I’m looking for opinions. In this pictured is one of the 2 connections on a Tram 1491. I wish to improve on keeping the moisture out and be easy to take apart. My idea is anti seize on the threaded portion and a heat shrink tubing over joint plus quality tape over that. What are your thoughts. As I reAlly only want to climb the tower one time and the anti seize is a just in case. I have to go back up. Thanks in advance. Just realized I posted 2 male ends but you got the idea. It is a compression type fitting with a silicon compression gasket
mainehazmt
6 answers to this question
