That's OK.
One other point to make. You don't really need a unique DMR ID to use DMR. FCC doesn't require it, and it's not a substitute for ID'ing using your call sign. So if you're not in the official database all anyone sees is garbage. Not to mention spoofing DMR ID's. Yeah people do that and since it's not illegal the FCC couldn't care less.
For those than want to register and get a DMR ID this is the place.
https://radioid.net/
I also have a NXDN ID too BTW through this site.
I also believe people use their DMR ID as the digital ID for P25.
You require a DMR ID to access amateur radio networks.
Sent from my SM-S911U1 using Tapatalk
for the most part, i have learned to ignore my assigned DMR ID and rely on my unique ID i made up..  As long as it gets programed in all the radios in your group, good to go and harms no one.
As I mentioned it doesn't have to be unique. Using some made-up ID works, which defeats the purpose of having a DMR database in the radio. I've done the later accidentally, used the wrong ID when programming my radios. That happened when a guy on an out of area repeater noticed my call sign didn't match the call sign that showed up on their radio. Oops.
Yea,, when you are interested in only those in your group..  Who cares about those 'other' guys?
Yeah, I have to agree: seems to turn DMR into GMRS and not in the broader spirit of Ham Radio.
But to each, their own...
  • 3 weeks later...
I have a couple of Motorola DMR radios with several DMR repeated and simplex channels programmed and not one of the have any HAM channels programmed in them. One main reason why I don't is because I am not a licensed HAM and I don't care to be a HAM.
2 hours ago, GreggInFL said:
What's the best way to learn DMR? This question from some holding a GMRS license only.
Randy, you have a channel? :)
Remind me again: what DMR radio are you wanting to learn to program?
buy a cheap Baofeng DM32 and get your toe's wet.  This radio, for the price, is pretty decent..  I'm not a fan of it's encryption, which works but only for short distances but the Analog, DMR, Talk Groups and Zones make it an enjoyable radio to use.  The huge battery will eaily get you a few days of use between charges as well.
Okay, but on what service can you use DMR without a license? The only one I'm aware of is PMR446 in Europe.
I have a Baofeng DM-32UV, still in the box. I intend to configure the analog side for GMRS. I'll RX only on the digital side for now, but would like to know what I should be listening to. It's not a matter of how to program it, it's a matter of what to program, i.e. what should a DMR newbie be listening to? Is there a recommended beginner code plug?
With the exception of CB Radio, FRS, Marine and Aviation in the United States, and IMS Spread Spectrum, I believe all services require some type of Station or Operator license.
Sorry, I wasn't clear. You stated you have Motorola DMR radios but don't have a HAM license. So on what service are you using those radios?
In the DMR mode the Part 90 Industrial/Business Radio Service
You need a codeplug specifically configured for your DM-32 and the DMR repeaters in your area.
Since the DM-32 is relatively new and each radio's codeplug is different (except for OpenGD77, which are interchangeable), you need to contact some Ham or Ham Club in your area that has a DM-32 and has written a codeplug.
When I was "younger" I used to look forward to these challenges to help strangers; now not so much, especially for radios that I have little or no respect for.
Gregg,
I would be happy to help put together a codeplug for you/with you. You can listen to DMR on amateur radio.
Reply to this topic...
