Turns out it's not that big of a thing. Used 12 Gauge copper solid wire. Used the following formula:
Used a drill and a vice to straighten the wire. Ran into one problem, I don't have a hot enough soldering iron/gun for that large copper. Have one on order but I did manage to get a solid solder connection although not pretty. Left both legs of the antenna long and trimmed each by 1/8" increments. Hit 1:1.03 at one point and should have left it alone. It is now at 1:1.2 which is fine for my first build. Used micrometers to measure spacing and feed points. Still have a little work to do on it. Want to re-melt the solder joints when the hotter gun get's here. Want to make some "standoffs" out of plexiglass for between the elements for consistency. Will pick up a chunk of PVC to wrap it in. Used RGB 8X for pigtail which is fine with me as it is only 6" long with less than 1% loss. Transceiver is putting out 9.9 out of 10 watts.
Not sure what I will do with the thing but I just wanted to see if I could make one. Measurements provided by above plan were very accurate with final build. My bench is a mess right now but I will take some pictures when I clean up the antenna a little and get closer to finishing the build.
WSKY567
And....
35 answers to this question
