UncleYoda Posted 7 hours ago Report Posted 7 hours ago Should not have to explain this, but... I can't read black text on a dark gray background. If we're going to get notification popups, they should at least be readable. /rant Quote
SteveShannon Posted 6 hours ago Report Posted 6 hours ago 26 minutes ago, UncleYoda said: Should not have to explain this, but... I can't read black text on a dark gray background. If we're going to get notification popups, they should at least be readable. /rant I also don’t like black on dark gray, but I don’t recall seeing any. Where are you seeing them or perhaps under what circumstances do you receive these notifications? What operating system or platform? Quote
WRUE951 Posted 6 hours ago Report Posted 6 hours ago 46 minutes ago, UncleYoda said: Should not have to explain this, but... I can't read black text on a dark gray background. If we're going to get notification popups, they should at least be readable. /rant change your setting in your browser setting. Dark to Light or Same as Windows WRUU653 and SteveShannon 2 Quote
SteveShannon Posted 6 hours ago Report Posted 6 hours ago 11 minutes ago, WRUE951 said: change your setting in your browser setting. Dark to Light or Same as Windows That’s why I was wondering about what platform he was on. Windows, and I presume Linux, Mac, etc, has a lot of display settings that can be customized to ensure that low contrast between the background and the text isn’t an issue. I doubt that @rdunajewski specifically set notifications to black on gray. Quote
UncleYoda Posted 6 hours ago Author Report Posted 6 hours ago Re: above replies, the fact y'all don't understand doesn't mean it ain't happening. This topic is intended for the man in charge, and he should know. It would be hard to capture a screenshot because I never know when one will appear and they clear after a few seconds. Quote
SteveShannon Posted 6 hours ago Report Posted 6 hours ago 2 minutes ago, UncleYoda said: Re: above replies, the fact y'all don't understand doesn't mean it ain't happening. This topic is intended for the man in charge, and he should know. It would be hard to capture a screenshot because I never know when one will appear and they clear after a few seconds. Nobody said it wasn’t happening and unless you report something I’m not sure Rich is seeing this, but whether you believe it or not we are trying to help solve your issue. So which notifications are you seeing that are black on dark gray. If you really don’t want anyone else to comment you should pm Rich. Quote
UncleYoda Posted 6 hours ago Author Report Posted 6 hours ago The problem I see with that line of thought is this is the forum section for his site therefore he should monitor it. Quote
SteveShannon Posted 5 hours ago Report Posted 5 hours ago 3 minutes ago, UncleYoda said: The problem I see with that line of thought is this is the forum section for his site therefore he should monitor it. Maybe he has notifications for it and can’t read them because they’re black on dark gray… WRUU653 and BoxCar 2 Quote
UncleYoda Posted 5 hours ago Author Report Posted 5 hours ago OK, I caught one example. Sometimes there are longer ones, I think those are for reactions or similar things. Quote
SteveShannon Posted 4 hours ago Report Posted 4 hours ago 35 minutes ago, UncleYoda said: OK, I caught one example. Sometimes there are longer ones, I think those are for reactions or similar things. Yeah, definitely nearly impossible to see. My notifications don’t look like that at all. I’ll try to catch one. Quote
SteveShannon Posted 4 hours ago Report Posted 4 hours ago Here’s what the pop-ups look like on my iPhone: Quote
SteveShannon Posted 4 hours ago Report Posted 4 hours ago Here’s another notification. WRUU653 1 Quote
WRUU653 Posted 1 hour ago Report Posted 1 hour ago (edited) 4 hours ago, WRUE951 said: change your setting in your browser setting. Dark to Light or Same as Windows This would be my thought exactly Edit: that said I use Dark mode on my iPad and light on my Mac and don't have this issue, but the question remains what browser and setting is @UncleYoda using, or device for that matter Edited 1 hour ago by WRUU653 Quote
SteveShannon Posted 53 minutes ago Report Posted 53 minutes ago 34 minutes ago, WRUU653 said: This would be my thought exactly Edit: that said I use Dark mode on my iPad and light on my Mac and don't have this issue, but the question remains what browser and setting is @UncleYoda using, or device for that matter I changed my phone settings from light to dark and it made no difference to the way notifications appear. I also adjusted my brightness way down and the notifications are still visible on my phone. Again I think it’s important to know what platform @UncleYoda is on, whether he is using a browser, and if so which one, or Tapatalk or the MyGMRS app. Im firmly convinced that the problem is exacerbated by his local settings but the light gray text on black background doesn’t help. Quote
