I realize that as you travel track to track and races to race that others might be on the same channel and you might need to move. But 4 channels should actually be enough to have something usable for the event. Of course the high dollar race teams all have a licensed frequency, so they don't tend to have issues with others interfering with their comms. The other thing with a CDM750 or similar radio is the quality of construction. Race cars are not luxury sports sedans with leather and adjustable 'comfort systems'. They beat you and vibrate and generally are a rough ride. I remember the difference in my Camaro just building in the cage and tying the subframes (unibody 2nd gen). Even with the mostly stock suspension system the car suddenly rode more like a log wagon and less like a pony car. And the solid motor mounts didn't help much either. CDM750's are dirt cheap since they are only 4 channels. No one wants them, they all want the CDM1250s and 1550s. I would be interested to hear how that radio holds up in a purpose built race car over time. gortex2 1 Quote
amaff Posted July 25 Author Report Posted July 25 2 minutes ago, WRKC935 said: I would be interested to hear how that radio holds up in a purpose built race car over time. Yep, same. For $125, I figured it was worth the experiment SteveShannon 1 Quote
gortex2 Posted July 26 Report Posted July 26 I have yet to see a mobile radio in a race car. Every radio I have seen is a portable with an antenna adapter. I dont know if indy or F1 is different but at least in the nascar world its all portables. Rarely do you even see a mobile in a safety truck either. If you are doing a mobile I'm with others get a quality LMR radio with limited functions. Quote
nokones Posted July 26 Report Posted July 26 3 hours ago, gortex2 said: I have yet to see a mobile radio in a race car. Every radio I have seen is a portable with an antenna adapter. I dont know if indy or F1 is different but at least in the nascar world its all portables. Rarely do you even see a mobile in a safety truck either. If you are doing a mobile I'm with others get a quality LMR radio with limited functions. I've seen a few in road race track racecars, but not in oval track racecars. Mobile radios are common in off-road race type vehicles for obvious reasons. Quote
amaff Posted July 26 Author Report Posted July 26 3 hours ago, gortex2 said: I have yet to see a mobile radio in a race car. Every radio I have seen is a portable with an antenna adapter. I dont know if indy or F1 is different but at least in the nascar world its all portables. Rarely do you even see a mobile in a safety truck either. If you are doing a mobile I'm with others get a quality LMR radio with limited functions. Really? Even at club level road racing (SCCA / NASA) I've seen a mix of mobile and H/Ts. Once you get up into your IMSA / WEC / World Challenge, even the lower tiers, it's basically all mobiles. I haven't spent enough time crawling around circle track cars to tell you one way or another in that world. SteveShannon 1 Quote
nokones Posted 5 hours ago Report Posted 5 hours ago This is my Time Trial and Autocross car with radio comm. The Antenna is an Antenex Non-Groundplane Phantom. Quote
amaff Posted 4 hours ago Author Report Posted 4 hours ago 24 minutes ago, nokones said: This is my Time Trial and Autocross car with radio comm. The Antenna is an Antenex Non-Groundplane Phantom. And you weren't at the Vegas TT National event earlier this year? I'm very disappointed. That's awesome. I run U2 in my car for TT, XP for AutoX. Maybe we'll meet up at LVMS at some point, or one of the Cali tracks Quote
nokones Posted 3 hours ago Report Posted 3 hours ago I have been restricted from racing by three doctors because of three different surgeries. I was hit by car when a 92 year old driver ran a stop sign and hit me while I was riding my bicycle 4 years ago. My last surgery was for by lower back last April. So, no racecar driving for me yet. I did put 10 gallons of fresh Sunoco Race Fuel in my car this morning and took it for a 25 mile drive up and down the freeway just to keep the car happy since it has been sitting for awhile and I mean awhile. The tires are hard as a rock but everything seemed to be ok. I am able to get in and out of the car ok without any soreness or pain and I am able to lift/raise a 15 foot metal roll-up door and open/close the ramp door on my trailer. However, I am not ready to lift my tires and wheels up and into my tire rack in my trailer yet and that is my goal. Maybe later this year. I do feel like I may be able to change the tires now since I graduated from Physical Therapy three weeks ago and the progress I'm making with the exercises that were given to me by the doctors. All I can do now is just be in charge and organize the events. I think I may be able to drive after the first of the year. The Doctors don't want me to go crazy yet, but they are very pleased with my recovery so far and have allowed me to take on more exercises with more weight resistance. They have been real impressed with my speedy recovery especially for an old person. "XP", you have to run against Andy and Teresa McKee. Quote
